Old 27th February 2015, 16:21   #5836
mercedised's Avatar
Thanked: 165 Times
Default re: The Tata Safari 2.2L Technical / Problems Thread
Any idea about cost of MAF sensor(located on the air filter) in Safari 2.2?
Looks like its gone kaput.
Better replace the MAF if its gone bad. Engine might run lean or rich with a bad MAF, my 3L which ran fine for 1.5L kms, suddenly the MAF goes bad, I ignore the problem and 10K kms later the engine has enough back-pressure that I had to get it rebuilt. The engine ran too rich or too lean at times due to bad MAF.
mercedised is online now   Reply With Quote
Old 27th February 2015, 16:26   #5837
Thanked: 18 Times
Please search for thread to clean MAF sensor. See if this solves your problem.
mandyrana is offline   Reply With Quote
Old 27th February 2015, 16:30   #5838
Originally Posted by mandyrana View Post
Is there any need to replace water pump. My car is 57000 kms old. I will get water pump changed at 100K. By the way what is cost of water pump
You are correct theoritically as regards change at 100K. You may get it checked properly and then decide. My water pump went bad @ 65K and I ignored it for @ 3-4K before deciding to get it changed.
kingshukt is offline   (1) Thanks Reply With Quote
Old 27th February 2015, 16:38   #5839
Thanked: 18 Times
Thanks!!
Are you talking about this big hose shown in attached picture?
Old 27th February 2015, 16:42   #5840
Thanks!!
No it is a black rubber hose -
The Tata Safari 2.2L Technical / Problems Thread-radiator_hose_safari.jpg
kingshukt is offline   Reply With Quote
Old 27th February 2015, 16:53   #5841
Thanked: 18 Times
No it is a black rubber hose.
Any thing from this picture. Can you please share picture?
Old 27th February 2015, 16:57   #5842
Yes - Hose| Thermostat to Radiator OR it can also be Hose| Upper cooling pipe to radiator.
It is most likely Hose| Upper cooling pipe to radiator.
Old 27th February 2015, 18:59   #5843
Thanked: 18 Times
Is there any reason this happen when engine is cool in morning, not in daytime. After reaching office my car is parked for 8-9 hrs but no leakage?
Old 2nd March 2015, 16:56   #5844
Thanked: 18 Times
Visited TASS on Saturday and he checked all the pipes and then found that there was leakage from Water Pump,So got water pump changed. Total damages to pocket Rs 3600.
I asked him to check Timing belt also, he checked it and said it is fine and get it changed around 90K.
I asked same guy 10-15 days back check problem with water pump but at that time he said no there is no problem in water pump. This time I was hell bent to chek water pump also.
I seriously doubt the quality of parts TATA is using.
Old 2nd March 2015, 17:04   #5845
My 1st timing belt got replaced @ 40K
Better get it check properly. Many things damage the timing belt, including the pulleys and idlers
Old 4th March 2015, 00:19   #5846
tsk1979's Avatar
Thanked: 15,704 Times
Thanks for the tip. I have barely run about 1200-1400kms, and am currently doing only less tan 2000rpms, upshifting early and driving in higher gears to lessen number of revolutions.
Got a working MAF now, checked it, and service light goes away on connecting new MAF. Will get it fixed tomorrow
However, there is one issue. When I insert multimeter from the wire side, I do not get voltage, looks like the slots are too tight. I need to use some pins probably and then connect the multimeter to pins to see if MAF is increasing voltage when engine is revved.
Old 4th March 2015, 07:59   #5847
mercedised's Avatar
Thanked: 165 Times
If the maf you have found is also bad then you will find loss of power while accelerating, I tried replacing my maf later after the engine was rebuilt although the check engine light went away with the replacement but the engine was now suffering from loss of power, sudden hiccups while accelerating. Unluckily the MAF for 3l Safari costs 18000 rs, Tata has priced it insanely. The one for 2.2 costs 6000 rs, my suggestion if you can buy a new sensor then please do it because like what happenned with me a bad MAF might not in all situations give check engine light.
Old 4th March 2015, 10:18   #5848
Please guide me. I always felt the headlamps of my 2011, 2.2 to be weaker as compared to other vehicles around. Even my dad's alto has a better throw. After reading a lot of reviews, I upgraded with ceramic holders, new relays and nightbreakers in place of stock. However, i am still just not satisfied with the performance. While fitting the bulbs, the mechanic left the rear sealing cover behind the lamp loose because of which moisture, dust and a couple of mosquitoes have found their way to the reflector. Now, slight drop in reflection may be attributed to these aliens but what would be a permanent solution to this? HID kit? Any one with a first hand experience? Any expert link? I would be grateful. Thanks to all gurus in advance for their comments.
his-xc-lnc is offline   Reply With Quote
Old 4th March 2015, 11:06   #5849
tsk1979's Avatar
Of course, I will not just go by service light. I plan to insert multimeter probes on the MAF pin, and see if voltage rises on revving. If it does, MAF is good, if it does not, its not. Unfortunately, the ELM 327 OBD connector I have does not give MAF voltage. So you have to manually insert pins into the wiring harness to check voltage.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 4th March 2015, 14:39   #5850
Thanked: 397 Times
Try focussing the headlamps first . You just need a Phillips screwdriver the detailed procedure is given in one of the thread by "Dadu"
On top of the headlight assembly you will see a Phillips screw moving it moves HL up or down.
Park your Safari opposite to a plain wall 25 meters away from wall and on the wall make a marking at 76mm height now cover one side of headlight and rotate the screw on the other side HL till the arch just touches 76mm height.
You will see marked improvement after HL is levelled properly.
amitk26 is offline   (2) Thanks Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
