Old 25th June 2010, 22:57   #2266
abbey4u's Avatar
Thanked: 108 Times
Thanks Prowler and bj96.
To try and identify here's what i did.
with engine off and AMP disconnected, ran stereo, blower for around 4 hrs. battery voltage dropped from 12.76 to 12.45. This means there component are not discharging the battery fast which is good.
Now cranked the engine on, (AC and stereo kept running), after couple of hours, cheked the voltage again. Of course after turning the engine off. Reading was 12. 7. This would mean alternator is chargin on load. which is again great.
SO the culprit seems to Amp as identified by TASS. i will now do a test on AMP
abbey4u is offline   Reply With Quote
Old 26th June 2010, 08:37   #2267
I also need a mirror. The flat one is useless, and not heated. It costs 100rs here.
I will be visting Jama masjid scrap market.
In Ludhiana, I found one intact mirror assembly for 700rs, but it was LHS. I needed RHS
Be aware that heated assembly has 4 wires, and non heated has 3 wires.
The heated mirror (LH / RH) have 5 wires and not 3.
3 wires to control the movement of the mirror (Left / right)and 2 for the heating circuit
kingshukt is offline   Reply With Quote
Old 26th June 2010, 10:02   #2268
bj96's Avatar
Thanked: 130 Times
Question Fluctuating RPM at the start
I see this new issue on my 2.2 done about ~9800kms so far.
My Safari sits idle for several days at a stretch and I fire it during weekends only. For last few weeks I have observed that morning (1st) start in the day, the engine rpm fluctuates (rises and falls) for first 5-10s before steadying at ~900rpm. During this time the engine noise is also harsher (falls and rises with RPM). No other issues, sluggishness, etc and second start onwards this issue is not repeated.
I thought, probably gumming of old diesel (I have tankfills which last for several months) due to limited running, however, wanted to check with other owners here.
Anything serious guys? What's the remedy? I am thinking about adding system-d in my next refill.
tia,
-BJ
bj96 is offline   Reply With Quote
Old 26th June 2010, 16:13   #2269
Thanked: 420 Times
Make sure you fill pure diesel and not adultrated with kerosene
Injector getting choked , Sytem-D will not help much
Tata Motors Customer Care :: Fuel Additives
Try Bardhal Diesel Combustion improver or BG244K and try for one tankful , may be drive from Pune to mumbai and back.
Try next tankful without and if problem is back time to reclaim warranty
amitk26 is offline   Reply With Quote
Old 26th June 2010, 17:23   #2270
cool_dube's Avatar
Thanked: 397 Times
Nothing to worry. This is the beast's way of shrugging off its sleep as you are waking her up from many days of rest My usage is similar to yours (once in 10-15 days) and I do see the RPM taking 3-4 seconds to stabilize. As long as everything is fine after that, nothing to worry.
Somehow I feel that we Safari owners are way too finicky about the beast... give her a break guys Read TSK's posts and enjoy...
Edit - Do stick to 'regular' diesel (strictly NO PREMIUMS) and do not even think of any additives till at least 30-40 K of running.
cool_dube is offline   Reply With Quote
Old 26th June 2010, 18:01   #2271
tsk1979's Avatar
Thanked: 16,016 Times
The non heated mirror has 3 wires
1 for left right, 1 for top bottom, and the third is ground.
Now why do you need to extra wires for heating element?
You just need one extra wire, since ground will be common.
anyways, I bought a mirror from scrap market. Got the internal plate(heated) for 200rs.
Heck, there is so much stuff from accidental vehicles there, you can actually construct a new car, esp if its a common car like swift
For the safari we had to hunt 20 shops before we could find the mirror.
Old 26th June 2010, 23:20   #2272
bj96's Avatar
Thanked: 130 Times
Thanks CD and Amit. Yes I'm using normal diesel only. Ok then, nothing to worry. I will wait and watch on this more.
Btw, out of curiosity, I went under to reach for the sedimenter. I could spot the canister like thingy with a sensor wire coming out, near the inlet of the fuel tank. I groped around, but could not locate any "drain screw" to empty it. How is it supposed to be drained? User manual does not document much.
Tata (safari)- official vehicle of CW Games.
-BJ
Old 27th June 2010, 01:06   #2273
CAn someone please tell me whats the idling speed /rpm of Safari? My resides at 1k rpm, is that normal or it should be low?
ThE Godfather is offline   Reply With Quote
Old 27th June 2010, 10:10   #2274
cool_dube's Avatar
Thanked: 397 Times
Should be b/w 850-900 rpm
Old 27th June 2010, 10:16   #2275
Thanked: 2,469 Times
A normal idle rpm for a safari is at 800 - 900 rpm, with the A/C ON, the rpm rises to 900. And the turbo kicks in exactly at 1700 rpm.
These are my readings noticed on a 3L Safari Dicor.
The erratic idle during long standing starts are a common thing, nothing to worry about. My Safari also stands for more than 10-15 days without being started, and i too notice the same. And thats normal.
I've noticed this problem in all of my cars.
Old 27th June 2010, 10:47   #2276
v&v
v&v's Avatar
Thanked: 1,099 Times
TSK, the scrap market you are referring to, is it the Mayapuri Mkt ? Me too looking for the RHS full assembly.
v&v is offline   Reply With Quote
Old 27th June 2010, 11:27   #2277
tsk1979's Avatar
Nope, its not the mayapuri market. Its the one near Jama Masjid. Just get down at chawri bazaar station, and walk to Jama masjid area.
Also, ask for "original" assembly. Many assemblies have local mirror plate(they take out original curved plate and fit duplicate flat internal plate).
So tell them you want original.
You will have to search quite a bit. Cost approx 5-600rs for entire assembly
Old 27th June 2010, 12:38   #2278
No mine stays at 1k all the time. Anyway I can set it on my own?
Old 27th June 2010, 16:45   #2279
rajismine's Avatar
Thanked: 252 Times
On my 3L, I was advised initially that the ideal idling rpm shud be 650-670 and mine always stays at that when idle..
however when idle, if i move the steering the rpm does go upto 700....donno if it may sound unusual but its like that from day one...
Godfather...there is noting that you can do on your own to change the idling rpm....
rajismine is offline   Reply With Quote
Old 27th June 2010, 18:13   #2280
drifter's Avatar
@rajismine: It's normal, my 3.0's rpm also goes up on moving the steering at standstill.
Drifter
drifter is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1186 14th June 2018 13:36
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
