Old 10th September 2010, 20:53   #2551
condor's Avatar
Thanked: 4,908 Times
mercedised : How many kms has your Safari done, I read somewhere that it has done 2.5L kms.
90k only. Not 2.5L .. I think your Safari in TBHP is the only one that has crossed 2L.
Old 10th September 2010, 22:44   #2552
sumannandy's Avatar
Thanked: 219 Times
That's right, it has done about 86k.
Originally Posted by mercedised View Post
@suman:
The turbo whistle above 2.5K or 3K is more pronounced then at lower rpm's. What type of noise are you talking about, Is it some kind of knocking or else?
may be its just the turbo whistle. There is no knocking. Just that I am not used to driving at high rpms and recently started driving at a little bit higher rpms.
Also, I got the oil changed at a Castrol dealership and the oil level is little bit higher than the max mark. Is that a problem? Its about 0.5 ltr more.
sumannandy is offline   Reply With Quote
Old 12th September 2010, 07:49   #2553
sumannandy's Avatar
Thanked: 219 Times
Please help me out with this. Will it cause any damage? Is it possible to drain the excess oil? It is about 1 inch above the max mark.
Old 12th September 2010, 13:18   #2554
SS-Traveller's Avatar
Thanked: 11,631 Times
A slight surplus of engine oil does not matter. Ideally and theoretically speaking, it puts an extra load on the crankshaft oil seal, which may cause it to leak. In reality, the oil doesn't make any difference, and if you are doing a prolonged (few hours) high speed run with, say, the revs above 75% of the red line, the surplus oil dribbles out of the crankcase air vent, and the oil levels off at the max. mark.
So, as the youth say today, just chill!
Old 12th September 2010, 20:05   #2555
mercedised's Avatar
Thanked: 177 Times
@suman: No problems. I have driven my Safari on 1 ltr of excess oil for almost 1000 kms. Later on when I came to know that due to faulty oil switch my father poured in 1ltr of oil, I went to SC and got the oil leveled.
mercedised is online now   Reply With Quote
Old 13th September 2010, 10:52   #2556
Kairalee's Avatar
Thanked: 24 Times
Originally Posted by dadu View Post
Under your circumstances, I would suggest using System D for a tankful only.
Without smoke the other possible causes dont apply to you.
Thanks dadu. I guess the proportion is 1 ml of System D for every 1 ltr of diesel isnt it?
Kairalee is offline   Reply With Quote
Old 13th September 2010, 11:07   #2557
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by lodhra View Post
hello
thank you guys
went to service station to get the numbers etched on glass. the service fellow told me the same about reverse gear
as for the reverse parking i feel the some slot switch gets stuck. he told me to have a few days run and see if it persist
thanks for the input
How would it help?
Thought excess oil will damage the turbo ?
Guess so. The container has a measure for 15ml, so if you do full tank then you need to squeeze out 4 times and add.
Old 13th September 2010, 11:21   #2558
Not unless the oil seals rupture.
Old 13th September 2010, 13:16   #2559
sumannandy's Avatar
Thanked: 219 Times
Great, thank you. I think I have driven around 300 kms in 3 days. Will get the oil leveled later when I get time.
Old 13th September 2010, 22:56   #2560
Thanked: 420 Times
Default Coolant level decreased after 2-3 weeks of change
I gave my vehicle for service on around 15th Aug and they replaced the coolant ( 2 yrs or 60K whatever is earlier), Vehicle was at A.S.S for one more week because the bumper was broken for which i refused to take delivery and they replaced it FOC. I saw coolant was filled till max mark.
Today I opened the bonnet and saw that coolant is much below max and above min.I do not see any white smoke or could not see any dirty gooey stuff in tank. Before coolant replacement during 2 years of ownership the coolant level never decreased from max mark.
What may be possible causes in this case , I am suspecting that they might not have put some washer / plug properly after replacing the coolant.
Any heads up before i go to T.A.S.S
amitk26 is offline   Reply With Quote
Old 14th September 2010, 10:09   #2561
...15th Aug...replaced the coolant ( 2 yrs or 60K whatever is earlier)
Today... coolant is much below max and above min.
Amit, you didn't check the coolant between the time it was filled and now (@1 month), did you? I would suppose the level you saw at the workshop was after changing coolant & topping up, before the engine was started. The drop in level could be because of the air pockets getting removed in the radiator.
Suggest you top up now and check after 1 week.
Old 14th September 2010, 11:18   #2562
Kairalee's Avatar
Thanked: 24 Times
Thank you sir! I will plan to do that during my next fuel top up, but I have a quick question now.
My Safari has run just around 3,200 kms, so i am wondering if using System D so early in its life will cause any issues to the engine.
If it is, then I dont mind waiting for a while before I can use it. I can live with the fact that the Safari will still have the jerk occasionally.
I am just being curious so I dont get anything messed up in the engine by adding this additive now.
Old 14th September 2010, 13:09   #2563
Hi Dadu,
I have the same problem of jerking and like you nsuggested i di see the black smoke in ORVM while the engine is gasping. What could be the other problem in this case.
TurboKunal is offline   Reply With Quote
Old 14th September 2010, 13:56   #2564
Thanked: 245 Times
True, I was not able to understand when people used to say excess oil damages the Turbo, it will damage only incase the oil seals rupture, in that case it will damage under low oil levels also.
There's definitely a leak, which needs to be found.
It wont cause any issue, its milder than the premium diesel. It has for 5ml and 10ml marker, I would suggest you use a clean empty bottle and measure and pour 65ml (65 ltrs tank) at home before you go for the fill.
Originally Posted by TurboKunal View Post
Hi Dadu,
Under normal circumstance, it can be caused primarily(there are many reasons though) due to two reasons unclean injectors and oil in the fuel. My first advise would be to use System D to clean the injectors, if that doesnt resolve, get your Oil separator checked for leakage and changed.
Old 14th September 2010, 17:10   #2565
Thanked: 38 Times
Infractions: 0/1 (5)
Hello
as per my previous post of wheel alignment i nwent to the service station
the guy took a TD and admitted that there is an alignment probem but not that grave and can be done on first service
now few things
the service station is packed with cars so they do not have time
as informed by great ppl here and also admitted by tata sales guy that wheel alignment must be done before car is deivered
my car is 6 days old and i plan to go on a 1200 km drive first week of october and plan to give the car for service
this guy has given me a date of 25th where he says he can do my alignment and then when i return i can get the service done
my questions are
1>should i hard press that guy to do y wheel alignment asap, its a pain and waste of time to go theragain and again because if i do my wheel alignment on 25th and then again on 4th i have to go for first service
2>is it advisable to skip the wheel alignment as he says it not a major problem do my trip and come back
the main issue is of contentment, why cant theses guys deliver this carswith full satisfaction
one more thing,
while driving i used to get a "chkchik" sound like a loose seat from back. earlier i thought it must be some unlocked seat but the sound grew iritating so i decided to check it out and found it was coming from the boot
when i showed the guy at tata service he found out to be from the the boot door upper biddng [just below the upper part of the door]
he said due to standing in storehouse and rain it has become dryu, he applied some wd40 and viola the noise gone. he said he couldnt replace that as it is one piece
he said due to rains sometimes drt get accumated and makes the vibratory noise
so any guys will this probnble recurr
if you ppl suggest i can flex my voice and gert an alignment done quick though he has nort refused it but going so many times is a pain
or do u think i ust complet y trip and go again
lodhra is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1193 10th July 2018 18:59
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
