Old 14th March 2005, 10:47   #1
SCH
Default MATIZ - Silencer noise
I have a Matiz SD Dec 99 model ; hav clocked 68000 km. it is in immaculate condition. Of late I have started experiencing some VROOOM noise on acceleration and also the noise now is more if parked stationary with Engine ON, compared to earlier times. Is it due to the silencer chipped at some place or due to carbon deposits in the silencer. Pls. advice
SCH is offline   Reply With Quote
Old 14th March 2005, 19:01   #2
puthari's Avatar
Hi , I have a Matiz - use it as my second car .It has clicked 1.7L. I did have the same issue - It appeared that the Silencer had a leak . I remember that the silencer comes in 2 parts . I replaced them and find no problems at all .
puthari is offline   Reply With Quote
Old 14th March 2005, 20:14   #3
Rudra Sen's Avatar
Thanked: 4,288 Times
Carbon deposits in silencer will make your car smoother in terms of noise. Must be a some small leak or crack. Considering the age, I think it's normal.
Old 14th March 2005, 21:14   #4
drifter's Avatar
99 model...that makes your car around 5 years old...its normal for a silencer to have leaks...and more so if you live near the sea. The salty air accelerates the corrosion process. Get the exhaust system checked....and replace the necessary parts...this should solve your problems.
Drifter
drifter is offline   Reply With Quote
Old 14th March 2005, 22:05   #5
khanak's Avatar
Thanked: 130 Times
same thing happened to my 2000 Santro a few years ago
got it changed
they put a repaired one instead of a new one
if you have the dough and wanted to do it sometime now is the perfect time to put in your performance exhaust
khanak is offline   Reply With Quote
Old 15th March 2005, 11:10   #6
SCH
Got the silencer inspected; there was a leak / small crack, welding wouls solve the problem.
Thanks for all the input.
Old 15th March 2005, 12:29   #7
puthari's Avatar
I suggest you get it replaced . I got it welded - but it could not hold . the hassle to run to the mechanic will be prevented.
Old 23rd March 2005, 00:32   #8
Revvmaster's Avatar
Thanked: 45 Times
Dear SCH
Having been a Matiz owner for 5 years until last month, one thing is for sure, the exhaust system on a Matiz is prone to rust and a crack in the silencer does occur once in a 18-24 months on an average. I did face this problem 3 times, solved it once by welding it, but it lasted for no more than 4 months.
Take it as you see it, it is a recurring problem. See for how long it lasts, once the weld gives away, just change the last three sections.
Revv
Revvmaster is offline   Reply With Quote
Silencer Noise!! need urgent help amit_mechengg Technical Stuff 9 26th May 2008 16:49
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Problem with Matiz silencer/muffler yeggina Technical Stuff 5 29th July 2007 07:08
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
