Old 8th August 2011, 18:57   #3631
Kairalee's Avatar
Thanked: 24 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
Originally Posted by jobinjv View Post
Would like to know if anyone is facing water leaking into the cabin from the doors. There are droplets of water falling inside from all four doors under reasonable rain. A bit surprised as I don't think even an 800 doesn't leak water through closed doors.
Does happen sometimes, (should not happen though). Get the doors aligned well and may be replace the door beadings as well. That should solve the problem.
Kairalee is offline   (1) Thanks Reply With Quote
Old 8th August 2011, 22:20   #3632
jobinjv's Avatar
I don understand what aligning the doors mean.
jobinjv is offline   Reply With Quote
Old 8th August 2011, 22:48   #3633
Lukeskywalker's Avatar
Thanked: 1,157 Times
Just go to the service centre and tell them doors need resetting, they will do it, then check for leakage.
Lukeskywalker is offline   Reply With Quote
Old 9th August 2011, 13:00   #3634
DerAlte's Avatar
Thanked: 2,877 Times
Hmmm, though there is no leakage from the doors, I guess I need to get the doors 'reset'. The door level at the top on the right side of my vehicle are disturbingly above the body roof line. Nothing wrong with the door closing/opening otherwise, i.e. there is no rub above or below the door.
Can't figure out one 'tak' sound that comes whenever going over a bump at normal speeds - comes at right at the top of the bump. Everything seems OK - no loose plastic or metal parts. Sound seems to come from near B-pillar.
No rattles or squeaks generally even after 4.5 years, except for occasional squeaking (kich-kich, like noisy springs) from somewhere below dash. Comes and goes - no fixed pattern.
Anyone face these?
Old 9th August 2011, 13:52   #3635
tsk1979's Avatar
Thanked: 15,684 Times
Deralte, the "tak" sound is a feature. Its called the idler arm. Get it tightened, and it will go away for 3000-5000kms.
As for the "spring sound", is it from the dash? A common culprit is the "Jumping rod bush". Every time you get suspension travel, it makes that spring sound.
As for dashboard rattling, do not get it opened on fixed, you will get more troubles. Live with it.
Old 9th August 2011, 16:41   #3636
Prowler's Avatar
Thanked: 286 Times
Anyone face these?
I get a different sound of late. Some time when I turn the steering, it makes a loud 'tak' Sound. But other than this sound, there is no other symptom.
For your case, a loose nut in the under chassis Steel guard can also result in some sort of sound when the car goes over a bump.
Prowler is offline   Reply With Quote
Old 9th August 2011, 16:51   #3637
tsk1979's Avatar
No its no loose nut.
your 'tak' is your center pin. Get it greased. It should go away.
If it does not, you need a new center pin bush.
If it still does not go, you need a new steering cross.
If after all that also it does not go away, you need steering damper change.
If that also does not work, then steering box needs to be changed.
Pray that its a major steering box fault or a steering cross fault, because its covered under extended warranty. The simple faults like center pin cost 1300-1500 to fix and are not covered under extended warranty
tsk1979 is offline   (2) Thanks Reply With Quote
Old 9th August 2011, 17:20   #3638
Prowler's Avatar
Thanked: 286 Times
Thanks tsk1979. How serious is this issue ? I have a long (not too long) trip to make by the long weekend and I don't want to be stranded on the highway. If it is greasing the center pin, it can wait till I am done with the trip. But if it is a major issue related to steering cross, a high speed drive may buy me a one way ticket to meet my creator for which I am not ready yet.
Old 9th August 2011, 18:17   #3639
tsk1979's Avatar
do not worry, go on your trip, and get it sorted when you come back get it fixed. If the issue is serious(like it was in mine), your steering would start vibrating every time you cross 60kmph
Just a khat is okay
tsk1979 is offline   (1) Thanks Reply With Quote
Old 9th August 2011, 20:36   #3640
Had the same issue on the driver side front door, got it fixed during last service.
+10 to this, I made the mistake of asking them to reduce blower vibration noise, they reduced that and added dashboard rattle.
Old 10th August 2011, 20:36   #3641
anujmishra's Avatar
Thanked: 338 Times
For second time my rear right window stopped operating due to wire short circuit. Once it happened in Bangalore and now in Nagpur. I took Safari to Safeway Motors nearby TASS and they found insulation of wires removed near motor in rear right window and hence short circuit.
Unfortunately I was not present during repair activity as I had to go out due to some work. They took photo and show to me. It is strange that it is happening repeatedly. I told this check the culprit and correct it. Lets see how it goes. It is dangerous while on tour and window is open and fuse blows.
anujmishra is offline   Reply With Quote
Old 13th August 2011, 14:53   #3642
richie4u's Avatar
Thanked: 181 Times
Hey all,
M safari has completed 2 years and hence has finished all its free services, Well now that I will have to do paid services I was wondering about the following:
1) I want to take my vehicle to an independent service center (JKRS car care, Goa) who I have heard it being tata authorised and is excellent with Tata vehicles so I would like to take my car to them for yearly servicing or solving out any issues. My question here is that my vehicle now comes under extended warranty and hence if god forbid but if any major problem occurs with regards to any part that need to be changed under the e-warranty then will the regular TASS make a problem if my vehicle has been serviced at JKRS in the two year period?
richie4u is offline   Reply With Quote
Old 13th August 2011, 19:42   #3643
As long as you get your vehicle serviced from an Authorised service centre, there should be no problems in claiming any kind of warranty.
Old 17th August 2011, 08:00   #3644
rrsteer's Avatar
Thanked: 900 Times
A concern with my Safari lately. Since the last three tank fills, the mileage I have got is : 9.4kmpl, 9 kmpl & in the most recent 8.6kmpl.
This has been the first time that I have got such low mileage on the trot. On the other hand, the SUV which is now more than 2.5 years old and has clocked 90K kms, has never felt better to drive. The engine is very smooth and it feels like a well oiled machinery.
What can be the reason for the reduced mileage? The figures mentioned above are for 100% city use (non metro) and 100% AC on. While to some it may look par for the course, but I have maintained a regular log of my vehicle's FE and this is the first time in the ownership period that I have got such low figures.
A service advisor in a TASS advised to me to get the clutch overhauled. Apart from a sometimes sticky clutch pedal, I don't see the need. I concluded this by letting the Safari climb on a rather sharp incline, with AC on in 1st gear and with no accelerator input . The Safari pulled up just fine.
Please advise as to what can be the reason for the low mileage, or should I just ignore it?
PS: I upgraded to Continental AT's recently. And the low mileage figures have kind of coincided with the tyre change.
rrsteer is offline   Reply With Quote
Old 17th August 2011, 08:45   #3645
Thanked: 388 Times
Anuj inside door panel there is a peace of foam wrapped around wiring to reduce rattle and rubbing , Usually when panel is opened those guys mercilessly pull it apart. Just check if this helps
amitk26 is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
