Old 11th January 2011, 19:57   #2971
sheelz's Avatar
Thanked: 28 Times
Default Fog lamp adjustment
HI there
I have Dec 2010 GX. The beam of fog lamp is way too low, just ahead of the vehicle. Can the beam be raised. i asked a tata guy but he told me that it can,t be done. I think its possible.
Any idea guys how??
sheelz is offline   Reply With Quote
Old 11th January 2011, 21:45   #2972
4x4addict's Avatar
Thanked: 2,513 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
@sheelz:
Fog lamp reflectors are deigned to throw light very low and just a few meters. This is to prevent the light being reflected back in your eyes. You cannot do anything about the OEM fog light. You can add after market driving lights...
4x4addict is offline   Reply With Quote
Old 12th January 2011, 08:54   #2973
anujmishra's Avatar
Thanked: 338 Times
Default Re: Fog lamp adjustment
Originally Posted by sheelz View Post
HI there
Any idea guys how??
Even I wanted to do the same and it is way too low in my car. We may have to go to aftermarket mechanic and get it corrected. I think It can be done by
applying some thought, however there is no shortcut though.
I feel using spring screws on all four holders of each fog lamps can help adjusting. I need to find solid spring screws first.
...This is to prevent the light being reflected back in your eyes...
I am sorry this is negating light principle. If light does not reflect to eyes one cannot see light at all. Please remember old school physics diagrams of lights chapter.
anujmishra is offline   Reply With Quote
Old 12th January 2011, 10:15   #2974
bj96's Avatar
Thanked: 129 Times
Originally Posted by anujmishra View Post
I am sorry this is negating light principle. If light does not reflect to eyes one cannot see light...
I think both are right. However, 4x4addict, probably means that in case of dense fog, light will be reflected back by the fog particles and you will see nothing beyond the fog. E.g. windshield in our safari- is NOT meant to reflect any light. If it starts reflecting light you will not see the road properly and cause big strain to eyes. While road should reflect (e.g. markers, speed limit boards etc). Similarly, for best result, fog should not reflect back any light. Hence, fog lights are placed at lowest part of the car and pointed downwards to the ground so that it illuminates the road below better (light needs to pierce the thinnest layer of fog to hit the road below and get reflected back to the driver's eyes). If the beam is directed up the fog particles will reflect the light and rays will scatter without illuminating any road below.
-BJ
bj96 is offline   Reply With Quote
Old 12th January 2011, 11:23   #2975
ACM
ACM's Avatar
Thanked: 2,494 Times
bj96 - thats bang on.
In dense fog for example if one switches on the high beam one is completely blinded by the reflection from the fog. It's not that if the beam is strong or high that it would see through dense fog, instead it would reflect back more strongly. Hence if one does not have fog lights one has to use the low beam or sometimes even just the blinkers, else the fog lights have to be used and they do need to be positioned right at the base.
We at times use the auxilary lights in fogs and they tend to be called fog lights while in reality they are just auxilary lights that reinforce the main beam.
Also fog lights are of two types ones at the base have to such that they focus towards the ground at a short distance only.
While there are other lights that use the piercing principle, (single pointed beam that does not disperse easily.) This though will never be provided as standard by any manufacturer as it's not really a proven concept for driving in fog.
Bottom line one has to drive slowly in foggy conditions and the lights provided by the maufacturer suffice for that purpose. One may add additional lights just for night driving with better visibility in non foggy conditions.
ACM is offline   Reply With Quote
Old 12th January 2011, 13:18   #2976
Kairalee's Avatar
Thanked: 24 Times
HI there
Any idea guys how??
My Aug 2010 Lx had OE bumper/fog lights fixed as an additonal accessory at Concorde Bangalore, and the guys at the TASC I go to (EMM EMM motors - Banaswadi) were able to easily raise these lights. Adjusting a set of spring screws housed in the lights did the trick I guess. The lights now complement the headlamps very well. Those in Bangalore can talk to Mahesh or Afroze at EMM EMM motors, who will get it done for you.
Kairalee is offline   Reply With Quote
Old 12th January 2011, 15:46   #2977
anujmishra's Avatar
Thanked: 338 Times
Many thanks for this link. I would go this weekend and get it done. I was searching for such contacts.
Old 12th January 2011, 20:46   #2978
sheelz's Avatar
Thanked: 28 Times
Hi Guys
Mine is 2010 Safari GX with dark faux wood finish central console. I had fitted ambi pure car perfume on the left central vent. Due to spillage, I realised that the small portion as indicated using the drawing below has come off like layer. I didn't like it so I took my vehicle to TASS. They told me that it will cost 4400 rs to replace the panel only. I mean this is way too much.
My panel is scratch less except for that portion.
Any help guys? Don't want to put any sticker or something to hide it. Since the finish seems to be paint only, any idea of getting the finish done again.
The yellow portion is the area which is affected
The Tata Safari 2.2L Technical / Problems Thread-100_4437.jpg
Last edited by Jaggu : 12th January 2011 at 21:39. Reason: Back to back posts, EDIT the original post once approved instead. Thanks
Old 12th January 2011, 22:47   #2979
anujmishra's Avatar
Thanked: 338 Times
Our one of the BHPian LukeSkyWalker has put AutoGraphix stickers in that entire console of his Safari. I am also planning to do in the near future.
Contact any of the Autographix and you can select stickers of your choice and I really liked it. Please do not go to any local stickers shop.
Old 13th January 2011, 09:54   #2980
verditer's Avatar
Thanked: 72 Times
Wow - anu pictures of Lukeskywalker's central console?
Would love to look at it...
verditer is offline   Reply With Quote
Old 13th January 2011, 10:59   #2981
anujmishra's Avatar
Thanked: 338 Times
Sent him PM. I am sure he will respond at the earliest to this thread.
Old 13th January 2011, 10:59   #2982
mercedised's Avatar
Thanked: 161 Times
I too have these stickers on my Indica, none of them for Safari now. I'm planning a total different dash (cover) design tobe worked upon.
mercedised is online now   Reply With Quote
Old 13th January 2011, 12:37   #2983
4x4addict's Avatar
@anuj:
Having estates in the hills, I tend to drive in fog conditions a lot and hence know this from a practical stand point. No need to look up my physics text book.
Old 13th January 2011, 13:11   #2984
anujmishra's Avatar
Thanked: 338 Times
@anuj:
I just mean to say that "Light should reflect to eyes so that eyes can see the surface or front of car under extreme condition (read fog). If it does not reflect then it is as good as dark or fog". Fog generally absorbs lights in it and hence it does not reflect to eyes so driver cannot see anything.
I agree that fog lamps are built for lighting just next to car and it should be placed as low as possible because from ground surface upto 2ft density of fog is low so these lamps can penetrate that and light should reflect into eyes. As it go up density increases and driver not able to see anything even with loads of lights.
Old 13th January 2011, 18:25   #2985
Thanked: 18 Times
1. Its the Alternator regulator. Get it fixed ASAP as it can kill other electricals and damage ECU too
2. Can't do anything. Same problem here. A quick fix is mix some power steering oil with gear oil in winter months, but try at your own risk
3. 4000rs inclusive of everything(approx), but I may be wrong. I am not sure if this cost is for pair or one window motor
As for spending a bomb, if your alternator just needs a regulator change, it will cost you in the ballpark of 2000rs odd. Best get it done from a good electrician, I have had horror stories of alternator repair at TASS on my indica.
If you do manage to find a good independent workshop with scanner in NCR do let me know too!
I visited TASS last week facing same problem of 1st and 2nd gear are hard to Shift from last month other gears are okay to shift. They told me they have to check gear box, synchromesh rings and will be able to give my car in 2 days. I asked them this is just 6 months old car how can this prob be there in new car. They said there was another safari having same prob, so they changed rings. I told them of i will come later. I wanted to have second opinion. Now it seems that this is known problem.
Any more suggestions that thisproblem will be automatically solved by next 2 months as winter is almost over by next month
mandyrana is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
