Old 4th December 2011, 22:26   #31
Sprucegoose's Avatar
Thanked: 38 Times
Default Re: Air-con woes and Nightmare!
Quite common. I guess there may be two reasons - there are more vents on the drivers side, and also possibly the drivers side is a bit warmer due to his/her presence.
On a humorous note one may blame it on Murphy - the LH side needs one moves across to wipe it.
I had a similar problem, with only the left side front window getting misty with the AC on. I realised, most of my friends who sit in the passenger seat, tend to move the vents towards the window so as to not blow the cold air straight onto their body. I just point the vents in and downwards and the problem gets solved.
Sprucegoose is offline   Reply With Quote
Old 5th December 2011, 12:17   #32
vigsom's Avatar
Thanked: 582 Times
@YVES since the leak is in the high pressure side(drier area) which sees approx 250-300psig pressure, I don't think araldite will work.
could you post a pic so that we can see if something can work?
Aluminium welding is possible but that used to be done on old cars' which had aluminium coils +fins ; not on the latest ones which have cast units
Air Con making noise!! Shan2nu Technical Stuff 29 25th September 2015 04:30
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
Double air-con for the Innova? EDIT : Pics uploaded GTO Technical Stuff 28 8th October 2013 00:59
Updated Mahindra Thar in 2-3 months. EDIT : Launched with Air-Con and immobilizer! shireeshjacobs 4x4 Vehicles 350 13th May 2013 16:24
Air-Con for 1987 Premier Padmini? newcoolgadgets Technical Stuff 7 14th March 2007 19:13
