Old 20th November 2014, 14:29   #5746
DerAlte's Avatar
Thanked: 2,877 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
Originally Posted by Ajitsingh208 View Post
... Every time I switch off my car, all the doors are automatically unlocked. Now if someone sitting in the middle row seats as much as touches the door opening handle when I am switching off the Safari, the child lock is enabled. So, I have to get out and open the door for them, Put the child lock back in Off position. ...
The behaviour is correct, but your association with child lock is incorrect.
If the door opening handle - whether the inside on or the outside one - is held open when the lock electrically disengages (by switching off car or by operating driver side lock lever), that door lock doesn't disengage - all others do. The childlock lever is not connected to this - it only prevents opening from inside, mechanically, by making the lever slip and not engage.
The correct method is (if the car is off) to a. tell the person not to touch the handle till you say so and b. lock and unlock with driver's side lock lever - this time that door's lock with disengage.
Happens to me all the time, but from outside. I would have started the car, the door locks would have engaged - and then my not-so-patient wife will stand at the door holding the outside handle and banging on the window. I have to tell her to wait till I unlock.
DerAlte is offline   (1) Thanks Reply With Quote
Old 20th November 2014, 17:04   #5747
bhagathmp's Avatar
Thanked: 62 Times
Hi Bugs (What a Nickname man!, hope you are not into Testing )
LOL not into testing, but in IT none the less.
Yes, but it still takes a couple of instructions to get this procedure into ones head, as I think this is mostly not how it works on other cars, or may be I never noticed
Bugs
bhagathmp is offline   Reply With Quote
Old 20th November 2014, 17:41   #5748
Ajitsingh208's Avatar
Thanked: 102 Times
Bugs
I guess I have got you guys confused.
Let me put it in Simple words,
If You set the Child Lock to Off does it ever turn back to On on its own.?
This is what is happening with my Safari.
Ajitsingh208 is offline   Reply With Quote
Old 20th November 2014, 18:00   #5749
bhagathmp's Avatar
Thanked: 62 Times
No it does not do that on mine.
Have you checked to confirm if the child lock "auto engages" under normal lock / unlock situations?
Bugs
Old 20th November 2014, 18:43   #5750
DerAlte's Avatar
... If You set the Child Lock to Off does it ever turn back to On on its own.? ...
No it does not do that on mine. ...
Neither in mine. It only happens when the person cleaning my car manages to toggle it while cleaning it.
@Ajitsingh208, does it happen only on 1 specific door, or on any door (incl. 5th door) other than driver's side? What did the Tata A.S.S. guys say? If only one specific door, it could be that the lock engaging rod is bent.
Old 20th November 2014, 21:00   #5751
Thanked: 102 Times
So, this is not a hidden feature . So far I have only noticed it on the middle row doors, no one has ever sat at the back. But it happens on both locks, The child lock automatically goes to ON if someone touches the door opening handle, Then I get down, put it to OFF, let them out. Sometime later, the process repeats itself.
Any clues as to what I can ask the TASS guys to check.
Old 20th November 2014, 21:10   #5752
bj96's Avatar
Thanked: 129 Times
If the door opening handle - whether the inside on or the outside one - is held open when the lock electrically disengages (by switching off car or by operating driver side lock lever), that door lock doesn't disengage - all others do. The childlock lever is not connected to this...
You are 100% right. I have noticed this in all my cars from 2002 WagonR to 2013 Honda. Looks like when the lever is pulled to open the door, it locks some internal mechanism, which prevents the release of some lever inside. The correct way, as you described, is either (1) tell your passengers not to touch (pull) the door open lever or (2) Unlock it, lock-it and then unlock it again- works fine.
I have a really strange problem in my Safari...
Ajit,
Learn to appreciate and enjoy what "The Beast" offers and ignore such little nuances. It helps to keep the blood pressure low and enjoy a good night sleep .
-BJ
bj96 is offline   Reply With Quote
Old 20th November 2014, 21:29   #5753
Thanked: 102 Times
Originally Posted by bj96 View Post
Ajit,
-BJ
Hahaha, I was just curious, have stopped worrying about such features ever since I have owned RE, Safari has just added to the calmness.
Old 23rd November 2014, 20:57   #5754
Thanked: 40 Times
I have a door open warning on my instrument cluster all the time even when physically all doors are closed anf locked. Can any one tell me, how to find which door sensor is giving this spurious warning? I am not able to lock the car with remote since it activates the siren and the door auto lock after start also wont function. Will the obd port gives these info?
ameaa is offline   Reply With Quote
Old 24th November 2014, 15:25   #5755
DerAlte's Avatar
Originally Posted by ameaa View Post
... how to find which door sensor is giving this spurious warning? I am not able to lock the car with remote since it activates the siren and the door auto lock after start also wont function. Will the obd port gives these info?
The OBD port will not tell you about the door switches. Definitely one of the switches is misbehaving, without which door locking electronics will not raise an alarm.
Detecting which switch is a tricky problem, since the wiring side of the switches in not easily accessible. One way of searching is to look for a door that has an unusual gap with the frame. The one that is the most common culprit is the 5th door. The only other way is to check the health of each switch with a multimeter, only the A.S.S. people will be able to do it.
Old 24th November 2014, 15:31   #5756
ebonho's Avatar
Thanked: 3,179 Times
Hmmmm surprising. I never knew my wife had a twin sister somewhere in Bangalore .....
Of course my half of the twins will not leave the handle, so its impossible to unlock the door. Its a marital pantomime that we have come to enjoy after 18 years together.
I often wonder if things could be reversed if she was ready and waiting by the car, and I took another 15 minutes dashing on my favorite after shave, before making my appearance outside, ready to leave.
Maybe that's a mystery I am not destined to solve.
ebonho is offline   (2) Thanks Reply With Quote
Old 24th November 2014, 16:49   #5757
DerAlte's Avatar
Originally Posted by ebonho View Post
... if things could be reversed if she was ready and waiting by the car, and I took another 15 minutes dashing on my favorite after shave, before making my appearance outside, ready to leave. ...
ROFLMAO.
Unh-hunh no, doesn't work - have tried that too! I only get a constant stream of reminders, increasingly growing raucous by the minute.
The only thing that worked for me was to get down and open the door for her like a thorough gentleman.
Old 24th November 2014, 18:15   #5758
tsk1979's Avatar
Thanked: 15,683 Times
A.S.S. and multimeter? You give some people too much credit!
They usually solve stuff by hit and trial only!
tsk1979 is offline   (1) Thanks Reply With Quote
Old 1st December 2014, 18:46   #5759
DerAlte's Avatar
Any idea what does Brake Disk cost? Better to do it at T.A.S.S. or outside?
Old 1st December 2014, 19:29   #5760
Thanked: 388 Times
Approx 8K for pair + labour
http://www.99rpm.com/tata/brake-disk...or-safari.html
Better to get disks resurfaced outside. I got my brake disks resurfaced on lathe, It takes away less then 1 mm of thickness. Brakes form a lip sort of thing at edge and only that much was removed. I guess you can safely get the disks resurfaced a couple of times before changing.
In Safari hub needs to be opened for taking out disks so get hub greasing done as well if you are getting it done outside.
amitk26 is offline   (2) Thanks Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
