Old 26th September 2012, 21:33   #4786
Flare's Avatar
Default re: The Tata Safari 2.2L Technical / Problems Thread
Originally Posted by shantanumishra View Post
Hi Ajit,
I have the similar setup running perfectly since last 2 years.
I will try to get you some pics in couple of days.
Yeah the rear fog lamps are on my mind for quite some mind. just cant get my hands onto it. btw lookin out for white bulb for my fog lamps
Flare is offline   Reply With Quote
Old 28th September 2012, 08:44   #4787
sirius1845's Avatar
Thanked: 13 Times
Question re: The Tata Safari 2.2L Technical / Problems Thread
Today I had a new problem while coming to office. Yesterday there were rains and the road was wet. There is a flapping noise as if mud guard flaps are flapping with the tires, but on inspection everything seems fine. Still when i drive with windows down i can hear this noise. Any one observed similar stuff?
sirius1845 is offline   Reply With Quote
Old 28th September 2012, 10:18   #4788
tsk1979's Avatar
Thanked: 16,421 Times
Sometimes polythene etc., get stuck to the undercarriage. Get under the car and inspect
Old 28th September 2012, 10:56   #4789
sirius1845's Avatar
Thanked: 13 Times
Smile re: The Tata Safari 2.2L Technical / Problems Thread
Problem solved it was a stone stuck in the front wheel creating the sound effect.
Old 28th September 2012, 14:06   #4790
BipB's Avatar
Thanked: 87 Times
Dears,
Have you guys ever faced a problem with the central locking unit? I own a 2011-June safari Lx. The dealer provided me with Minda remote lock at the delivery time. Last June I found that the remote lock was not functioning properly. Sometimes it worked and times remained silent! Got the Minda guys check it and they said their unit is doing fine. They asked me to contact TASS and get the central locking unit (The one below driver’s seat) checked. Called up TASS, they said there’s nothing in stock. To my surprise, the whole system started working again after few days except the ‘auto lock’ feature (The auto lock used to get activated on applying break after the engine was started). By this time my vacation was over and had to come back to work. Last week got a call from Dad saying the auto lock is all dead. The car cannot be locked even with the KEY!
Just wondering, is this part covered under warranty? I do have extended warranty as well.
BipB is offline   Reply With Quote
Old 28th September 2012, 15:49   #4791
shantanumishra's Avatar
Thanked: 28 Times
Originally Posted by BipB View Post
Dears,
Yes, the Minda central locking has a 3 year warranty. Just last week, my LX's central locking siren went dead and was promptly replaced under warranty by the Minda folks.
However, you will have to source the Minda warranty card for claiming warranty. You can get the central helpdesk no. from their website.
shantanumishra is offline   (1) Thanks Reply With Quote
Old 29th September 2012, 09:06   #4792
tsk1979's Avatar
Urgent help needed. When I hold the luggage rails and rock vehicle it makes creaking sounds like old sofa springs. Similar sound also comes when I turn steering. Its as if two pieces of something are rubbing together. Any idea?
Old 29th September 2012, 09:14   #4793
Thanked: 30 Times
Get shocker checked,
Not sure whether it has a shocker kit or shocker bearing,
But get the same checked,also get the jumping rod bush greased,
Thanks & Regards
Anupam
anupam00 is offline   Reply With Quote
Old 29th September 2012, 10:43   #4794
Born 2 Be Wild's Avatar
Thanked: 175 Times
Is anyone on the forum Using Synthetic engine oil for their Safari? could you please share your observations or any difference that you may percieve. Also WHat is the Mineral oil best suited for the safari? I change OIl every 7.5 K to 8K KMs.
Born 2 Be Wild is offline   Reply With Quote
Old 29th September 2012, 11:10   #4795
ringoism's Avatar
Thanked: 1,509 Times
Originally Posted by rideon View Post
Guys,
Need help on an issue with my Safari. For the last 2 weeks there is a very audible tire "Roar" when at speeds over 70kmph. Have checked the tire pressure and alignment and balance, but there are no issues. There is also a noticeable resistance in the vehicle since the roar appeared. I was told about checking the wheel bearings. Have yet to check them.
Any other suggestions?
Wheel bearing noise can usually be isolated from tire noise quite easily since there are generally directional effects (for lack of better terminology) - that is to say, it generally gets louder when turning left and softer when turning right or vice-versa, because of the varying load placed on the bearings on either side of the vehicle under such conditions. It is a rumbling sound, not anything sharp. I'm not talking about sharp turns, mind you, just of gently pressing the steering wheel in both directions at highway speed, while observing the effects. It is sometimes subtle - I've identified bad bearings in cars where others couldn't hear it. You can often feel it in the wheel or floorboards, too - and yes, as someone else asked, you can jack up a wheel and usually be able to hear / feel it there, too. Bearings should be absolutely smooth, and the slightest roughness / rumble is a telltale sign that it is nearing the end of its service life.
ringoism is offline   Reply With Quote
Old 29th September 2012, 12:34   #4796
BipB's Avatar
Thanked: 87 Times
Thnaks. Seems the OE Central Locking Unit is from Hella! Remote lock is all what I have from Minda. Worst case, they have quoted 2 weeks to get the replacement!
Old 29th September 2012, 15:29   #4797
tsk1979's Avatar
It was the rhs lower ball joint. Total cost including labor is 1220.
For a moment it had me scared. I never thought something so small could create such a racket !!!
tsk1979 is offline   (1) Thanks Reply With Quote
Old 30th September 2012, 11:58   #4798
Ajitsingh208's Avatar
Thanked: 103 Times
Just wanted to check with fellow LX owners,
Are the Red lights on doors, reflectors or do they actually glow when door is opened?
I know they glow in EX so I checked at the showroom, they said in LX they don't glow. Is that true?
Also the website says, there's a light in glovebox. I don't see any in mine.
Ajitsingh208 is offline   Reply With Quote
Old 30th September 2012, 12:31   #4799
Lukeskywalker's Avatar
Thanked: 1,170 Times
If your car is a model manufactured after 2010, in all probability the door pads have only reflectors, I've heard some cars came with the older version of lights subsequently, but I have checked in new cars displayed in showrooms, there is no light but only a reflector.
The glove box has a light, am not sure if it is there in LX, but if it says it is there then check for fused/missing bulb.
Lukeskywalker is offline   (1) Thanks Reply With Quote
Old 30th September 2012, 18:39   #4800
BipB's Avatar
Thanked: 87 Times
It's a simple reflector (on my 2011 LX). There's no other light on the door except the puddle lamp.
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1193 10th July 2018 18:59
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
