Old 11th August 2008, 17:52   #1
Default yellow light on in zen
Hi all, was driving down to whitefield ad after a couple of bumps near ulsoor lake the speedometer stopped working and the yellow engine light came on. What i need to know is that is this common and will the light disappear on fitting a new speedo cable?
manek is offline   Reply With Quote
Old 11th August 2008, 20:24   #2
The yellow light is the check engine light.I feel there is a fuse blow out and not a cable problem.
D.V.R is offline   Reply With Quote
Old 11th August 2008, 23:03   #3
manikjeet's Avatar
Thanked: 110 Times
it happened with my zen few weeks back
my speedo cable got disconnected and engine light came up
it when away after i connected the cable back and soft reset the ecu
manikjeet is offline   Reply With Quote
Old 12th August 2008, 00:22   #4
rohan_fonseca's Avatar
Cable issue. The speed sensor is throwing an error.
rohan_fonseca is offline   Reply With Quote
Old 12th August 2008, 08:09   #5
dude just check out the oil pump...same thing happened to my zen also it was the oil pump which got daamaged which pumps the oil.....
zenopio is offline   Reply With Quote
Old 8th January 2009, 09:48   #6
skyliner34's Avatar
Thanked: 63 Times
it would be a safe bet to visit any Maruthi service station.
you never know what the actual problem might be...
skyliner34 is offline   Reply With Quote
10 year old baby gets new jewellery!- My Zen and it's new white LED cabin light. abhipuru16 Modifications & Accessories 16 5th July 2010 03:35
Maruti Zen- Current divided between head light and left side indicator abhipuru16 Technical Stuff 5 10th April 2010 17:08
2002 Zen - Engine light on!!! alias Technical Stuff 16 29th October 2008 17:42
New SLK Mango Yellow Dippy Super-Cars & Imports in India 24 20th April 2005 08:51
Screaming YELLOW Porsche!! GTO The International Automotive Scene 6 22nd April 2004 04:03
