Old 24th September 2014, 12:34   #46
joybhowmik's Avatar
Thanked: 1,928 Times
Default Re: Problem in filling petrol with "Auto Cutoff" feature
Originally Posted by Red Liner View Post
Different dispensers, the issue persists only with my car. No other car behind or ahead of me has this issue.
And it's cropped up dead after service. Not very inspiring.
The auto-cut off lever on the nozzle normally has 2 or 3 notches. Moving the lever up or down on these positions, controls the flow rate of fuel. Try with the lowest flow rate.
For helping remove any airlocks, try rocking the vehicle gently as it is being filled.
Hope this helps.
Old 24th September 2014, 15:39   #47
Red Liner's Avatar
Thanked: 1,482 Times
Hope this helps.
Thanks man. But the point is it's not supposed to happen in the first place. There are no air blocks. Lowest rate does not work either. Attendant has to stand by and force feed like you would do when topping up the tank.
Red Liner is offline   Reply With Quote
Old 24th September 2014, 15:46   #48
joybhowmik's Avatar
This problem cropped up immediately AFTER the scheduled service.
If he manually force feeds at a higher rate, is there any spillage? Sounds like an obstruction in the inlet.
What really happened in Service? Were you present with the car?
Old 26th September 2014, 13:49   #49
Thanked: 1,083 Times
That the auto cut off is happening earlier is due to back pressure generated. If it happening after service, check if they changed the fuel filter. During that they must have either blocked the breather pipe, or constricted the fuel filling pipe.
Yamaha RX100 - Engine loses steam, power cutoff @ 90 kph yamaniac Motorbikes 12 25th June 2018 12:54
Baleno: Engine cutoff at 4500 RPM xenxer Technical Stuff 31 19th December 2009 06:18
Palio 1.6 - AC cutoff on Load Seeler_Rebeiro Technical Stuff 6 8th July 2009 13:47
Fiesta 1.6S RPM Cutoff autoenthusiast Technical Stuff 8 1st March 2009 10:05
