Old 5th August 2008, 21:37   #1
Deeps's Avatar
Thanked: 68 Times
Default Vibrating Brake pedal!! What reasons?
I have recently noticed this problem on my Xeta which has clocked 36,000km.
When I press the brake pedal, it viibrates and also a distinct and easily audible sound comes from the brakes. This happens at a greter degree when slowing down from higher speeds. The brake pads were changed at 25,000km.
I suspect that the discs need to be grinded. What else could be the reasons and solutions?
Deeps is offline   Reply With Quote
Old 5th August 2008, 21:54   #2
vikram_d's Avatar
Thanked: 940 Times
You are right. The discs most certainly are warped. They will need to be faced.
Old 5th August 2008, 22:07   #3
Deeps's Avatar
Thanked: 68 Times
Vikram, how long does this process take and cost??
Old 5th August 2008, 22:16   #4
nitrous's Avatar
Thanked: 285 Times
The brake discs and the new brake pads are having a bad marriage
Old 5th August 2008, 22:40   #5
Deeps's Avatar
Thanked: 68 Times
they lived happily for over 10K km. Midlife crisis now???
Old 5th August 2008, 23:21   #6
iraghava's Avatar
Thanked: 156 Times
Disc facing takes an hour or so so it is usually done when the car is given for a service. Cost should be around 800 rupees or so.
Old 5th August 2008, 23:41   #7
Thanked: 660 Times
Front disc have gone kaput, normally happens when you over use the pads so that revit holding the asbestos coating starts touching the disc. There are two solution, buy a pair of new disc, or give it to a lathe wala. Rs. 200 per disc job. Second solution is possible if and only if the disc is still thick enough.
Brake pedal too high, causing right leg pain ulhas.ahirrao Technical Stuff 16 4th February 2011 11:44
Brake pedal Wobble rajesh1868 Technical Stuff 12 12th July 2010 10:00
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Need Help: Brake pedal pulsating!!! stevie Technical Stuff 4 27th October 2006 20:41
