Old 8th May 2016, 21:14   #6211
Thanked: 21 Times
Originally Posted by sandeepc83 View Post
Hello,
I own a dicor 2.2LX 2012 model. Been a good ownership till now.Great drives, adventures and memories. The plastic cladding on the side has been fading off for sometime. Now it looks really ugly and shows prominently. I checked with SRMT vizag regarding body colour paint for the cladding. They quoted about 35k and is well beyond my budget. I am not really particular about body colour paint but I just want to cover up the faded cladding. Is there anyway of renewing the cladding or getting rid of the fading? Im posting some pics....
Keeping it natural will keep masking the scratches. If you paint it you run the risk of future scratches showing prominently. I think you should be able to replace just the cladding. Or you can try polish. The same one that they apply once you send your safari for service. Just my opinion
v_2rahjo is offline   Reply With Quote
Old 9th May 2016, 11:18   #6212
Thanked: 2,397 Times
Default Re: The Tata Safari 2.2L Technical / Problems Thread
Hello,
Why don't you give tyre polish a try? Don't apply too much as that will make the cladding 'shinny' after a while. Just use a little bit on a piece of cloth and apply it on the cladding. Wipe it after application, do not leave the cladding 'wet'. It will attract a lot of dust in such a case.
If you do decide to paint it, get it done outside, will be a lot cheaper.
Dry Ice is offline   Reply With Quote
Old 9th May 2016, 11:53   #6213
Thanked: 26 Times
Originally Posted by lodhra View Post
If i do not get it replaced soon does it cause any engine trouble running or one i can ignore ?
Just to update so someone else may benefit
The P0500 error came up due to carbon on the sensor. Got it cleaned (foc) tata guys did it for me as i had done engine work from them.So now all good. They said the moment error registers the engine may slightly stutter tgh nothing much dramatic happens unless its redlined
One more query
I feel engaging first gear a bit hard and also clutch seems a bit hard . My car has done only 38k in its 5 years. Anything potential to look out for ?
lodhra is offline   (5) Thanks Reply With Quote
Old 10th May 2016, 13:27   #6214
Prowler's Avatar
Thanked: 290 Times
One more query
Sometimes engaging first gear is a bit hard. It is 'normal' for our gearbox. As for the clutch, the service guys apply some grease and it becomes sort of normal for a few months.
Prowler is offline   (1) Thanks Reply With Quote
Old 26th May 2016, 13:36   #6215
man_of_steel's Avatar
Thanked: 1,056 Times
Guys,
Can anyone confirm if the stock central locking system of Safari (3.0 Dicor to be specific) is made by Autocop? Also, anyone aware of any procedure to reset the keyfob?
man_of_steel is offline   Reply With Quote
Old 31st May 2016, 04:24   #6216
scuba's Avatar
Thanked: 270 Times
Hi guys,
a problem occurred on my Safari 2.2 dicor. Temperature gauge needle stays on far left side - starting position all the time. That has happened when I turned AC on. AC fan runs ok. I didn't have the time to wait for engine fan to start, but temp. of coolant is around 95 degrees C.
Anyone with similar problem or possible solution?
Thank you all
scuba is offline   Reply With Quote
Old 31st May 2016, 11:18   #6217
PrasannaDhana's Avatar
Thanked: 2,727 Times
Infractions: 0/1 (9)
This thread has 415 pages. But here I am with a pif of my 2012 Safari Dicor 2.2 closing in on the magical milestone.
The Tata Safari 2.2L Technical / Problems Thread-wp_20160530_17_50_31_pro.jpg
PrasannaDhana is offline   (1) Thanks Reply With Quote
Old 31st May 2016, 19:22   #6218
Thanked: 397 Times
Originally Posted by man_of_steel View Post
Guys,
It is Minda not Autocop
amitk26 is offline   (1) Thanks Reply With Quote
Old 1st June 2016, 09:56   #6219
DerAlte's Avatar
Thanked: 2,877 Times
... anyone aware of any procedure to reset the keyfob?
What is the issue? The key fob doesn't need to be reset, even if one changes the car battery.
Old 1st June 2016, 10:52   #6220
Thanks. Was in the impression that it is Autocop!
The problem is weird. The central locking just freezes sometimes. Sometimes I will be able to lock/unlock with the remote but sometimes the system does not respond and I will have to open the door manually. Been in a sticky situation couple of times where the immobilizer was still active and wasnt able to start the truck because it was not responding to the remote. Even central locking from the driver door will not work when this freezing happens.
PS: Have bypassed the immobilizer as of now to avoid such situations.
PPS: Remote battery was recently changed and the LED blinks with all the button operations.
Any solutions for this? Gets irritating at times.
Old 1st June 2016, 21:19   #6221
DerAlte's Avatar
... Any solutions for this? Gets irritating at times.
Unless the Chassis ECU is misbehaving, this could be a simple problem of loose connection. With the car off and key out, remove the cable connector from the ECU (under driver seat) and reconnect. Just might solve the problem.
Old 1st June 2016, 22:42   #6222
DDDHRUV's Avatar
Thanked: 9 Times
Alternately you may also contact the MINDA helpline. Their service is quite prompt.
DDDHRUV is offline   Reply With Quote
Old 2nd June 2016, 11:20   #6223
The SVC has checked this once and did replug the CU. They then mentioned that the issue is solved and it was a cut wire somewhere. And now the problem has resurfaced. Its a 10yo truck and this critical component's misbehaviour at times is highly irritating since I usually travel with my family which includes my 1 year old daughter. So I don't really want to repair the system like what was done before and would like to completely replace it with an aftermarket system. Is it possible if I go for a full system including the actuators?
Thanks Dhruv. As mentioned above I have lost trust in the system and can't afford another lockout when I am out with my family. I would like to replace the system with a brand new one. Is this possible since it already has an OEM system in place?
Old 2nd June 2016, 11:35   #6224
DDDHRUV's Avatar
Thanked: 9 Times
man_of_steel, I am surprised your TASC has not involved Minda team till now. The OEM Minda support is excellent. You just need to log a complaint. I think their number All India Number is 011-33145145. You can always contact your TASC for local contact number. They should be easily able to resolve the issue. FOC if under warranty and chargeable if out of warranty. Just check if your battery is in good condition. Any drop in voltage affects the performance.
Old 2nd June 2016, 12:06   #6225
Nop. Minda team was not involved until now. Let me give it a last try. Thanks for the tip. And yes, battery is brand new.
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
