Old 10th July 2009, 13:24   #46
gpa
gpa's Avatar
Thanked: 282 Times
Mithun,
A great source of info from the link. Thanks.
Cheers,
gpa
Old 10th July 2009, 14:04   #47
Gansan's Avatar
Thanked: 914 Times
While negotiating extended stretches of slow moving traffic, I switch the A/C off in my Alto but leave the blower on in fresh air mode. Then switch the A/C on in recirculation mode once I pick up speed. With short stretches of slow moving traffic, I just leave it on. I don't use the "booster" effect on the highway either because 80 KM being the speed I am most comfortable at right now, there is hardly any oppurtunity to overtake!
But I doubt switching on and off every now and then will harm the compressor. May be it will wear out the push button fast!
Old 10th July 2009, 16:47   #48
gpa
gpa's Avatar
Thanked: 282 Times
Gansan,
Don't switch on the compressor on and off repeatedly. It will lead to premature failure of the compressor. The compressor requires a huge amount of power each time its starts up and will wear out prematurely if switched on and off frequently.
This will also affect your FE as the compressor will have to start up and cool warm air again rather than if it were already switched on and running.
Cheers,
gpa
Old 10th July 2009, 17:07   #49
ghpk's Avatar
Thanked: 193 Times
Originally Posted by gpa View Post
Gansan,
Cheers,
gpa
Few post back many of members already said, new modern CAR A.C. will not easily go Bad with frequent ON/OFF.
For myself, I keep AC running continuously on my Santro, and i feel following things.
When running AC with Blower speed 1 or 2 (Rotary switch) it trips quite frequently once the car is Cool, while on Full speed Air-flow, it takes a lot of time before it trips.
It consume a lot of Fuel when AC is on while car is parked somewhere.
In cars with Electronic Climate control, take their own sensor temperature and then maintains the desired temp. no matter whether it Trips or SLOWS down the cooling air flow.
Also car where Thermostat is Dirty, (less sensitive) due to excessive dust will NOT TRIP accurately. this is one of the neglected things on CAR AC.
Old 11th July 2009, 07:39   #50
Gansan's Avatar
Thanked: 914 Times
Gansan,
Cheers,
gpa
I was offering an opinion on another query, I don't have to switch on/off that frequently. I encounter extended slow moving traffic very rarely on my route.
Old 12th July 2009, 16:04   #51
gpa
gpa's Avatar
Thanked: 282 Times
When you have switched on the a/c the compressor will switch on and off intermittently as per the need to maintain the desired cabin temperature. Manually switching on and off (pressing the compressor switch) is what will lead to wear in the system.
Recently, during a free check-up camp organized by my local M.A.S.S, the a/c mechanic mentioned this to a customer who asked him if he could save fuel by manually switching off the compressor ever so often.
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
Swift (Running-in) Query abhi1881 Technical Stuff 11 2nd August 2005 09:45
Longest running model names Aditya The International Automotive Scene 16 29th May 2004 04:25
Mercedes India running BioDiesel Tests GTO The Indian Car Scene 1 21st April 2004 23:46
