Old 15th December 2009, 15:46   #1606
abbey4u's Avatar
Thanked: 108 Times
Originally Posted by LionX View Post
Yes, I am using Patronas Urania Supremo in my safari along with OWS220 engine protector. I felt marginal difference in the engine vibration and noise. Go ahead with the plan .
Thanks. What exactly is "OWS220 engine protector" is it some kind of oil additive like bardhal. Is it easily available in the market?
What if i just have the petronas urania.
abbey4u is offline   Reply With Quote
Old 15th December 2009, 18:23   #1607
Thanked: 245 Times
Originally Posted by ThE Godfather View Post
@Dadu, there could be any replacement? I mean can I ask them to replace something under warranty?
@King, thank you for the information.
You can ask them to check as per kingshuk and do not replace anything unless broken
Old 15th December 2009, 19:51   #1608
Alrite. I had shooted an email to Tata Motors on the email IDs Rahul Bro gave me. And they responed in 15 minutes, asked me to wait for sometime. I noticed in that email, the person who replied, has forwarded the email to 5 more people. I just hope I gets a resolution in time.
ThE Godfather is offline   Reply With Quote
Old 15th December 2009, 20:25   #1609
Rahulk76's Avatar
Thanked: 204 Times
Originally Posted by dadu View Post
@rahul76, Your earlier pictures do look like diesel spillage marks burnt over time, but its nothing to worry about, there's a lot of heat under the hood and with time the grime builds up.
Heres the latest pic of the area, after thorough cleaning. Hoping that its nothing more now to worry about.
The Tata Safari 2.2L Technical / Problems Thread-14122009019.jpg
and a negative of the same I am amazed... it gives lots of further infomration. Dirts are easily identifiable when you look at both the pics carefully and match the pattern in negative. ofcourse its how i interpreted it..
The Tata Safari 2.2L Technical / Problems Thread-negative.jpg
Last edited by Rahulk76 : 15th December 2009 at 20:33. Reason: Image placement and text additions
Rahulk76 is offline   Reply With Quote
Old 15th December 2009, 21:15   #1610
Thanked: 245 Times
You have become a cleanliness freak, Best of luck.
Old 16th December 2009, 07:40   #1611
Rahulk76's Avatar
Thanked: 204 Times
Ah no Dadu...not freak It was just because, wanted to take no chances of oil leakage from there as per instructions from TASS and guys back at RC. Those pics above were b,coz of just playing with irfanview and came across negative option
Old 16th December 2009, 12:51   #1612
LionX's Avatar
Thanked: 628 Times
Yes, it is like bardhal. I dont know about the availability at your place. In bangalore it is not easily available, only one dealer in bangalore. But you can order it from the site
http://www.speedworksindia.com/ .
I dont think there would be any issue in using patronas without the OWS, c'mon most of the safaris are running on Castrol GTX alone mate.
LionX is offline   Reply With Quote
Old 16th December 2009, 16:13   #1613
maheshmenon's Avatar
The engine problem is back big time, did about 1k km after my previous TASC visit (see previous posts). Just today when I started the truck, the rpm was needle was vibrating at about 500 only , the engine was shaking like crazy ( i mean really crazy) and making quite a racket. service light was remaning on. Attempted two starts but the same issue. had a quick look at the turbo hoses, no anomalies,but i had to shut down the engine fast, the vibes really had me worried that the mount may be damaged if I kept it running.
I want to get TML in the loop now, the customer care e-mail ID hasn't responded. any help will be appretiated!!!
maheshmenon is offline   Reply With Quote
Old 16th December 2009, 16:30   #1614
bj96's Avatar
Thanked: 130 Times
Originally Posted by maheshmenon View Post
...the customer care e-mail ID hasn't responded
My experience- they respond in a day or two. How long did you send it? If you have used harsher tone than usual, then poor lady handling customer mails may be short of wits to figure out whom to forward- means more delay .
...vibrating at about 500 only
Engine not revving up could mean suffocation or bad fuel to burn. Hope your diesel is not adulterated and your filter is clean?
-BJ
bj96 is offline   Reply With Quote
Old 16th December 2009, 19:02   #1615
Exclamation
I refuel only at Shell or PSU Company Owned & Operated pumps. Also the fuel filter was replaced about 10k km ago so I can rule it out!
Old 16th December 2009, 23:28   #1616
Shubhendra's Avatar
Thanked: 1,181 Times
Default Small Querry
Hi All,
My beast has completed around 7700 kms and gone through first and second service. But Engine Oil has not been changed in both the Services and as per SA of TASS there is no need for engine oil change and Engine Oil change will be done at 15,000 kms.
But today when i was going through Service Manual, it was recommending Oil change at every Service.
I am totally confused. Please suggest me Gurus, whether SA was wrong or TML. Should i go for voluntary Service now and change engine oil?
SHubhendra Singh
Shubhendra is offline   Reply With Quote
Old 16th December 2009, 23:34   #1617
SPIKE ARRESTOR's Avatar
Thanked: 807 Times
Dear Shubhendra,
in your owners manual you will be having a matrix showing the intervals at which what needs to be carried out as a preventive maintenance procedure, have a look at it you will get your answer, don't listen to the SA or anyone for that matter. Oil change at every service will not be written in the manual, most probably the kilometres will be mentioned.
SPIKE ARRESTOR is offline   Reply With Quote
Old 17th December 2009, 11:20   #1618
Thanked: 245 Times
Improve car performance, Car performance enhancements, Engine performance improvements, car performance products, car care products, engine performance products, engine performance enhancements, OWS, OWS India, OWS products, OWS products India, Tecta .
Then why not Bardhal itself, Bardahl Engine Tune-up & Flush, recommended by TATA and available at every T.A.S.S.
Originally Posted by Shubhendra View Post
Hi All,
SHubhendra Singh
Engine oil change is at every 15k or 1 year, whichever comes earlier, dont worry.
Old 17th December 2009, 13:28   #1619
LionX's Avatar
Thanked: 628 Times
Has anyone faced hard clutch in your safari?
The clutch is smooth in cold start but after around 30min drive, the clutch becoming hard, ride is rough, gear shift is hard and I can feel some vibration (some grinding kind of) on the gear lever and the pedals.
Till now TASS has replaced the following,
1. Clutch
2. Pressure plate
3. Slave cylinder
4. Some tube (don't know exactly what it is )
But the problem remains, and TASS has no clue. Please let me know if anyone knows the reason.
The car is in bangalore now and TASS is Concorde Motors in hosur road after bommanahalli.
Old 17th December 2009, 13:55   #1620
jkdas's Avatar
Thanked: 1,436 Times
Any smoke? Difference in engine oil level? Bad fly wheel?
dadu; new ones get a change at 5k or 7.5k as per Rahul IIRC.
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1186 14th June 2018 13:36
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
