Old 31st July 2008, 22:09   #1
ashwanth's Avatar
Default Gear levers - Shifting pattern, positioning
I haven't been in (or) driven a Mahindra Scorpio.Scorpio's gear lever angle is somewhat out-of-normal (i have seen pictures of the SUV)and the reviews I read about Scorpio in auto magazines and in the forums don't really lament about the gear lever position.
Shouldn't have Mahindra made the gear lever knob (atleast) orient towards near-vertical at Neutral position?
So how do you(if you have driven it) feel shifting in a Scorpio - vague or normal ? Just curious to know as many people don't like the gear lever design of TATA sumo Grande !
-Ashwanth.
ashwanth is offline   Reply With Quote
Old 31st July 2008, 22:12   #2
ashwanth's Avatar
Default Gear shifting pattern in foriegn and indian cars
How does one move the gear lever in opel astra for selecting different ratios? I have travelled in this car when I was a Kid and didn't remember/observe the gear shift pattern.See the attached picture.I know the standard japanese H-pattern.
my guess will be
1st gear - straight up from N
2nd gear - straight down from N
3rd gear - right ,up,from N
4th gear - left , down ,from N
5th gear - up,right,up from 4th(only possible from 4th ?)
R gear - left,up,from N
Hope I have not ruined the gearbox !
Old 1st August 2008, 11:34   #3
alpha1's Avatar
Thanked: 1,035 Times
I found the Scorpio's gear shift a pain during the TD.
Probably you get used it it as you continue driving.
Old 8th August 2008, 00:36   #4
razor4077's Avatar
Thanked: 258 Times
I did too, but the salesman attributed the stiffness to a brand new gearbox. I have driven older Scorpios, and have found shifting pretty painless. Takes a while to get used to the gearshift though, especially if you are used to driving a sedan with a short, slick gear throw.
Regarding the positioning of the lever, yes, it's about 5-10 degrees "rotated anticlockwise" if you get what I'm talking about. For example, third gear isn't straight up like in most cars, but is up and slightly to the left. Again, you get used to it soon.
razor4077 is offline   Reply With Quote
Old 8th August 2008, 12:29   #5
alpha1's Avatar
But the question remains why?
Is it that Mahindra thinks this would make some sort of distinct distinguishing feature on Scorpio - something that owners can boast about?
Or is it that they dont think it is important to give a comfy-at-first-go gear shift?
Skoda Superb : What a BLUNDER of positioning GTO The Indian Car Scene 55 22nd December 2011 13:41
Can indicator/wiper levers be swapped in Skoda? silverbyte Modifications & Accessories 5 2nd July 2009 09:04
Positioning of the Vapor canister sumeethaldankar Modifications & Accessories 6 14th March 2009 18:29
GEAR shift pattern - is this right? shapath Technical Stuff 7 12th October 2007 13:21
Positioning snafus in Indian Car Market hondadude The Indian Car Scene 9 19th October 2006 18:55
