Old 16th November 2013, 19:40   #31
Thanked: 124 Times
Default Re: 10 Engine Idling "did you knows" EDIT: Myths & Facts added!
Originally Posted by amit View Post
1. In winter conditions, emissions from an idling vehicle are more than double the normal level immediately after a cold start.
Does anyone know why? I mean, cold start means closely packed oxygen molecules per intake charge = better combustion right? Could anyone throw light on this?
vvijay is offline   Reply With Quote
Old 16th November 2013, 20:05   #32
Thanked: 152 Times
I think the reason is all engines has an optimal operating temperature and in winter while just idling it takes a long time to get into optimum temperature, also it has to be noted that in Canada winter mean sub zero temperatures
B747 is offline   Reply With Quote
Old 16th November 2013, 20:38   #33
Thanked: 14,603 Times
Since the engine block, all parts are cold.. the environment also being cool/cold the warm up time needed is longer so the idling circuit makes the Air-Fuel mixture richer to maintain the RPM and heat the engine. This takes up energy and time so the combustion is not complete as when the engine is warmed up.
This is the reason for more emissions during cold start.
Anurag.
a4anurag is online now   (2) Thanks Reply With Quote
Facts or Myths....Expose the truth sforsarang Technical Stuff 20 15th April 2015 09:24
Throw out everything you thought you knew about tyres. Auto Bild India knows best Nikhilb2008 Tyre & Alloy wheel Section 28 19th June 2009 19:26
Diesel: Facts or Myths akash_m The Indian Car Scene 6 18th November 2008 12:49
Diesel Cars - Myths or facts etrast75 Sedans 1 12th May 2008 14:27
