Old 29th June 2009, 21:05   #46
COUGAR's Avatar
Thanked: 86 Times
I am looking to fit an AC in the gypsy next month after the rest of the work is done. What are the options other than the Sanden?
mine is a 2007 model MPFI king
COUGAR is offline   Reply With Quote
Old 30th June 2009, 11:16   #47
KSM-Vtec's Avatar
Thanked: 440 Times
Can someone plz put up detailed pics of the AC install(condensor location, electric fan, compressor details, plumbing)???
KSM-Vtec is offline   Reply With Quote
Old 16th July 2009, 15:41   #48
Gear-ge's Avatar
Hey guys !
Just the thread I was looking for. Am off to get a Wagon-R electric fan for my Gypsy King carb. Been havaing a hard time with the temp gauge shooting up to the red while idling/crawling through Delhi's rush-hour traffic. Even without the a/c.
Now I can probably get a belt to connect up the compressor, get the condensor coil (under-belly) checked, replace solenoid switch and drive around in air-conditioned comfort.
Oh, wait. That will be after I put in a new clutch assembly, change suspension/tie-rod bushes check shockers.
Well, after the next pay-check for sure.
Great discussion. Khan-saheb, let us know what aircon you put in and what-went-where ?
Gear-ge is offline   Reply With Quote
Old 19th July 2009, 15:53   #49
Thanked: 103,402 Times
Gypsy owners considering an air-con install would benefit from reading this thread (AC for MM550 (and Jeeps in general)) as well.
Old 10th August 2009, 02:06   #50
Thanked: 62 Times
If I remember correctly, Gypsy used to come with factory fitted A/c at one time.
Can anyone confirm that. And if i did, can't we replicate the exact setup at per the Maruti Suzuki stock setup.
wanderhermit is offline   Reply With Quote
Old 10th August 2009, 10:43   #51
KSM-Vtec's Avatar
Thanked: 440 Times
it comes only with the blower not the compressor, condenser and related attachments.
Old 10th August 2009, 11:02   #52
Thanked: 1,498 Times
On a lighter note, has anyone considered installing a fan inside the cabin directed at the driver and/or passengers?! Cheaper and more vehicle friendly for sure.
Wasnt that long ago when it was considered a luxury!
Reading all the posts, for a MPFI Gypsy, what would be the single modification to make that will accomodate the additional load on the engine? Larger engine driven fan? The Wagon R electrical fan in place of the engine driven fan referred earlier? Larger radiator? Or a new fan/radiator combination?
Btw, I would go down that path only if a cabin fan proves to be totally useless.
Sawyer is offline   Reply With Quote
Old 10th August 2009, 11:24   #53
KSM-Vtec's Avatar
Thanked: 440 Times
To my knowledge its not only the additional load on the engine but also the condenser blocking the air flow(if it is installed in the front of the radiator, which is the case most often) to the radiator.
To combat the load on the engine a bigger 3 line copper radiator is required and to improve the air flow an additional fan right in the front should be installed.
Old 10th August 2009, 20:43   #54
Thanked: 62 Times
I have one question. which will be the best suited radiator if I want to install a new radiator.
Can somebody suggest a radiator of a similliar Japanese car/suv. I think they are more reliable than the rest.
I hav3e also heard that Ford make one of the best radiators. Is it true. Is it possible to put any ford radiator in Gypsy. Ikon, Fiesta or Fusion?
Old 11th August 2009, 12:34   #55
nikhil1300's Avatar
Default A/c For Gypsy
Nice thread was planing to install A/C for my gypsy 1998 hard top can anyone tell me where i can buy the entire a/c unit in bangalore and which garage according to you can give me a trouble free installation.I am not so technical
pls correct me
changing belt driven fan to electrical
changing the radiator (wagan R,118N, Contessa ambassador)
changing the fan (wagan R,118NE,Contessa,ambassador)
installing compressor(sanden 507)
installing condenser coil(super king)
installing the blower (super king)
gas(R134a)
stock thermoclutch(??????)
and related attachments.(??????)
nikhil1300 is offline   Reply With Quote
Old 11th August 2009, 12:52   #56
KSM-Vtec's Avatar
Thanked: 440 Times
Well i am not too sure if the wgn R radiator will help. But the 3 line copper radiators do help a lot.
Have posted pics/details of the AC and Copper radiator install on my Gypsy recently.http://www.team-bhp.com/forum/4x4-ve...ter-gypsy.html
Old 19th August 2009, 14:11   #57
nikhil1300's Avatar
so people on this post or forum what will be the final verdict.I am not so technical
pls correct me
gas(R134a)
Old 19th August 2009, 15:40   #58
Jaggu's Avatar
Thanked: 8,680 Times
changing belt driven fan to electrical No, belt driven fan is retained. Electrical fan is added
changing the radiator (wagan R,118N, Contessa ambassador) Basically a bigger radiator with more core
changing the fan (wagan R,118NE,Contessa,ambassador) yes
installing compressor(sanden 507) yes
installing condenser coil(super king) yes
installing the blower (super king) yes
gas(R134a) yes
stock thermoclutch(??????) You meant thermo stat?
and related attachments.(??????) tubings and pipes
Maybe you want to do some heat sealing inside the cabin to make the ac more efficient also. Find out a good A.S.S or specialist AC guy and get it done, they will take care of the job.
Old 24th August 2009, 08:59   #59
nikhil1300's Avatar
thanks a lot jaggu will look in to it and get back with the details
Old 27th August 2009, 10:51   #60
nikhil1300's Avatar
just wondering
Reva Cars come with an a/c is it possible to install Reva Cars a/c in our half cabin gypsy i think since Reva car is the smallest car on the indian roads may be the a/c unit is compact and powerful
Does any one have any idea on this
Gypsy vs Gypsy King prasygreat 4x4 Vehicles 90 15th April 2016 01:14
Swift Airconditioning performance emkay456 Technical Stuff 64 10th June 2013 21:33
Airconditioning cars, were we fooled? gigy Technical Stuff 65 7th June 2013 21:52
Gypsy or Classic ? Now bought Gypsy pdev29 SUVs, MUVs & 4x4s 45 25th July 2008 11:19
