Old 30th May 2014, 12:34   #16
arunkumar_rec's Avatar
Default Re: Outside air entering cabin even with a/c in recirculation mode.
Folks,
Mine is a Hyundai Getz 1.3GLS. Recently I had my car's evaporator changed by MCC Motors, Perumbakkam due to ineffective cooling. And also the Refrigerant was filled up(completely leaked earlier). I was told that they didn’t remove the dashboard to get these done.
After the service, my car is sucking in outside smells/fumes even when the A/C is in recirc mode. When I asked MCC Motors about it, they claim complete innocence. Don’t know what went wrong when they carried out the A/C service.
Any guesses on what went wrong? – torn grommets/tear in insulation foams/misaligned fitment after service???
I don’t know if plugging in the fresh air inlet(hole in the BIW) will resolve this issue. If this is the best solution, what is the best way to do it – will plugging the BIW hole with heatlon foam by removing the Cowl be good enough (or) do I have to remove the dashboard and seal the blower inlet duct with a plastic sheet?
Please suggest..
Thanks,
Arun
arunkumar_rec is offline   Reply With Quote
What to check for outside smell entering the car cabin? satish_appasani Technical Stuff 25 10th May 2018 17:24
Engine choking in petrol mode, works fine in CNG mode fast lane Technical Stuff 12 28th August 2016 13:04
Traffic smell entering Cabin through the Boot Voyager-1 Technical Stuff 12 23rd July 2014 21:25
Skoda:Rain water entering the engine through the air filter koshy10 Technical Stuff 28 11th November 2009 11:22
CAI will suck only cold air: even if sucking in air just next from the engine :-) khan_sultan Street Experiences 19 30th June 2008 09:29
