Old 3rd November 2009, 11:53   #1411
Originally Posted by Rahulk76 View Post
Its a Front Left BRAKE CALLIPER ISSUE. Please ask the TASS to change it and check.
After getting the same rectified from TML, the issue hasnt comeback in last 8000kms on my safari
Are you sure it is the left brake caliper. I am given to understand that it is the Right brake caliper. I have also seen new (PDI) vehicles being corrected / repaired for this issue at TASS
kingshukt is offline   Reply With Quote
Old 3rd November 2009, 12:16   #1412
Rahulk76's Avatar
Thanked: 204 Times
Originally Posted by ItMyLife View Post
I have a question:
Picked up 2.2 LX Dicor last Tuesday. While braking at higher speeds ~80kmph, I felt the vehicle pulled to the left. Went to the service advisor and reported the issue.
The technical experts aka technicians/mechanics removed the front wheels, took out the brake pads, scrubbed them with sand paper and put them back on. Bleeding was an option they were considering, but suggested that I drive and test it again and come back if the issue persists.
Now though I did not get a chance to go beyond 60 kmph is the Delhi traffic, but I noticed that the acceleration is smoother. Has smoother acceleration got anything to do with what the technicians did?
Please enlighten me.
Well my vehicle spent good 2 weeks at TML ERC Center for rectifying this issue. Seems more like a QC issue, or batch.
All the details are available at http://www.team-bhp.com/forum/test-d...born-free.html
Rahulk76 is offline   Reply With Quote
Old 3rd November 2009, 12:32   #1413
LionX's Avatar
Thanked: 646 Times
Unhappy Effect of Retro
The issues/changes I am facing after the Retro fitment by TASS.
1. Decreased FE, FE has reduced by 1.5/2 km/ltr. Previously I used to get 12 in Bangalore city traffic, now it has reduced to 10.5 to 11.
2. Linear pickup, the turbo kick is linear from around 1500rpm. This makes the city driving easier, I can drive at 30Km/hr in 3rd gear without lugging the engine.
3. Low pickup. This is the main issue disturbing me now. Just after the retro, I could feel marginally loss in power. It turned out to be air filter issue at the first look, as the filter was clogged because of the quality cleaning TASS gave. Even after getting the filter fixed, I am not satisfied with the performance. I doubt it as a clutch problem as the clutch is getting harder after a short drive. It is super smooth for the initial 30min drive and after that its hard and even gear shifting is hard. I could feel the shudder in lower gears while acceleration. I need the Gurus advice here for the proper solution.
4. Water getting inside the Cabin. I came to know about this while ICEying the car. Water was getting inside through the firewall. My dealer (RF Motors) has fixed the security system wire in such a way that the rubber sealing cannot be put back in the firewall. I got it fixed but the problem still exists. I think it can also because of the door alignment. Need to get it checked again at TASS.
I am fine with point 1 & 2, but need a help for 3 and 4. Please advice as I am going for the second service next week. I am considering both Hosur road as well as Mysore road Concorde Motors for the service.
LionX is offline   Reply With Quote
Old 3rd November 2009, 12:59   #1414
Rahul Bro, as I said in my previous post, they removed some black color steel plate from the brake pads. Will it affect anything? Should I get back the plate into the PAds?
ThE Godfather is offline   Reply With Quote
Old 3rd November 2009, 13:04   #1415
tsk1979's Avatar
Thanked: 16,421 Times
The plate was not removed from the pads, but from the Chasis. Its called a shim, and is used for camber adjustment.
Old 3rd November 2009, 18:52   #1416
No he removed from the pads itself. I have seen that bro.
Old 6th November 2009, 16:14   #1417
Mine is Nov2008 model, I got a call from A1 motor for the retro fit.
enginbe belt
ecu programming
door laches
According to the operater, these are the things which will be changed.
Is there anything else which needs to be replaced? seems people aren't happy after the fit, but have no other option.
Bull_Twin is offline   Reply With Quote
Old 9th November 2009, 03:12   #1418
adc
adc's Avatar
Thanked: 2,103 Times
Default Oil pressure failure checklist - Engine components list
All, please do look at this thread
http://www.team-bhp.com/forum/long-t...ml#post1572449 (Tata Safari Dicor 2.2 LX VTT-TMT [The Magnificient Tourer] - the first 2.2 on T-Bhp)
And do let me know what are the specific engine components that I should absolutely stress at TASS to look into due to the oil pressure failure to the engine and as such vital engine components have been starved of lubrication.
adc is offline   Reply With Quote
Old 9th November 2009, 09:17   #1419
The below are the same comments that I had posted in http://www.team-bhp.com/forum/long-t...2-t-bhp-6.html (Tata Safari Dicor 2.2 LX VTT-TMT [The Magnificient Tourer] - the first 2.2 on T-Bhp)
The oil pressure sign coming on can be because of:
1. Pump failure (chances are less)
2. The oil pressure switch / sensor failing. The chances of this are higher. It is also possible that the wiring to the switch has come loose/ torn off. This reasoning for this is based on my earlier experience with Sierra. I also has the oil pressuire ligh, lighting up @ 11:00 PM on a lonely road and I was all panick-stricken. But since I had problems of oil leakages in this vehicle, I filled with 1L oil at the 1st petrol pump I could find and then limped home. The next day TASS analysed it as switch / sensor failure. It was changed and all was fine.
Mods: Please excuse this duplicate post. Posted twice since I was not so sure about which thread ADC will refer to seeking our replies / comments
Old 9th November 2009, 10:34   #1420
adc
adc's Avatar
Thanks much kingshukt, sure will have something to update by the day ends today.
Old 9th November 2009, 10:34   #1421
Rahulk76's Avatar
Thanked: 204 Times
In addition to above, ADC have a look at this as well
http://www.team-bhp.com/forum/techni...ml#post1393346
I hope your Return line of turbo and/or airfilter is clean
Old 9th November 2009, 10:41   #1422
adc
adc's Avatar
Return line turbo - have to be checked out
Air filter is almost brand new - 1200 km run from the change at TASS, at Jeypore, Orissa.
Old 9th November 2009, 16:29   #1423
Thanked: 50 Times
Default Two queries, pl. suggest
1. I bought my Safari in August 2009. At the time of delivery, had checked its VIN and dealer's invoice (from TML, Pune), it was sent in May 2009 from TML to the dealer.
After reading the discussion about retrofits, I am confused, whether any of those will be applicable on my Tigress too?. The dealer guys said, none is required on my car. I need opinion of all you gurus on this matter.
2. My second service is due, done 5500 kms. The vehicle has run smoothly without any major issue (engine related). On my recent long Rajasthan trip, I felt that liner power delivery has slightly reduced on return of the trip, as the odo was approaching 5k mark. Now on inspection, I find that engine oil appears dirty/ blackish in colour. Though, I have already read the earlier discussions on this forum about right time to change engine oil, as we all know the TASS guys insist that it is needed only at 15 k service. I am in a dillema before taking it for the 2nd service: should I insist on oil change (doesn't mind extra cost, for better engine life), or I shouldn't confuse with the color of oil, it is not needed before 7500 kms? In terms of kms, my 65 % driving have been highway driving.
All Pl. help me out in taking a right decision.
LongDrive lover is offline   Reply With Quote
Old 9th November 2009, 19:23   #1424
adc
adc's Avatar
Update on the oil pressure pump failure - it does not look good
Full post here: http://www.team-bhp.com/forum/long-t...ml#post1573699 (Tata Safari Dicor 2.2 LX VTT-TMT [The Magnificient Tourer] - the first 2.2 on T-Bhp)
Old 11th November 2009, 16:03   #1425
Thanked: 50 Times
All gurus, plz respond to my queries as quoted below. Waiting for your valuable responses.
Originally Posted by LongDrive lover View Post
Skoda Laura: Problems & solutions thread anandbhat Technical Stuff 1193 10th July 2018 18:59
Tata Safari - Technical Specifications & Feature List Stratos Technical Stuff 11 24th June 2011 20:48
technical aspects in technical driving ram_hyundai Technical Stuff 1 2nd February 2008 21:12
