Old 29th December 2008, 16:34   #451
tsk1979's Avatar
Thanked: 16,012 Times
My safari carries me only till the parking. Is there a feature which can make it carry me home? My home is on the 7th floor and when lift is not working its real painful. Carry me home will be really good. How do we activate it?
Old 29th December 2008, 16:37   #452
ram.west's Avatar
Thanked: 20 Times
Post ???
Guys!! What is the range of the default remote we get with the safari??
Mine works only if i'm say within 10ft range!!!
ram.west is offline   Reply With Quote
Old 29th December 2008, 16:39   #453
Thanked: 1,592 Times
Try daaru instead of diesel. The truck will then get high enough to carry you home.
Steeroid is offline   Reply With Quote
Old 29th December 2008, 16:40   #454
tsk1979's Avatar
Yes, its around 10-20 ft only, does not work more than that, maybe it needs new batteries?
Old 29th December 2008, 18:10   #455
maheshmenon's Avatar
Talking F-m-h
Originally Posted by HappyWheels View Post
You mean the 'Follow-me-home' right?
Of all the things that Safari does, carrying you home is what it does very well!
Sorry Got that wrong
Can we put take this up with IFTEX to add some to System -D??!!
maheshmenon is offline   Reply With Quote
Old 1st January 2009, 18:26   #456
Rohit26's Avatar
From sometime back when I am pressing right knob of my odometer to see temperature,it displays " OPEN " & above it shows my odometer-km reading.Previously i used to have temperature display there...
Is this problem or I am missing something ?
Rohit26 is offline   Reply With Quote
Old 7th January 2009, 11:01   #457
GhettoMAX's Avatar
Default ...
Rohit, something similar had happened to a car of mine which turned out the temp sensor was left disconnected by a mechanic doing some repairs around that area.
GhettoMAX is offline   Reply With Quote
Old 7th January 2009, 11:37   #458
smsrini's Avatar
Thanked: 272 Times
Default Fuel cap release not working
1) For about a week, the electrical fuel cap open is not working having to open the rear door and use the cable tucked away inside the left side compartment.
Is this a electrical problem or a mechanical one that can be DIY ?
2) Rear door squeak gremlins turn up again. The Concorde Motors service center had put some thick packing for the door which seems to have worn off. What is a permanent solution to this bug ? I've seen the Mercs ML, VW Touareg have some support for the rear wheel on the tailgate. Can something like that be done for the Safari ?
thanks
Srinivas
smsrini is offline   Reply With Quote
Old 7th January 2009, 11:44   #459
Jay is asking for the feature that doesn't let others open their doors unless the driver deems fit.
Edit: time warp. just realized I replied to an ancient post of suman's.
hrag is offline   Reply With Quote
Old 7th January 2009, 11:52   #460
jkdas's Avatar
Thanked: 1,436 Times
Check if the sensor (its a small device behind front bumper on left side,looks like a small black lengthy bulb) is still there. Or maybe some wiring issue. Took me sometime to figure out what it was initially when I saw the sensor.
Old 7th January 2009, 11:54   #461
Maybe a minor wiring issue, but take it to your dealer and you will get a free new solonoid under warranty anyway.
Old 7th January 2009, 12:42   #462
Default HVAC - Heating system
I've observed that if the temperature knob has been set to extreme right (full hot), without turning on the fan or switching on HVAC *F* button, the air that blows into the car is HOT.
Is this the same in all cars Or is it a problem in mine?
Thanks in advance
anilrs is offline   Reply With Quote
Old 7th January 2009, 13:54   #463
jkdas's Avatar
Saw service light on for a sec or so. I knew why; was on tsk1979 mode for 3-4days. I get 13kmpl
Back to my driving style. Red lining on lower gears helped push the carbon out after a week.
Old 7th January 2009, 14:02   #464
Thanked: 420 Times
Thanks in advance
It is same in all cars the HVAC button is to switch on AC compressor for cooling
How do some people get average of 14+ on Safari on highways ?
What is the safe and optimal Tyre pressure to get high fuel efficiency on safari ?
Max I got was 13.5 on highways on GQ while driving at 120 - 130 Kmph ? Tyre pressure 32F / 35 rear
On my recent coorg trip I got 11 on hill driving between 40 ~ 80 Kmph mostly in 2nd and 3ed gear and occasional fourth gear to control better on winding roads with tyre pressure 32F /35 R
and 12.5 in plains at around 120 Kmph+ on SH88 and SH17 with tyre pressure 33/36
amitk26 is offline   Reply With Quote
Old 7th January 2009, 14:41   #465
suman's Avatar
Thanked: 257 Times
There is a fuse for this in the fuse box in the cabin, check if its blown. If it's OK, sometimes the way the guys screw the fuel cap back on interferes with the release mechanism - a slight adjustment gets it back on.
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1186 14th June 2018 13:36
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
