Old 22nd September 2013, 20:30   #5341
Thanked: 420 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
Thanks a lot for the pointers , Actually this noise started since yesterday morning and Vehicle was serviced around 1 month back , May be they did something at that time.
I will go to nearest T.A.S.S that is KHT if they can't do anything will go to concord.
Originally Posted by anupmathur View Post
The injector is not seated properly in the cylinder head and combustion pressure is leaking past the seat.
There is even a possibility that this injector will not come out easily; may have jammed in the mounting hole. Please have this attended to at an early date.
[/left]
Originally Posted by DerAlte View Post
Doesn't sound like a belt interference. Rather, it sounds like a leak to me, like a pressure being periodically released. But I have not clue what kind of leak and where. Definitely not fuel or head gasket.
Is there a difference in the feel of the engine? Like loss of power or roughness? Or the driving feel is exactly as before?
There is no roughness or powerloss in the engine , Also this noise is audible in idle engine in the moving vehicle there is no such noise.
amitk26 is offline   Reply With Quote
Old 22nd September 2013, 20:40   #5342
richie4u's Avatar
Thanked: 183 Times
Well this problem/sound is definitely due to pressure loss which is happening due to the injector not being properly seated. This same thing had happened to me once but was rectified giving the same reason. Please make sure that the fuel line that you can see connected to the engine is connected back and connected properly and tight cause when they did my job,while delivering the vehicle one of the "outputs" of the fuel line was not connected and fuel leaked out!
richie4u is offline   (2) Thanks Reply With Quote
Old 22nd September 2013, 20:54   #5343
bj96's Avatar
Thanked: 130 Times
I will go to nearest T.A.S.S that is KHT if they can't do anything will go to concord. ..
...leaking past the seat...
If it is some-kind of leak at the injector, wouldn't it be possible to put soap solution/foam around the seat and start the engine. If there is leak it should bubble up?
-BJ
bj96 is offline   (1) Thanks Reply With Quote
Old 23rd September 2013, 00:17   #5344
Thanked: 420 Times
Thanks a lot every one . One more question is it safe to drive it to workshop ( approx 25 km) or should I call them to tow it ? I have already driven some 3-4 km after I first noticed this sound.
Old 23rd September 2013, 06:26   #5345
Thanked: 253 Times
Thanks a lot every one . One more question is it safe to drive it to workshop ( approx 25 km) or should I call them to tow it ? ....
Safe enough to drive to the workshop.
The longer this leak persists the greater is the chance of the injector getting jammed in the mounting hole, with all the carbon deposits; which is something that might already have happened.
anupmathur is online now   (2) Thanks Reply With Quote
Old 23rd September 2013, 17:26   #5346
Thanked: 420 Times
Problem solved it was indeed injector not seated properly, refitting with a new washer solved the issue. Thanks a lot for help on diagnosis.
Here is the video ,Can some one please identify what kind of noise it is ?
One thing I noticed is that there is some amount of gooey oily deposit near to injector closest to firewall while others are completely dry, Can it be related ?
amitk26 is offline   (2) Thanks Reply With Quote
Old 24th September 2013, 21:28   #5347
richie4u's Avatar
Thanked: 183 Times
Got a peculiar problem today: I was driving to Kolhapur.After covering about 150-160 kms(crossed Belgaum) while I was accelerating in the 3rd or 4th gear , the car had reached 2K RPM or so but and a certain point on the highway I felt the car kind of lose power for at 2k rpm -then a jerk-then lose power again and then back to its normal self all in 3-4 seconds. The feeling cannot be explained properly but imagine the car at the sweet turbo spot climbing at 2000 RPM but the feeling on the accelerator pedal is as if the car is at 400 RPM(not actually happening but the feeling) just for 1-2 seconds and back to 2K RPM. Quite a scary moment that was. This happened back again when I was returning back from Kolhapur. Something similar had occurred to me while I was on the way to Pune some time last month but I thought it was just my imagination. What might be the problem?
richie4u is offline   Reply With Quote
Old 24th September 2013, 21:43   #5348
Thanked: 51 Times
Hi All,
I am planning to go for 45K service for my Safari. I have few questions.
1. Till now all the services were done at the interval specified in the booklet but right now itís only 43K and the kms specified in booklet is 45000-45500. Is it okay to get it serviced now for 45K free service? Will Tata create a problem in any EW claim?
2. What oil you guys recommend. Do we have any say at service centers? Till now I was going with whatever Tata was using but as car is out of service I want to use better stuff if there is.
3. I want to go for service every 10K after this free service. Is there any problem in doing that? Will Tata create a problem in EW claims because of that?
4. Is there anything special I need to take care in this service?
5. Few other things, looks like one of my reverse sensors is gone kaput. So Tata will change both the sensors or one? Is it covered in EW?
6. I have lost my windscreen washer reservoir cap. Does Tata sell that separately or I have to change full reservoir? I hate anything broken or misplaced
Please advise
-ijeet
ijeet is offline   Reply With Quote
Old 24th September 2013, 21:50   #5349
bj96's Avatar
Thanked: 130 Times
Originally Posted by ijeet View Post
6. I have lost my windscreen washer reservoir cap. Does Tata sell that separately or I have to change full reservoir...
Same here. When I inquired a year back, they said whole tank has to be replaced. Whereas Maruti sells it as a separate spare and costs 20/- or so (happened with my WagonR too). Safari's washer tank comes fitted with two DC pumps and costs around 1200/- or so. I have not changed, instead DIY fabricated a cover using 10ml measure cup that comes with babies Combiflam Suspension bottle. Does the work (preventing dirt falling inside). Will try to post a pic tomorrow.
-BJ
Old 24th September 2013, 22:03   #5350
Thanked: 51 Times
-BJ
Whoa 1200INR. then I think I will go with some jugaad only. Don't want spend that much just for a cap for sure. Already spoiled a tshirt by going under and looking on the underplates. I just lost it while I was filling the tank up and it fell on the underplate. Did all to find it but was not able to do so
ijeet is offline   (1) Thanks Reply With Quote
Old 24th September 2013, 22:54   #5351
richie4u's Avatar
Thanked: 183 Times
Well I got a cap for 20 buck over here in Goa at a spare parts dealer shop when I lost my cover too, it is not yellow in color like the OEM but if it does the job ,who's complaining. So try at tata spares dealers in your city,they may a white colored cap which kind of does the job.
richie4u is offline   (1) Thanks Reply With Quote
Old 25th September 2013, 09:42   #5352
Lukeskywalker's Avatar
Thanked: 1,170 Times
Hi All,
1. Till now all the services were done at the interval specified in the booklet but right now it’s only 43K and the kms specified in booklet is 45000-45500. Is it okay to get it serviced now for 45K free service? Will Tata create a problem in any EW claim?
Hi Inder,
1)You can get it serviced a little early, no issues of warranty in that.
2)You cannot supply oil of your choice, you have to buy it from them, if you want better quality, ask them for the Synthetic Oil.
3)If you are using synthetic oil, you don't need to change it every 10k kms, but you can get a general checkup done at every 10k kms if that gives you peace of mind.
4)The sensor would not have failed, the pins connecting them would be disconnected, just ask an electrician to have a look.
If you know the SA, you can ask him to get you a reservoir cap from salvage instead of buying the entire tank.
Lukeskywalker is offline   (1) Thanks Reply With Quote
Old 25th September 2013, 12:45   #5353
Thanked: 420 Times
It could be chocked fuel filter if your safari is due for service try changing diesel filter. Initially the change interval as per service booklet was 30K but later they issued a circular to change at every 15K service due to frequent chocking.
Old 25th September 2013, 22:31   #5354
richie4u's Avatar
Thanked: 183 Times
Well my Safari was serviced recently in August so I don't think a fuel filter can get clogged in such a short period, can it? Is there a way to check it and clean it before replacement cause I just would not like to spend 1.5K for nothing. What could be another cause for this, just to remind you this does not happen on a daily drive for short period like 50 Kms or so but happens only when I do long drives or may be if i do short drives continuously throughout the day but in that case it happens at-least once a day.
Old 26th September 2013, 14:26   #5355
Thanked: 51 Times
Originally Posted by Lukeskywalker View Post
Hi Inder,
Thanks Hari Sir,
Sensor is making a continous beep sound thats why I was thinking may be it failed. Will get it checked.
Planning to book with Prerna, Hosur Road. Hope they can salvage a cap.
-Ijeet
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1186 14th June 2018 13:36
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
