Old 15th October 2009, 14:01   #1306
Thanked: 245 Times
Originally Posted by kingshukt View Post
You are right , something is stuck. The electro-magnetic clutch on the compressor is stuck in engaged position.
My suggestion for all those who have fogging (early morning)- I recollect a post some-where, AC cooling without switching on, screeching sound like belt noise when engine is cold is to make beeline for TASS. TASS cannot change, even if under warranty, without a joint report with Subros person. So be ready for some delays.
The 1st lot of Safaris would be completing their 2 Year Warranty period and the compressor is a very expensive part.
EX and above can also check by switching on their roof A/c with the front A/ switch in OFF position. If you hear a hissing noise from it, (gas energizing in the coil),followed by cold air,you have the same situation.
Old 15th October 2009, 14:09   #1307
Originally Posted by ThE Godfather View Post
No its not exactly while going up down or something. But it just get start coming after diriving for a while. One thing to note is its only when car is moving and not stationary.
Means if I have a pressed the clutch and need to drive it comes then .only. Not while car is in neutral or I am pressing-releasing the clutch.
Its not under the seats, its more under the hood, below the engine.
I have the same problem. It does not happens always though. Sometimes when I change gear or even in nuetral when I depress the clutch thak noise happens. I was told by the TASS guy that this is common in all 4x4 and that it is normal. Something about having dual gear etc etc. Is yours a 4x4?
Country Road is offline   Reply With Quote
Old 15th October 2009, 15:00   #1308
tsk1979's Avatar
Thanked: 15,684 Times
I also sometimes hear this thak on clutch press. I was told its normal.
However any noise I hear the guy tells me "its normal in 4x4".
I ask him, can I test this in another 4x4 to which he says "Sir no 4x4 ever comes to this workshop"
Old 15th October 2009, 15:10   #1309
bj96's Avatar
Thanked: 129 Times
I hear this "thak" sometimes while releasing the pedal hurriedly. It is not loud but audible enough even with glasses rolled up. Occurs when engine has warmed up a bit. Can also be heard in neutral, car stationary- press and release the pedal quickly. I too was told this is normal.
-BJ
bj96 is offline   Reply With Quote
Old 15th October 2009, 17:42   #1310
sidcruise79's Avatar
Same here.
Another victim of the 'THAK'
sidcruise79 is offline   Reply With Quote
Old 15th October 2009, 23:56   #1311
tsk1979's Avatar
So fellas do not worry about thaks and clangs. Remember Tata is a truck maker, and you drive their most luxurious trucks, so as long as she moves its fine, thak, clang, whoosh, whistle, screem, whine... All are okay. As long as she moves
Old 16th October 2009, 00:21   #1312
adc
adc's Avatar
Thanked: 2,100 Times
Good lines that TSK, most luxurious truck! - seems mostly exclusive in a 4wd, none felt in a 2wd of mine.
As for me, will update soon on taking care and being careful of the front wheel bearings - just not to run up some 1k maintenance bill if you drive fast and roughly.
adc is offline   Reply With Quote
Old 16th October 2009, 01:30   #1313
nitrous's Avatar
Thanked: 283 Times
Thak should be the clutch release bearing.
Thak a Thimi Thaaaa!
Old 16th October 2009, 09:40   #1314
You said it .
So long as you are ready to dis-regard the minor niggles, there is no vehicle like a Safari. The silver lining is that this vehicle, the present model, has come a loooong way (and I say it from the positive angle) since the their 1st version, the TCIC, especially as regards the problems - minor or major.
kingshukt is offline   Reply With Quote
Old 16th October 2009, 10:06   #1315
Thanked: 136 Times
This Thak or kling (or however we need to call it) sound is there in my vehicle also. Got to notice it well when the SA was negotiating the vehicle into the service bay.
So the "all Safari's have this" or "this is normal, sir" excuse is not an excuse.
But then, the sound has not been too loud for me to notice before that.
HappyWheels is offline   Reply With Quote
Old 16th October 2009, 10:28   #1316
Rahulk76's Avatar
Thanked: 204 Times
You hit the nail on the head anna...
Guys, dont waste your time over this sound ...Its normal for a heavy duty clutch release bearing to make that sound.. Release the clutch slowly it wont be heard. Even my 3.0 ltr had this so does alto
Rahulk76 is offline   Reply With Quote
Old 16th October 2009, 11:09   #1317
Prowler's Avatar
Thanked: 286 Times
Thak a Thimi Thaaaa !
After a trip to Velankanni (mostly on cratered lunar road), my truck has started making rattling sound on the driver door. Driving a Safari is really a pleasure - but one has to become a little deaf.
Remember Tata is a truck maker, and you drive their most luxurious trucks, so as long as she moves its fine, thak, clang, whoosh, whistle, screem, whine... All are okay. As long as she moves ...
That she will always.
Prowler is offline   Reply With Quote
Old 16th October 2009, 15:15   #1318
One more thing about the turbo lag (I hope thats what it is called), when I push the accelerator, you feel the push on the seats after like 1 sec, is it normal?
ThE Godfather is offline   Reply With Quote
Old 16th October 2009, 17:10   #1319
I just checked the mileage on my vehicle and this the second time I have checked after the retro, its giving me a 'PERFECT 10'
Before the retro it used to give 12kmpl under the same driving conditions i.e city driving and I used to shift gears at around 2200-2500 rpm, now I do it at 2000 rpm.
Other 2.2 owners who have got the retro done please share your woes/experience.
Old 16th October 2009, 22:39   #1320
dkamath's Avatar
Thanked: 98 Times
Haven't checked the average in city driving conditions, as i hardly drive it in city of late, hehe. And have noticed a drop in fuel consumption on highway drives, after the retrofits, and the ECU reflashing in particular. What used to be 14.x kmpl, is now 13.x kmpl. Not concerned greatly by this drop, as it's returning the same figure unfailingly. But the thrust in the 3rd gear seems to be lost, ie. the vehicle would lug along effortlessly on 3rd gear in the ghats, but now, it drops power instantly and have to downshift to 2nd. Again, the engine feels more sedate now. Hence, have got over the second inkling as well, hehe.
PS: jaysmokesleaves, i haven't yet mastered the gear shifting skill that doesn't cut off the AC while driving over ghats. This is my only gripe.
dkamath is offline   Reply With Quote
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1139 14th January 2018 13:40
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
