Old 31st May 2008, 18:58   #1
aerohit's Avatar
Thanked: 623 Times
Default SX4 - Need Used Engine
Guys,
Can any one post high res pics of the engine bay of SX4 from different angles , including engine mounts - front, left, right and top.
thanks a lot
This is required, as engine transplant project will be going off soon.
thanks.
aerohit is offline   Reply With Quote
Old 1st June 2008, 19:27   #2
GTO - Touring's Avatar
Have you already tried searching in the BHP Garage? Lots of SX4 pictures there.
GTO - Touring is offline   Reply With Quote
Old 1st August 2008, 15:39   #3
aerohit's Avatar
Thanked: 623 Times
The Oil was not changed correctly either by Driver and engine was turned on and driven with very low oil level in it.
Everything is messed up.
Any chance of finding a slightly used engine in BLR ?
Please PM urgent, need to get it back on road asap!
[No i dont want to fix an already new engine, I want engine replaced]
Old 1st August 2008, 15:55   #4
theEnd's Avatar
Its probably best to go ask Maruti (or an authorized service centre). I doubt that there are many used SX4 engines available as of now.
theEnd is offline   Reply With Quote
Old 1st August 2008, 16:03   #5
Thanked: 245 Times
Check with MASS if any Total loss vehicle came, some will have their engines intact and can be bought.
Old 1st August 2008, 17:54   #6
im_srini's Avatar
Thanked: 399 Times
Exclamation
The Oil was not changed correctly either by Driver and engine was turned on and driven with very low oil level in it. Everything is messed up.
Hi Aerohit, a replacement engine, especially for the SX4, would be extremely difficult to source. May I ask who suggested that you replace the entire engine ? And could you elaborate on "everything is messed up" ? Did the engine seize up ?
Modern engines are more resilient than we give them credit for. Moreover, I'm guessing an M-series engine would have detected the low oil pressure & switched to "limp-home" mode - things may not be bad enough to warrant an engine change.
The problem with a replacement engine is it's questionable history, you could just be exchanging one problem for another !
im_srini is offline   Reply With Quote
Old 1st August 2008, 18:03   #7
theMAG's Avatar
Thanked: 1,574 Times
I dont think you'll get any used M16 engine. You might get earlier engines with some luck.
Old 1st August 2008, 18:15   #8
Awaiting Email Confirmation
hey bro..you can easily get a new engine replacemnt done at any reputed M.A.S.S in your city. Maruti Suzuki India offers complete engine replacement at very reasonable costs for almost any Maruti car. I know this because i had seen all this written in the form of a advt at one of the M.A.S.S. But you might have to double check. Best of Luck..you'll need it !
Vishesh is offline   Reply With Quote
Old 1st August 2008, 18:17   #9
aaggoswami's Avatar
Thanked: 1,542 Times
As someone pointed out, search around for any total loss car damage.
Or else get the engine replaced.
It will be very difficult to source a second hand M16.
aaggoswami is offline   Reply With Quote
Old 1st August 2008, 18:25   #10
Thanked: 149 Times
Those letters in bold - what do they mean?
And I believe that at least one sx4 had serious damage during a TD. That is in bangalore itself.
As pointed out, I do not see why you cannot re-build the engine - and if you insist, upgrade. Source the MJD!!!
Old 1st August 2008, 18:29   #11
iceman91's Avatar
Thanked: 22 Times
Dont get an SX4 engine...trust me I tried
on the other note..can i buy your "messed up" engine please ??
iceman91 is offline   Reply With Quote
Old 1st August 2008, 18:36   #12
Ricky_63's Avatar
Thanked: 394 Times
Have you got the engine checked ? What all is messed up ? Is it more costly to repair the damage than to replace the engine ? I should think not. Let the M.A.S.S. take a look & give you a run down on it.
Old 1st August 2008, 21:54   #13
drbabuanand's Avatar
aerohit
please specify what exactly happened.i also drove my sx4 without coolant and radiator water.the engine heated up.the service personnel replaced the radiator,checked the engine with "tech-2" and said everything is ok.now the car is as good as new.
guys please enlighten about tech-2.
drbabuanand is offline   Reply With Quote
Old 2nd August 2008, 12:50   #14
Thanked: 103,712 Times
Uh oh, sounds like your engine has seized up. Considering that the SX4 is a relatively recent launch, wouldn't your car have been serviced exclusively by the M.A.S.S.? If you have to repair it yourself, I'd suggest rebuilding the existing engine than swapping with a used one. That is, if you manage to find a used SX4 engine in the first place.
Old 2nd August 2008, 12:57   #15
iceman91's Avatar
Thanked: 22 Times
get the extent of damage checked. 9 out of 10 times it can be repaired and will be as good as new!
You are in Bangalore..check with any of the tuners in bangalore..they will be more than willing to help.
Else get the whole thing done by MASS, your insurance will cover it.
Need Advice: Used Honda Accord 2.3 or Used Hyundai Sonata 2.7 V6 abhijeetveer Sedans 17 27th August 2010 19:25
Swift to SX4 - Booking a Black SX4 Zxi - Some queries on Pg3 joy_swift Sedans 67 28th August 2009 16:08
New SX4 VXi vs. 2005 Honda City GXi ?? - SX4 NPV is higher!! complexroots Sedans 13 10th November 2008 20:58
SX4 Petrol / SX4 Diesel (To be launched) / NHC VTEC+ / NNHC (To be launched) ? autoenthusiast Sedans 24 19th June 2008 18:24
Suzuki SX4 or NHC type 1 second hand EDIT: SX4 now booked - EDIT 1 -Swift VDi booked GeekSrik Hatchbacks 126 24th June 2007 12:37
