Old 18th August 2008, 13:39   #1
Thanked: 11 Times
Default Petrol smell when starting Ikon Flair
I have 2005 model Ikon flair which has done 30K. Recently I noticed that while starting the car in morning, I can smell petrol in the cabin. It will fade off after some time. Checked with Lathangi Ford and they are not able to identify the issue. They checked all pipes for leakage and found nothing.
Can some one faced similar issue?
Recently went to Lathangi for 30K service and they didn't replaced the air filter. Reason given is that they will remove only if the vehicle has covered 20K between services. I asked them to change and the filter was clogged with dust. Fuel filter changed, engine oil replaced with synthetic Oil, AC filter changed and the total service cost comes to 8K.
shalini_g is offline   Reply With Quote
Ford Ikon 1.6 issue - Burning Smell After turning on AC Sugeeta Technical Stuff 12 10th February 2015 23:56
Bad smell after starting the car (NHC-2004) anandpadhye Technical Stuff 35 23rd August 2007 10:50
Ford Ikon Flair or Palio 1.9D ELX? neverclever Hatchbacks 12 16th April 2006 01:04
can i fit 14 inch tyre on my ikon flair 175/70 r13 ravi Tyre & Alloy wheel Section 1 29th October 2004 10:33
Ikon Flair The X Factor Sedans 17 11th October 2004 13:38
