Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 10th August 2008, 15:40   #16 (permalink)
rider60's Avatar
Originally Posted by merve_extreme View Post
Now generally the heater core is in front(towards the vent side) of the evaporator,so there is no way that changing the temperature setting is going to solve the problem of the evaporator freezing due to the malfunctioning expansion valve,changing the expansion valve is the only and proper solution.It will involve removing and refitting the AC piping and hence a refrigerant recharge.
well in that case i rather wait and see if this problem still persists and is equally bad all the time then i am left with no choice but to do what you suggested, let me get that part checked at the HASS tomorrow and get teh price quotes for the same, if this problem still gets to my nerve on the highway again i will change it and keep you guys posted thanks a ton merve.
rider60 is offline   Reply With Quote
Old 10th August 2008, 16:18   #17 (permalink)
tsk1979's Avatar
rider don't worry.
What exactly is happening is this
1. Your HVAC cools the cabin to chilled temp
2. Cutout detects this and shuts of the AC, and slowly Air coming from vents starts getting warmer than the ambient cold temperature of the cabin
3. Due to high humidity, you see mist. Its same has when you blow breath in winters
As for outside windows fogging, I also face this problem. I just decrease the cooling so that the temp difference between inside and outside is not much. If your cabin is very cold you will have misting outside due to condensation on cold glass
__________________
Reclaimed, wrung dry and recycled....!
Old 10th August 2008, 20:33   #18 (permalink)
scorpian's Avatar
EXpansion valve is malfunctioning,quite common problem,replacing it will solve your issues.
When the blower speed is reduced the expansion valve has to cut down on the liquid flow to the cooling coil,this is not happening in your case.Since you say u have recently serviced the HVAC,what normally happens is some debris must have got stuck in the expansion valve....
The best bet would be to replace it,make sure you pick the japanese ones if u plan to buy aftermarket .....
scorpian is offline   Reply With Quote
Old 10th August 2008, 23:00   #19 (permalink)
merve_extreme's Avatar
This can only happen in ventilation mode when outside air is warmer than the air inside the cabin,it will never happen in recirculation mode.
Rider, was the HVAC in ventilation mode? if yes then mist phenomenon could occur.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 11th August 2008, 01:50   #20 (permalink)
rider60's Avatar
well i always run my ac in ventilation mode only, its only when dad uses the car he puts it in recirculation mode.
rider don't worry.
ok tsk if this is the problem and not the valve then i am more than happy to hear it.
however this will be confirmed by next summer i guess or may be in this highway trip.
Old 17th September 2008, 01:40   #21 (permalink)
rider60's Avatar
well a update here, my woes are there, it forms the water droplets all around the blowers even now, this occurs only if the cold hot temp is in full cold mode, other wise its just fine. no problem with blower speed or the cooling they are both awesome.
i still ask the same question, this never occurred till the guy actually cleaned my evaporator by removing the dash board. did the guy at hyundai seriously mess with my valve settings???
also, the car is just 2yrs and 9months old and i already have a very squeaky alternator belt the sound shows the indication that its time that i changed it, has any one had this problem before???
does this have any thing to do with my ac or any other side effects in my accent viva crdi???
__________________
my new passion MY Torooo...
Old 17th September 2008, 02:13   #22 (permalink)
rider60's Avatar
well i forgot to add, the guy(technician at lakshmi hyundai banjara hills service center) at hyundai also said he was not sure if changing the valve would solve this issue for sure hence recommended i run the AC with mixing the hot a little and it has worked out so far, thats the reason for serioulsy wondering if they messed up my valve settings previously.
i just clue less as to what would happen if i get this checked else where, i am kind of scared if they mess up something it might cost me dearly to pay up for any of those parts.
so what do i do guys? gurus?
__________________
Old 17th September 2008, 08:07   #23 (permalink)
Rider, stop worrying. Your AC is now performing to optimum levels (after the service).
Why did it never happen for the first two years? Because the AC in the brand new car was probably not charged fully with refrigerant.
If you keep running the AC in ventilation mode, the evaporator will get fouled up faster. Better to be in recirculation mode. That is also more eco-friendly.
anupmathur is online now   Reply With Quote
Old 17th September 2008, 08:10   #24 (permalink)
akshay4587's Avatar
I have been noticing this mist in my Bolero since years now,happens pretty often.
Recently happened in the accent as well but for a few minutes then it was normal.
It is related to humidity only
__________________
1997 Gypsy MG410W(Sold)
2001 Bolero GLX
1983 Premier Padmini DX
1978 RE STD 350
1999 RE Machismo 350
2005 Zma 225
2006 Accent GLE
akshay4587 is online now   Reply With Quote
Thread Tools
fit an air con(AC) in maruti 800 navdeep Technical Stuff 55 22nd September 2009 15:54
OHC Idling Problem - Air-Con Related KSM-Vtec Technical Stuff 24 13th July 2009 20:56
Chevy Spark @ 2.89 lacs. With air-con! Now 2.66 GTO The Indian Car Scene 167 15th August 2008 02:21
Air-Con for 1987 Premier Padmini? newcoolgadgets Technical Stuff 7 14th March 2007 20:13
Air Con making noise!! Shan2nu Technical Stuff 20 21st April 2005 19:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
