Old 28th July 2008, 17:14   #1
His Highness's Avatar
Thanked: 25 Times
Default Grinding noise in Honda City 4At
Sometimes,just sometimes ( When the car is around 60 kmph and on 2500 RPM) I can hear a grinding noise from under the car.
If I increase the speed slightly, the noise goes away but the noise persists if I continue at the same RPM and speed.
Any idea what that could be about?
I called the Service centre and got the standard response " Please bring the car in and we will diagnose the problem"
Mind you, this does not happen all the time.
His Highness is offline   Reply With Quote
Grinding noise coming from the front brakes of Swift Vxi when rolling back vivekchugh Technical Stuff 10 9th October 2015 21:06
Grinding noise from rear wheels Hashim Technical Stuff 0 7th November 2009 00:25
grinding when first gear engaged cheatingdeath Technical Stuff 14 28th June 2009 15:25
Loud grinding noise from the rear reignofchaos Technical Stuff 19 26th March 2009 16:14
Grinding noise in gear-change! ramzsys Technical Stuff 3 1st October 2007 22:37
