Old 14th August 2008, 10:49   #1
joecherian's Avatar
Thanked: 78 Times
Default anti-stall setting . what is this ?
My Indigo user manual tells that you should have the engine tuned , particulary for antistall setting. Any idea what this is and how it can be done ?
joecherian is offline   Reply With Quote
Old 14th August 2008, 19:53   #2
Thanked: 660 Times
I guess its the ideal idle rpm of engine.
Old 14th August 2008, 22:38   #3
rider60's Avatar
Thanked: 47 Times
more info on the year and model of the vehicle would let us help you better, if the version one indigo petrol i am guessing these came with a 32 bit processor and think they have idling setting so that the engine wont stall!
can you post a picture of the manual which says this?
not sure of the diesel though any body any info on the same?
rider60 is offline   Reply With Quote
Old 14th August 2008, 23:41   #4
joecherian's Avatar
Thanked: 78 Times
Mine is a 2003 model Indigo LS .The manual, I had downloaded from web recently.
Old 14th August 2008, 23:44   #5
rranjith_kum's Avatar
Thanked: 17 Times
AFAIK there is a setting to set the closing movement of the throttle valve therefore to set the idle rpm of the engine. This got to be meddling with that and I guess they may set it faintly higher in due course of time I guess so that the engine is not let to speeds below due to which it STALLS !!
rranjith_kum is offline   Reply With Quote
Old 15th August 2008, 00:41   #6
.anshuman's Avatar
Thanked: 9,160 Times
AFAIK 2003 LS,Yours is a non intercooled diesel without the electronic fuel pump,you must be talking about idle speed setting which can be manually done easily in previous versions of indigo and indica.
Old 15th August 2008, 01:46   #7
DirtyDan's Avatar
Thanked: 776 Times
Default Under load and off again
I believe you have an ecu and sensors which change your idle depending on whether your engine is under a load or not. Under a load means, lights, a/c, in gear or out etc. You may well hear your engine increase its rpms under load and then decrease when the load lessens. The hardware and software to accomplish this constitutes your anti-stall system.
With time road and engine vibration, heat, cold, corrossion and who knows what else can make wires, sensors and ecu go bad. The software may need to be updated as well if there is a newer, better version. So, Tata says get them checked once in awhile. It's a smart thing to do.
TVS Wego - Engine stall & Starting problem rkirana Motorbikes 18 31st January 2014 20:19
Learning to drive: When does a car stall ? kalpeshc Technical Stuff 12 6th March 2007 23:24
Anti honda?? Anti suzi?? Anti fiat?? Anti ford etc etc?? Vent out ur opinions here!!! mclaren1885 Shifting gears 3 29th June 2006 14:23
