Old 14th March 2005, 10:10   #1
Default Zen's ac not functioning...!
This morning while approaching to office, my zens ac did not operate. I pushed the button but it failed to start, only the blower was functioning. Any idea what that could be ? Some fuse ?? or ??
Thx a lot,
Tarun
Tarun is offline   Reply With Quote
Old 14th March 2005, 10:47   #2
iceman91's Avatar
Thanked: 22 Times
could be the fuse or could also be that the gas has leaked out.
iceman91 is offline   Reply With Quote
Old 14th March 2005, 10:56   #3
Rtech's Avatar
Thanked: 217 Times
Could also be the dashboard AC switch itself. Dunno if the Zen's have that problem, but the Uno definitely did.
You need to be a bit more specific. Did the compressor come on at all, but was just not cooling? Then as iceman said, its probably low on gas.
If the compressor did not come on at all, you need to check the fuse first, then check out the switch. Cross your fingers and hope its not your compressor that's broken though!
Old 14th March 2005, 11:14   #4
Thx Rtech, Iceman
Nope. The compressor did not come at all. The car had been serviced just 800 kms back and i specifically asked the Pasco (dealer) guys to functioning of ac.
Till friday it was working and suddenly no life in it at all.
In worst scenario : How much would the compressor cost ??
Tarun
Old 14th March 2005, 13:10   #5
Jaggu's Avatar
Thanked: 7,664 Times
check gas pressure, and also the compressor fuse.. bypass the pressure switch using a wire to confirm its low gas pressure
dont worry about worst case scenario, chances are very less, still it will cost around 15k max for OE zen compressor
Honda Accord 2001 - Electric Seat not functioning kiran1103 Technical Stuff 3 11th January 2011 21:19
Non functioning signals and other hazards!! Gordon Street Experiences 11 19th March 2008 11:20
Non-functioning speedo and Tacho Deeps Technical Stuff 1 3rd October 2005 12:10
E-Zen & B-Zen.... MustangMan The Indian Car Scene 3 2nd July 2005 21:27
Understanding the engine functioning from scratch sakeeboy Technical Stuff 0 13th January 2005 18:05
