Old 11th June 2015, 12:15   #61
Default Re: Good A/C Service mechanic in Chennai
Dear Members,
Please suggest a good ac mechanic for Maruti Swift VXi at Chennai . This is a 2007 model till 2014 the AC was fine, then the cooling went down I took it to an ac mechanic at Gopalapuram who filled gas and told me every year gas has to be filled now it is around 15 months again the cooling is down. Does gas need to be filled every year? Please suggest some genuine ac repair mechanic who will close the leak if any and then fill gas. Maruti is charging around 4500 for full ac overhauling .Your valuable advice on the matter please
biju.bala is offline   Reply With Quote
Old 11th June 2015, 22:55   #62
callvvijay's Avatar
Thanked: 144 Times
Originally Posted by biju.bala View Post
Dear Members,
I had taken my car (Alto) to Suresh Car A/C a couple of times (refer posts from me as well as others in the previous pages) and I'm quite satisfied. Referred my friend (Accent) and he is also very much satisfied. So overall, I can definitely recommend Suresh for your A/C needs.
One point to note - call him up before going to his place as he is quite busy.
Doesn't matter where you take your car, please post your experience after your visit.
Cheers!
callvvijay is offline   (1) Thanks Reply With Quote
Old 13th June 2015, 23:03   #63
Went to Suresh Car A/C after reading this thread for old hyundai car. Incidentally my call driver knows him for over 20 years. He replaced the entire part including compressor and filter. Gave an estimate of 19k but actually charged 21k. Also emptied my petrol tank.
A/C works fine. I am still testing it.
I felt it was a bit expensive and he did not explain why he charged 2k extra. I also did not bother to check with him as long as my ac is fine.
srikrish is offline   Reply With Quote
Old 14th June 2015, 01:32   #64
nitrous's Avatar
Thanked: 285 Times
Petrol lost must have been during testing. But, if it's 10 or 20 litres, it's a big deal.
Secondly, what old hyundai car is it that required an AC overhaul?
2k is ~10% difference between estimate and invoice. This is ok. It's a different story if he gave you a 25k bill.
Old 14th June 2015, 06:53   #65
hserus's Avatar
Thanked: 2,614 Times
Most likely took it for a spin to go wherever .. a lot of the small places do that - which is why you deliver it to them with a nearly empty tank.
Also try speed motors in shastri nagar, adyar. I and a bunch of bhpians highly recommend it. http://www.team-bhp.com/forum/chenna...r-chennai.html (Multi-brand Car Workshop - Speed Motors (Shastri Nagar, Chennai))
hserus is offline   Reply With Quote
Old 14th June 2015, 12:34   #66
scopriobharath's Avatar
Thanked: 1,255 Times
Actually - I would not recommend Yeahaya for an AC job, as he does not have the equipment. He outsources the same to someone else. I think i will stick with Suresh @ T.Nagar. Yehaya also does not have any equiment to Test the AC setup.
scopriobharath is offline   Reply With Quote
Old 14th June 2015, 16:44   #67
Dear Members I had taken my car to ac suresh at kodambakkam and his technician diagnosed it as a leak in the cooling coil. They took me along to a shop nearby and the shopowner quoted Rs.3500 for the cooling coil ( subros make ) it was in a shabby cardboard box without any markings and he was not willing to give a bill. I went out from there and was wondering whether to contact Susee for the spare part when I located a store across the road which also was selling ac parts including subros.He offered the same part in box packing for Rs.2175 ( with bill and 14%vat) . So kindly check prices for the replacement parts quoted. The whole service came to
Rs.1500 - gas filling + refrigerant Oil
Rs.1000- Labour
Rs.2175 - Cooling coil
The staff and team of ac suresh is knowledgeable and seem to have done a good job overall satisfaction level is ok only word of caution is to double check pricing of spare parts quoted. I would also ask Maruti owners to check with Maruti Service masters they have an ac repair package for Rs.4500 which they claim is inclusive of spares.
Old 22nd June 2015, 09:59   #68
greenhorn's Avatar
Thanked: 1,509 Times
I Had been driving around in my friend's 2005 Wagon R whose AC had turned into a heater. Took it to suresh, where the problem was diagnosed as a problem with the condensor. My friend also decided to change the evaporator as it seemed to be in bad shape (they said it could run for a while longer with a bit of cleaning)
Plus refrigerant & Labour cost 9.5K. Whole work was finished in a few hours. Initially was a bit taken back by the bill, but then i realized that the parts might have cost as much, and my friend had decided to change both the evaporator and the condenser. Very happy with the work - my friend had been offered a quote of 12K by his Bosch FNG with no assurance of fixing the problem, so this was a much better outcome!
Old 6th July 2015, 13:58   #69
Any recent experiences with car a/c mechanics in Chennai? I need to get my parent's santro fixed. Cooling is less esp in the heat here...
I am in T Nagar, so I suppose i should go to Mr. Suresh?
sundarpn is offline   Reply With Quote
Old 6th July 2015, 14:48   #70
greenhorn's Avatar
yes! I looked at alternatives only because going to T Nagar from south chennai is such a bother!
Old 28th July 2015, 21:09   #71
Thanked: 152 Times
You should try the one which is in the street just next to A2B chrompet. They did a satisfying job.
klassics45 is offline   (1) Thanks Reply With Quote
Old 29th July 2015, 11:39   #72
Thanked: 110 Times
I had AC issues in my palio for more than 3 years. It works intermittent and pressure loading cycle is not optimum. AC made worse noise when loaded. One of my friend recommended Sarath car AC mechanic. He is near to the Ascendas IT park Taramani. In the mean time I have procured another ac compressor from scrap market as my compressor was making noise. Dropped the car to him for the work. Estimated work was 12K. He replaced Evaporator (cooling coil), expansion valve, Drier bottle vacuumed and left for hours. In the mean time he started to test the scrap market compressor. He pumped to 350psi and dipped in a bucket of water. After few mins there are tiny air leaks from the seals on the scrap compressor. He said its a gone compressor and he started to test my compressor with the same method after 10 mins inside the bucket there was no leak and passed with flying colors. The reason for the compressor noise was the lack of oil. He used some lubricant to clean the compressor and later filled with oil. Unit was back with new components, 2 350gm refrigerant bottles were used (not the bulk black bottle). It was the moment I was waiting after turning on the compressor, Pressure was consistent from the delivery side, cool air from the grill in just few mins grill temp dropped 4C, another 5 mins compressor cut off at 2.5C . Total bill came to 11K. I am happy that he solved my AC issue permanently.
vijaycool is offline   (1) Thanks Reply With Quote
Old 16th May 2016, 17:41   #73
greenhorn's Avatar
went to suresh last weekend because of reduced cooling in my indica.
Was diagnosed as a blocked evaporator, 4.5K parts + 2.5K Labour.
during testing, they found out that the evaporator needed replacement too. Total cost ended up as 8K
He also fixed the FICD setting, so acceleration is more linear and less jerky. I'm happy
Old 24th July 2016, 16:09   #74
I went to him last week too and he suggested changing of the cooling coil in my 2003 santro 1.1. He did check the gas pressure and said it was good. However, i asked if it could be just serviced for now. He did the same and charged 2k for labour + gas filling. The cooling has improved since.
I feel the work was worth only about 1k to1.5k. The MRP on the gas bottle was 400 and i doubt if the entire bottle was emptied into my AC. I do get a feeling that i was paying more for the knowledge than for the work. But then again, I dont know what other AC mechanics usually charge or if they do a neat job like this.
The work involved removal and cleaning of the evaporator coil located behind the glove box and cleaning of the same (washed with water only). After refitting, the AC was connected to a vacuum pump and all the air was evacuated. Then, a little oil was added to the system by connecting the pipe to a small measuring jar containing maybe 50 to 80ml of oil. As the system was under vacuum, it sucked it up. Then finally, gas was added to the system.
dennie is offline   Reply With Quote
Old 8th August 2016, 00:27   #75
Dear nitrous ,
not sure if it was a nexus between my cab driver and suresh
it was a 2001 hyundai santro
Good Service Center / Mechanic for bikes in Bangalore? penpavan Motorbikes 30 8th January 2018 23:17
Good Bike Mechanic in Chennai? himakar Motorbikes 24 7th July 2017 12:10
Good mechanic for RX100 in Noida / Delhi? vaasu Motorbikes 6 8th December 2009 16:44
Need a good mechanic. Hellcat Motorbikes 4 23rd July 2005 15:11
