Old 18th September 2010, 17:15   #46
aargee's Avatar
Thanked: 2,109 Times
I would strongly vouch for WD40 as I'm seeing its use everyday & it washes almost everything to perfect. If you were unable to get WD40, you may try one of its alternatives, Zorrik from Pidilite industries. Its a good one too. Costs about 55 Rs for 85 ml.
Old 18th September 2010, 17:20   #47
Thanked: 16 Times
Hyderabad BHPian's
Any idea where we can get this product in Hyd? WD40
Will Miniser Road be a good place to try.
BheemBoy is offline   Reply With Quote
Old 18th September 2010, 17:51   #48
Thanked: 244 Times
You can also try a product targeting Tar & Oil. IFTEX System Tar & Oil Remover. Its from the manufacturer of System G/D.
IFTEX System Tar & Oil Remover IFTEX System Tar & Oil Remover greatly enhances the appearance of the vehicle by making it free of tar, asphalt, undercoating, road oil and dirt. Because of the high quality additive package, IFTEX System Tar & Oil Remover removes the foreign matter without having any effect on vehicle paint..
Check with them on its availability and where to purchase.
Old 18th September 2010, 21:21   #49
msaudf's Avatar
Thanked: 146 Times
a visit to the car wash will do. they will soak the body with a nice coat of diesel and you can see the tar droplets giving away and flowing down.
cost involved Rs.300 - 400
msaudf is offline   Reply With Quote
Old 19th September 2010, 12:06   #50
PM - B's Avatar
Thanked: 277 Times
Have noticed that when you go to a ***, they use "soap oil" to clean the cars that come in for servicing.
I will try and get details on the same and an image of the container next time i go there. This most probably will clean all stubborn dirt.
PM - B is offline   Reply With Quote
Old 24th November 2010, 12:51   #51
soap oil does not remove tar, best option diesel. i buy soap oil in 10 ltr cans for my punto and TBTS. cleans great, good shine but does not remove tar.
Abhi
Abhi2902 is offline   Reply With Quote
Old 24th November 2010, 13:21   #52
goandude's Avatar
Thanked: 437 Times
Abhi
"soap oil" seems like an oxymoron to me. what is it?
goandude is offline   Reply With Quote
Old 24th November 2010, 14:32   #53
shazikon's Avatar
Thanked: 19 Times
I have used Meguair's Bug and tar remover. It works really well in removing hardned tar on paint.
shazikon is offline   Reply With Quote
Old 24th November 2010, 15:22   #54
OHCVtec's Avatar
Thanked: 12 Times
By brother's White Merc had the same issue with tar all over his car, took it to the local washing fellow, he said he will spray it with diesel, keep it in sun for a couple of hours, till then the tar will loosen and then a good shampoo wash after that will do the trick.
OHCVtec is offline   Reply With Quote
Old 24th November 2010, 15:50   #55
fine69's Avatar
Thanked: 859 Times
Has anybody used this product? Unlike other alternatives it seems to be targetting exactly what we want - Tar removal; on top of that it claims to be paint friendly.
I tried the Contact Us link on their website but it doesn't work. I've filled up their Enquiry form but not certain if it would be answered.
Till date I've only used diesel with Amway's Car Wash (silicone based) for tar spot removal. It does work but as everybody must've experienced, needs lot of patience. At times it seems so funny that at first I wash the surface with car wash, then comes diesel to remove tar spots, then comes car wash to wipe off diesel, then my hands (drenched in diesel) to be washed with soap, too much washing!!!
If anybody has any information on where to procure this from please let me know, thanks.
fine69 is offline   Reply With Quote
Old 24th November 2010, 17:28   #56
Thanked: 56 Times
WD 40 does the job well and a small containeer is also available in ~ Rs 90.
It was sufficient to clean tar off the windshield, bonnet, front fenders , front bumber and side view mirrors (of Civic) and it was easy to use.
Although I read it does not affect the paint as a precaution I washed it off and that requires efforts (not sure how differently but may be similar to washing off diesel). I had to as the remains were all over the windshield and I presumed driving would not have been safer..
alto99 is offline   Reply With Quote
Old 24th November 2010, 22:09   #57
SAS
SAS's Avatar
Thanked: 60 Times
IMHO, I have used diesel. It requires a couple minutes to soak and then it's a simple wipe-off, even for the worst tar patches around the footboards and underbody below the tires. I use clean cotton waste dipped in diesel and then gently rubbing it over the tar spots first, then a wipe-off with another clean cotton waste piece again dipped in diesel. You then need to wash your car with a shampoo and then wax it to replinish the wax layer. The shampoo needs to be more concentrated than normal in order to wash off the oil.
It's the cheapest and most effective way to get tar off.
SAS is offline   Reply With Quote
Old 25th November 2010, 07:32   #58
Thanked: 36 Times
I use Amway Car Wash and have diesel with me. Car Wash is to be used as half cap in 8 litres of water. How much diesel do I add to this solution to wash the car?
abhipuru16 is offline   Reply With Quote
Old 25th November 2010, 07:51   #59
rk_sans's Avatar
Thanked: 602 Times
@abhipuru16,
Wait, do not add diesel to that solution.
As mentioned by others or recently by @sas, just use cotton waste to dip in diesel and clean the places where there is tar. Then give your car a regular car wash.
rk_sans is offline   Reply With Quote
Old 25th November 2010, 08:09   #60
swiftnfurious's Avatar
Thanked: 6,422 Times
Originally Posted by Ricky_63 View Post
I have used kerosene to remove tar from the running board of my car. Works instantly, no problem ever.
Originally Posted by Rotorhead View Post
Kerosene should help you in removing the tar. in fact the road laying guys either use diesel or kerosene to remove tar residues stuck to their hands i guess.
Originally Posted by quicksilver View Post
Have to add one more thing... both Kerosene and Diesel are dust-magnets and are hard to wash off because of their oily nature. You may have to wipe the panel multiple times with a damp cloth to remove the traces. This is probably where the car shampoo part helps.
+ 1 to this. I have used Kerosene, worked really well but I prefer using diesel. One issue is that you will need to wash your car really well after this as the oil sticks on. May be multiple car washes with shampoo should do the trick. This is how I removed the excess oil.
This is an expensive option.
Originally Posted by rk_sans View Post
@abhipuru16,
+1 . Just use a piece of cloth / cotton and rub the area softly. Then immediately wash it off.
swiftnfurious is offline   Reply With Quote
DIY: How to remove Black Spots (Tar) from your car nettooran DIY - Do it yourself 40 18th July 2015 19:31
Finally, a coat of tar for the Inner Ring Road (Bangalore) mooza Street Experiences 10 11th May 2010 19:08
How to remove unwanted paint? Boom Shiva Technical Stuff 17 7th January 2010 12:53
Govt. to remove income tax exemptions and deductions. Please comment against it..... satish_appasani Shifting gears 15 15th May 2007 21:13
Why didn't the marshals help, remove the Renault? Shan2nu Int'l Motorsport 14 17th September 2004 00:52
