Old 6th August 2008, 16:30   #1
joecherian's Avatar
Thanked: 78 Times
Default Park your cars with wheels aligned straight?
Hi, I have a question regarding the way you park the cars.Will there be any effect on the steering system of the car ,(i mean the modern cars with all those fundu power steering stuff) in case I park my car with wheels aligned in any other direction other than being straight ?
joecherian is offline   Reply With Quote
Old 6th August 2008, 18:59   #2
nishantgandhi's Avatar
Thanked: 151 Times
Did not understand the question. Why should it have any effect on the power steering?
nishantgandhi is offline   Reply With Quote
Old 6th August 2008, 19:36   #3
vikram_d's Avatar
Thanked: 940 Times
There will be no effect on the power steering but a lot of other parts like drive shafts, ball joints etc will be under stress if the wheels are not straight.
Old 6th August 2008, 20:43   #4
Thanked: 245 Times
The "power" part of the vehicle "steering" disengages once you switch it off, whether electric or hydraulic actuated.
Old 6th August 2008, 22:29   #5
Thanked: 149 Times
Why? Mind elaborating??
I confess to using subterfuge to byepass the 20character rule. My only question is "why?". |-)
Old 6th August 2008, 22:36   #6
vikram_d's Avatar
Thanked: 940 Times
Ok. Let me see if I can explain this.
When you turn the steering, the steering column transfers that force onto the drive shaft and other related components to turn your wheels. So when you park with the wheels at an angle the steering parts exert an opposite force. Have you noticed how when you take a U Turn the steering tends to straighten out when you let go of yoru grip on it. This force is continously exerted on the steering column when you park with you wheels cross and not straight.
When the steering is straight there is no force being exerted on these parts. Therefore it is always ideal to park with your steering straight.
I could not explain it any better. Let me see if I can find something better to explain this.
vikram_d is offline   (1) Thanks Reply With Quote
Old 6th August 2008, 23:20   #7
vivekiny2k's Avatar
Thanked: 184 Times
no vikram, that force only comes in play when the car is moving. in a stationary car there is no counter steering force.
there is another thread on this. and the conclusion was it really doesn't matter.
vivekiny2k is offline   Reply With Quote
Old 7th August 2008, 02:31   #8
flipsyde's Avatar
Thanked: 62 Times
Vikram, what you say hold true only when the car is moving. And besides that is also because the torque supplied to both of the driven wheels are more or less the same while the inner wheel has to move a lot lesser while the outer wheel has to move more to complete the same circle. Hence the steering straightens out.
flipsyde is online now   Reply With Quote
Old 7th August 2008, 08:11   #9
mjothi's Avatar
Thanked: 216 Times
I was told to always park it with the wheels straight by a cab driver back in Chennai. Reason he said was, when you keep it turned, there is a small inclination in the front and so its not good. The weight will be on the center of the wheel and not on the tyres. As if you have a bent wheel. Did I explained it clear? I doubt.
mjothi is offline   Reply With Quote
Old 7th August 2008, 08:40   #10
Thanked: 253 Times
Originally Posted by mjothi View Post
... The weight will be on the center of the wheel and not on the tyres. As if you have a bent wheel. Did I explained it clear? I doubt.
That explanation does not make much sense.
In any case, I do not recommend learning these things from cab drivers, who are, in our country, by and large illiterate!
There are well qualified people on this forum who'd give valid answers to such queries.
anupmathur is online now   Reply With Quote
Old 7th August 2008, 08:45   #11
joecherian's Avatar
Thanked: 78 Times
I too got a similar info from one of the TATA authorised service centres (btb I have an Indigo) and what he told was that if you park your car with the front wheels at an angle, it do have an adverse effect on the steering system.He told some facts to prove his point but I was in no mood to listen as I was busy planning my drive down to Cochin that evening.Anyways, I think this needs more research and fact findings to conclude.
Old 7th August 2008, 08:55   #12
Thanked: 17 Times
I disagree sir! Even illiterate people (not all) can teach us a very important lesson or 2 in our life. Literacy can never match experiences. It's better if one is literate too.
I agree to this part. And the technical point of view on this matter can be explained well by the same. Where are they?
We've only had 2-3 technically correct responses here till now.
speedzak is offline   (1) Thanks Reply With Quote
Old 7th August 2008, 09:07   #13
bblost's Avatar
Thanked: 6,980 Times
In some countries for hilly roads there is a rule that the steering is kept in such a way that if the hand brake fails the car will hit the kerb and not roll down straight.
Am very sure this rule came in place after evaluating all the options.
Without power being supplied (as car is OFF) there should IMHO be no problem.
I prefer straight wheels in a level parking area because it looks good and also to cause lesser inconvenience to others. As the profile of the car is smoother.
Old 7th August 2008, 09:16   #14
Thanked: 712 Times
@ bblost:
It's discussed in this thread
http://www.team-bhp.com/forum/techni...k-incline.html (What is the correct way to park on an incline?)
sukiwa is offline   Reply With Quote
Old 7th August 2008, 09:51   #15
Thanked: 253 Times
I guess that the way I worded it did not come across right. I made reference to 'these things', meaning the more tecnically complex or specific matters, which require thorough knowledge of the design principles underlying the specific assembly.
I am an engineer, and short of saying "I don't THINK it will lead to a problem", I cannot give a detailed answer, as I am not specifically an automobile engineer.
And yes, there are many car related issues on which I seek the opinion of car mechanics or taxi drivers, illiterate as they might be.
Drink and drive? Go straight to JAIL! GTO Road Safety 167 3rd May 2018 18:24
A walk in the Park - Bannerghatta National Park Mad Max Travelogues 14 13th September 2013 21:58
Hi Guys.....straight to business. fretcraze Introduce yourself 5 17th May 2009 11:16
Narian Karthikeyan: Straight from the heart Mpower Int'l Motorsport 5 12th March 2007 22:07
BMW Unveils New Biturbo Petrol Straight Six Engine CaliforniaKnight The International Automotive Scene 6 28th February 2006 10:01
