Old 30th September 2011, 11:38   #3781
verditer's Avatar
Thanked: 73 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
Check the seat near that area. Shake it and see if any noise comes.
As for the door, do you hear anything when you open and shut it? If not, then its not the hinges but somewhere else.
No squeaking when the doors are open and shut; so yes, can rule out hinges. Will check the seats, but I think it is not the seats, but something with the pillar between front and rear doors, or something else in the door area.... because the sound originates from a high area, near my right ear, not below me....
verditer is offline   Reply With Quote
Old 30th September 2011, 11:42   #3782
smsrini's Avatar
Thanked: 272 Times
Originally Posted by verditer View Post
There is a continous squeaking noise coming from the right rear door hinges area; I have tried lubricating the hinges but that has not helped. Haven't been able to pinpoint the source - any ideas?
Want to try to fix it myself first if possible before going to TASS for such a minor thing.
The squeak source being close to my right ear when driving, is quite annoying...
Any pointers to what I can do to address this?
Could be door alignment when closed and the lock not tight enough..
smsrini is offline   Reply With Quote
Old 30th September 2011, 11:45   #3783
comfortablynumb's Avatar
Thanked: 962 Times
Could it be the seat belt harness, i.e. the metal widget through which the seat belt loops and comes down?
Cheers,
Vikram
comfortablynumb is offline   Reply With Quote
Old 30th September 2011, 11:54   #3784
verditer's Avatar
Thanked: 73 Times
Cheers,
Vikram
Thanks for pitching in, but dont think it is the seat belt harness - this sound is more from something heavy - squeeakky - ky ky ky - squeaky ky ky ky... ky ky...
If it is door alignment,, have to go to TASS then..
Old 30th September 2011, 13:55   #3785
bj96's Avatar
Thanked: 130 Times
...continous squeaking noise...source being close to my right ear when driving...
...the seat belt harness, i.e. the metal widget through which the seat belt loops and comes down...
Ditto. I had that noise. Turned out the seat belt harness at the top to adjust its length was hitting the pillar/plastic panel. You can slide it up and down to adjust length- has a red color lock button on it. Take it fully up (or down, if already up) and drive. Sound will go away. Spray some WD-40 inside to keep it quite. But, I think the best thing would be to strip the plastic panel and cushion the clamp with some foam for permanent fix.
I had another sound- the right ORVM used to do khrrrr... khrrr... on bad roads, sounded like door rattle. The ORVM is fixed on its mount using three nuts arranged in a triangle. One of these had slipped and another one had broken base. Don't know how/why? Did a jugaad (DIY)- changed the slipped screw and filled the broken base with m-seal. Noise is gone for now. I am told ORVM costs 5k + painting? :(
-BJ
bj96 is offline   Reply With Quote
Old 3rd October 2011, 13:58   #3786
verditer's Avatar
Thanked: 73 Times
^^ Thanks a lot friends. You were right, it was the seat belt harness, and I was always thinking it is something in the door. Taken care now.
Old 3rd October 2011, 20:47   #3787
Thanked: 21 Times
Some queries regarding my beast. Hope other Safari owners can help me out.
The leather on the steering wheel is peeling off at the bottom. TASS has promised to change the entire steering wheel. I'm thinking, lets just get a proper leather steering wheel cover done from elsewhere. Any idea about the costs involved?
Sometimes I sorely feel the lack of a clock on the center panel. Anybody out there with any after market fittings?
simpleman is offline   Reply With Quote
Old 4th October 2011, 15:05   #3788
jkdas's Avatar
Thanked: 1,435 Times
Learned another lesson
If you dont have EW, go to your friendly workshop ! Just paid 7500Rs as labor charge for 90k service and some work!
Total bill at 22k approx.
Old 4th October 2011, 15:20   #3789
n.devdath's Avatar
Thanked: 1,959 Times
This is a known issue with the Safari steering wheel and like you said, TASS usually replaces it FOC within warranty.
A faux leather cover should cost you around 500.00INR whereas a real leather cover from a branded place would set you back by around 2000.00INR.
n.devdath is online now   Reply With Quote
Old 4th October 2011, 15:31   #3790
jkdas's Avatar
You had extended warranty? If so why not use that to get the master and slave cylinders changed?
Plates are not covered, but Master and slave cylinders are covered under extended warranty.
Anyways, for now, you can change the entire clutch as a set rather than going piece by piece.
It costs 12000rs.
Wont all this be changed (master + slave) during a full clutch replacement?
Else, how much would it cost for slave/master cylinder replacement?
Some luck!
Old 4th October 2011, 16:06   #3791
tsk1979's Avatar
Thanked: 15,849 Times
Some luck!
Yes, I think the full clutch set does include master and slave cylinders, but cost including labor would be around 15000 I think.
Again, not sure!
Old 4th October 2011, 16:29   #3792
chaxy's Avatar
Thanked: 16 Times
Originally Posted by Prowler View Post
My truck's brakes judder at triple digit speeds. Last time when I gave the car for 3rd service they didn't think the front disks needed to be changed. I protested and they said - ok sir - bring it back when you are free. I have extended warranty which will last for another year. Front disks are covered under extended warranty ?
Thanks guys.
I have exactly same issue with my truck. My brakes (disks/pads) are in good condition too. TASS told me that it is the issue with suspension bush(s) on the rear that get worn out.
chaxy is offline   Reply With Quote
Old 4th October 2011, 17:39   #3793
Prowler's Avatar
Thanked: 300 Times
Oh. In my case, the service technician who took the car for the long test drive, told me that it is the front disks (probably slightly warped or something to that effect) which cause the juddering at high speed.
Prowler is offline   Reply With Quote
Old 4th October 2011, 23:17   #3794
chaxy's Avatar
Thanked: 16 Times
The same issue causes the truck to jerk sometimes when you shift gears. I checked this issue with two different technicians at different times. They both diagnosed the issue as a suspension problem.
Old 5th October 2011, 12:02   #3795
Prowler's Avatar
Thanked: 300 Times
Ok. My issue - I hope is only with the front disks as I have run only about 16000 km till now. It is too early for the suspension bushes to play up as most of the run was in highways.
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1180 24th May 2018 12:04
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
