Old 19th April 2017, 20:40   #106
glenmz's Avatar
Thanked: 267 Times
Default Re: Battery / Alternator / Voltage Regulator problem?
Originally Posted by vigsom View Post
Does the flickering occur when the engine is off?
If the problem is seen only when the engine is on , it has to be the alternator.
An easy way to check would be to hook up a multimeter to the battery and see if the voltage fluctuates when the car is at idle. If the engine is raced and the flickering stops , then please have your alternator serviced.
You could just check all connections/main fuses , especially the main wiring coupler at the alternator.
An update on this. I had driven home last week. While driving at Cochin, I suddenly lost the power steering assistance and the battery sign lit up on the dash. Luckily I was at the vicinity of the service center. The issue was with the alternator pulley. The dampener pulley was changed along. The SA thinks that the flickering would be a related symptom.
glenmz is online now   Reply With Quote
Old 18th July 2017, 16:50   #107
Thanked: 561 Times
cross-posting for reference of colleagues: Link (Mahindra Xylo E8 (ABS):-Spacious, Feature-Packed, 8-Seater, Head-Turner Beast is Here) : Xylo voltage regulator - repaired & replaced !
pcpranav is offline   Reply With Quote
Old 19th October 2017, 16:56   #108
techiecal's Avatar
Thanked: 62 Times
Hi Folks,
Lately I have noticed that although my Alto LXi runs fine in daytime. No starting problem, good horn sound, etc. , during night when I switch on the lights, there is a whining sound from the alternator and for slightly longer distances some heat fumes are coming from the bonnet. The alternator is too hot to touch. Have checked the battery-no problem there. Voltages during idling and off is within limits also. Any insights? Could the alternator be failing even though it generating correct voltages.
techiecal is offline   Reply With Quote
Old 20th October 2017, 10:23   #109
Thanked: 379 Times
Originally Posted by techiecal View Post
Hi Folks,
Check the Alternator belt. Some workshops intentionally tighten the alternator belt to get future repairs, you may wish to check this as well.
jinojohnt is offline   Reply With Quote
D.I.Y. Weekend Project: Car Battery Voltage Monitor ghpk DIY - Do it yourself 2 26th May 2015 12:50
Battery / Alternator problem in Ambassador Diesel adrian Technical Stuff 5 11th December 2009 14:25
Alternator Dependency: Will a vehicle run with the battery disconnected? anupmathur Technical Stuff 252 30th June 2009 14:13
Tata Indica alternator voltage query tsk1979 Technical Stuff 5 9th December 2006 12:45
