Old 26th December 2008, 12:36   #436
trrk's Avatar
Thanked: 13 Times
Hi Suman,
Originally Posted by suman View Post
Yes and all four doors lock automatically a few seconds after the engine starts up (at least in the VX). Not sure what Jay's confusion is.
Way back in 1999 when I got my Safari, it had only central locking. So I got a remote central locking fixed to it. It would not lock automatically, but the driver's door lock used to lock all the four doors.
Jay is asking about a separate switch like in my City which locks and unlocks all the doors, I think!
@Steer: thanks for making it clear.
trrk is offline   Reply With Quote
Old 26th December 2008, 17:37   #437
jaysmokesleaves's Avatar
Thanked: 1,244 Times
The central locking that im talking about is the one that has an independent switch that locks all doors, which, when activated cannot be opened individually by other passengers.
The present system is not foolproof. The driver can lock all doors and anyone can open any door even when locked by the driver - so how can that be called central locking if anyone can open it.
Maybe TML provides central locking with decentralized opening.
Why I dont like this system is because my dog has figured out how to open the car door.
jaysmokesleaves is offline   Reply With Quote
Old 26th December 2008, 19:04   #438
Thanked: 1,592 Times
Oh My Dog! Thats dangerous!
The fella back home has learnt how to lift the latch on our gate, so now we HAVE to bolt the gate shut at all times. I know how you feel, man.
Steeroid is offline   Reply With Quote
Old 26th December 2008, 19:52   #439
Hows that possible! I have retrofitted Minda central locking in the LX version and once locked by the driver, the doors cannot be opened.
Thank god my Lab is not that smart.
Ravi Kashyap is offline   Reply With Quote
Old 26th December 2008, 20:33   #440
Strangerintown's Avatar
Thanked: 85 Times
You have the child lock on the rear doors and the rear tailgate. If you activate the child lock your dog will not be able to open the door from inside - however skilled it may be
Strangerintown is offline   Reply With Quote
Old 26th December 2008, 20:49   #441
That I am well aware of, but the child lock is nothing but nuisance value for me. Most often adults have to be rescued by using the outside door handle.
Thats why i wish TML provided REAL central locking and not a half baked solution in the name of central locking. I dont think adding a specific central locking switch on the drivers door panel will add to the vehicle cost in any way.
cheers:
Old 26th December 2008, 21:49   #442
nitrous's Avatar
Thanked: 285 Times
Which car/manufacturer has the kind of locking that you expect?
Old 27th December 2008, 19:12   #443
Got it in my Toyota Prado. Central door locking and central power window locking on the drivers door panel.
Old 29th December 2008, 06:43   #444
tsk1979's Avatar
Thanked: 16,016 Times
Its 9pm, on the highway, I see the service light coming on. It stays for 2 seconds, and then goes away. Happens a few times.
Call up the dealer helpline. and he says not to worry.
Tells me to do the following.
Engage 3rd gear, accelerate to 80+, shift to neutral, and full throttle for few seconds.
I do that, and don't see any service light.
Then at Khajjar, it comes again twice.
Come down to plains, fuel tank is on reserve, and do full tank from a known reliable pump. 300+ kms after that no warning lights, and I get 16.8kmpl
Old 29th December 2008, 11:19   #445
simply_sunny001's Avatar
Thanked: 15 Times
That happens due to bad fuel,i myself experienced that.
and i'm sure after a couple of tankfuls from any reliable petrol bunk,you will be fine.
simply_sunny001 is offline   Reply With Quote
Old 29th December 2008, 13:32   #446
jkdas's Avatar
Thanked: 1,436 Times
Left side window opens and closes as if its a demo as if someone tried to open/close. I cant open or close it from driver side now.
Wiring issue?
Old 29th December 2008, 14:03   #447
Thanked: 253 Times
Wiring issue?
LOL, almost certainly!
It certainly does not have a mind of its own, much as it might be trying to make you believe it does!
Old 29th December 2008, 14:47   #448
maheshmenon's Avatar
Unhappy C-M-H Deactivation!
Can any one explain as how I can de-activate the Carry-Me-Home feature on the 2.2??? Many a times I have been called by the valets/passers by/etc.etc. that my headlight is on!!! It is quite irritating especially when I am in a hurry!!!
maheshmenon is offline   Reply With Quote
Old 29th December 2008, 16:32   #449
smsrini's Avatar
Thanked: 272 Times
Originally Posted by maheshmenon View Post
This was posted by Dadu earlier on this thread.
Remove key-->Open Door-->Follow me home lights-->close doors-->press unlock and then lock.
cheers!
Srini
smsrini is offline   Reply With Quote
Old 29th December 2008, 16:32   #450
Thanked: 145 Times
... Can any one explain as how I can de-activate the Carry-Me-Home feature on the 2.2??? ...
You mean the 'Follow-me-home' right?
Of all the things that Safari does, carrying you home is what it does very well!
HappyWheels is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1186 14th June 2018 13:36
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
