Old 2nd August 2008, 13:53   #16
aerohit's Avatar
Thanked: 581 Times
I do the oil change myself, have been doing it forever ! Because MASS dont have the oil I want.
Why are people talking about MASS or Insurance?
You cant break the car yourself and ask the Insurance or Warranty to fix it!
Tomorow is a holiday will do further inspection.
Yes, it is good idea to speak to MASS though.
aerohit is offline   Reply With Quote
Old 2nd August 2008, 14:09   #17
amit_mechengg's Avatar
Thanked: 1,540 Times
I think since you have run on low oil , mostly the engine has seized. maruti has an option of rebuilding the engine, either the half engine or the full ones, with one year warranty too. you get a m800 half engine for just 10000rs with cylinder block, piston rings cranks and all. head is extra
Old 2nd August 2008, 14:59   #18
iceman91's Avatar
Thanked: 22 Times
No one said it will be done under warranty..what they are recommending is getting it done by MASS so that once you REPAIR it the engine is covered for a short duration under warranty!!!!
also you could claim insurance on it..now whether they agree to pay or you have to twist the story a bit is a totally different story.
iceman91 is offline   Reply With Quote
Old 3rd August 2008, 02:16   #19
Thanked: 658 Times
Finding the SX4 engine may be difficult. I am sure it can be repaired at a fraction of the cost.
If its too bad, go for the half engine assembly.
Old 4th August 2008, 11:23   #20
i inquired at M.A.S.S here in pune yesterday. they said that half engine can be done if engine is seized. but the engineer said that they have to check the amount of damage done.
he asked me one thing, didnt the engine oil check light glow? even the engine check light glows in case of problem with oil. also when the engine heats up the dashboard indicators throw the signals.
now i am also totally clueless as to what has happened. how all these checks were skipped
Old 4th August 2008, 11:55   #21
Thanked: 244 Times
Limp home mode
When the ECU detects a catastrophic failure in the operations, like an engine overheat. It slows down the RPM's does not allow you to drive normal but enough to drive the car at extremely slow speeds to the neast A.S.S.
Originally Posted by BaCkSeAtDrIVeR View Post
Those letters in bold - what do they mean?
Old 4th August 2008, 21:04   #22
Mpower's Avatar
Thanked: 1,682 Times
What you refer to as half engine is called short block. Popular for rebuilds. I think it should be fine if you do a through inspection and rebuild.
Old 20th October 2009, 06:11   #23
So were you able to find an used SX4 engine ?
D.V.R is online now   Reply With Quote
Old 30th October 2009, 15:52   #24
Thanked: 57 Times
Any update on the engine hunting ?
I cannot think of changing the smallest screw in the car when it is under warranty.
livyodream is offline   Reply With Quote
Need Advice: Used Honda Accord 2.3 or Used Hyundai Sonata 2.7 V6 abhijeetveer Sedans 17 27th August 2010 19:25
Swift to SX4 - Booking a Black SX4 Zxi - Some queries on Pg3 joy_swift Sedans 68 28th August 2009 16:08
New SX4 VXi vs. 2005 Honda City GXi ?? - SX4 NPV is higher!! complexroots Sedans 13 10th November 2008 20:58
SX4 Petrol / SX4 Diesel (To be launched) / NHC VTEC+ / NNHC (To be launched) ? autoenthusiast Sedans 24 19th June 2008 18:24
Suzuki SX4 or NHC type 1 second hand EDIT: SX4 now booked - EDIT 1 -Swift VDi booked GeekSrik Hatchbacks 126 24th June 2007 12:37
