Old 5th August 2017, 13:00   #31
dr.faramroze's Avatar
Thanked: 13 Times
I have a 2007 Tata Indigo GLS petrol done 29900 KMS. Of late the steering oil is reduced to empty within a month amounting to a rack replacement. The car is showroom smooth with no other suspension, clutch or engine related problems. The original tyres need replacement since they have developed cracks in the treads. A new battery has been installed this week since I want to use the car for a few months more. There are some visible rust spots on the roof. Is it a worthwhile idea to restore the car by repaint? Can I remove the power steering and switch to normal rack?
dr.faramroze is offline   Reply With Quote
Old 5th August 2017, 15:07   #32
Leoshashi's Avatar
Thanked: 14,260 Times
Default Re: 10 year old Swift Restoration Project
Originally Posted by RSM_TorqueZoner View Post
Hi Shashi, Thank you so much for this great input. I spoke with the service manager and he says the half engine kit forms the lower portion, the head will have to be opened up, either way, to understand what the issue is. Repairing the engine could go upto 50K according to his estimate, exact issue can be found only upon opening up the engine.
Yes, first determine the issue. You can also make sure about the engine's health by performing wet and dry compression tests. This won't need dismantling the engine.
Shashi
Leoshashi is offline   (3) Thanks Reply With Quote
Old 5th August 2017, 16:22   #33
Roy.S's Avatar
Thanked: 106 Times
Default Re: Want to spruce up an older car
My Swift Vxi is almost 10 years old and has nearly 1.5 lac km on the odo. I've had no problems with this car so far and it does triple digit speeds on the highway without much of a struggle. Mileage is about 10.5 to 11.5 in the city and a consistent 15.5 on the highways. If I were to keep it for another 2 years by the end of which I would probably have run it almost 2 lac km, what precautions should I take? Is better to get a half engine job done right now before I really need to?
I have pretty much killed the shock absorbers so those will have to be replaced, I suppose.
The entire car was repainted in 2014 and it has no scratches or dents on it apart from the bumpers.
Roy.S is online now   Reply With Quote
Old 5th August 2017, 20:11   #34
greenhorn's Avatar
Thanked: 1,507 Times
Can't the rack be overhauled? Check with a mytvs near you
Old 27th March 2018, 12:06   #35
Thanked: 20 Times
Digging a old thread on overhaul/sprucing up.
I have a Honda Zxi (2006) which I have been using since 2014, it is about 88k kms now, I got it from my brother in law in 2014 and it was in poor state that time. Thereafter got the following things done:
1) Re-painting from 3M in Borivali
2) Serviced the car locally, mostly at a 6 month interval
3) Recently serviced the car in December through a local mechanic
Off late the car seems to be making funny sounds in the morning. Shades of rust have crept in at the edges and there seems to be a lag and lack of confidence while braking or revving seems prevalent.
To date I haven't taken the car to an authorised service station, but am now very eager to do a complete overhaul of sorts before the monsoons. The likes of TV shows - 'overhauling' and 'pimp my ride' have left a lasting impression on my mind.
Remember, I plan to keep this car as long as I can, therefore making sure it runs well, looks a stunner and me feeling extremely confident behind the wheels in top priority.
Do let me know an authorised station in Mumbai where I wont be fleeced for unwarranted repairs which most of the service stations do (by playing on the emotional psyche of a lay man)!
I hope to hear from you soon.
saildrive is offline   Reply With Quote
Old 30th March 2018, 13:07   #36
Tanmay K's Avatar
Thanked: 175 Times
Maybe get an engine compression test done from your mechanic to see if the results are within spec. 88k is not a lot for a Honda engine at all though, but still worth checking.
Tanmay K is offline   Reply With Quote
Old 30th March 2018, 14:10   #37
lamborghini's Avatar
Thanked: 1,592 Times
A lot of A.S.C. will fleece you by adding unnecessary items to the bill - you need to be careful of the same, and understand what is being done for what.
Alternately, Mumbai has a lot of reputed independent mechanics - check out the Team BHP Directory for some recommendations. Maybe show the car to one or two folks and get different quotes and their understanding of what could be wrong before going ahead with the one who's most logical and most comfortable to deal with.
lamborghini is offline   Reply With Quote
ARTICLE: Buying a New car with an Older manufacturing date ajmat On buying a car 164 17th May 2018 07:59
Do we want the Contessa Back? Can HM bring it like we want it? devarshi84 The Indian Car Scene 43 1st September 2011 17:44
Prerana Motor's LIES : Attempts to sell an older BS-III car rejoycjohn Indian Car Dealerships 33 25th July 2010 09:15
OHC Spruce'd up. EDIT: Pics added! Sprucegoose Modifications & Accessories 35 2nd September 2009 00:46
Look what Toyotas doing to spruce up the Camrys image!! GTO Int'l Motorsport 5 25th January 2006 17:21
