Closed Thread
Old 15th March 2005, 14:14   #1
Default help needed in basics of driving
Dear guys.
I have used Automatic cars all my life and moved over to india recently.
I learnt manual shift easily but still drive with my left foot just touching the clutch pedal and whenever i brake, i press the clutch.
I am simply scared to rest my left my left foot in the dead pedal.
most of the time, my left leg is sore because of this.
My driver brakes all the time without pressing the clutch and he uses theclutch onlt to shift gears.
How do I do this?
How do experienced drivers like BHP ians do?
please teach me
Raj
v_s_natarajan is offline
Old 15th March 2005, 14:24   #2
Harrie's Avatar
Thanked: 25 Times
well i use engine braking. as and when i brake i simultaneously go down a gear or two.
take the car to some ground or a deserted road where there is no one around and try practising applying the brakes alone. as you feel the car is about to stall press the clutch and if needed go down a gear. once you get the feel of it it'll be ok.
Harrie is offline
Old 15th March 2005, 16:22   #3
speedsatya's Avatar
Thanked: 712 Times
riding the clutch can be dangerous .its also bad for your engine.
its really difficult to suddenly change your style of driving,but with time you will learn it.
use the clutch only to change gears or when u r starting from standstill.
speedsatya is offline
Old 15th March 2005, 16:34   #4
Shan2nu's Avatar
Thanked: 89 Times
Why didn't you choose the A/T option, in India too? That would have solved the whole problem.
With the kinda traffic we have here, you'll need to make more gear shifts in a day than what Schumi makes, during a whole race weekend. LOL
Shan2nu
Shan2nu is offline
Old 16th March 2005, 01:49   #5
Rehaan's Avatar
Thanked: 25,043 Times
Hi V_S_Natrajan,
There is a lot of material on TBHP aldready discussing this topic in one aspect or another. Check out these threads>
1. The best way to use the clutch & brakes (The best way to use the clutch, gear and brakes)
2. How to change gears
3. What is double clutching (Whats double clutching & whats the reason to use it)
4. First or second gear (First gear or Second)
5. 4-5 gear query
Read em and then post some more follow up questions!
cya
R
Rehaan is offline
Old 31st May 2010, 22:46   #6
rahul153's Avatar
Thanked: 19 Times
Originally Posted by v_s_natarajan View Post
Dear guys.
How do I do this?
please teach me
Raj
The Whole idea is, use clutch + Brake when driving at very low speeds, tis is to prevent knocking and engine being shutdown
otherwise, use brake, new cars can even run in 5th gear at speeds as low as 10 though not advisable to do that
use just brake and no clutch to control the speed to a manageable level,
if u feel u may need to slow down to halt, use clutch too otherwise just shift to appropriate gear.
Pls do feel free to correct me if am wrong
rahul153 is offline
Old 1st June 2010, 04:50   #7
aargee's Avatar
Thanked: 2,143 Times
Boy you replied to a 5 year old thread; By now, Raj would been driving in tracks!!!
aargee is offline
Old 1st June 2010, 07:38   #8
MileCruncher's Avatar
Thanked: 357 Times
LOL So True!
Anyways this is a problem that many drivers suffer from. Even my wife used to press the clutch while braking irrespective of the speed. And because thats what the driving school guys taught her. Only after continuously telling about the proper braking technique has she been able to get over that habit.
The thumb rule is apply only brake if you don't need to downshift. The moment the speed reduces to something lower than what that gear can handle without knocking, press clutch and downshift.
P.S: Pressing clutch while braking can be really dangerous while driving in the hills or on wet road as the wheels get disconnected from the drive train and lose any kind of traction.
MileCruncher is offline
Old 1st June 2010, 13:52   #9
Rehaan's Avatar
Please see the existing threads on this topic linked above.
Thread closed.
R
PS - Here are some more, thanks to condor :
http://www.team-bhp.com/forum/techni...step-step.html (Car driving lessons step by step)
http://www.team-bhp.com/forum/shifti...n-driving.html (learn driving)
http://www.team-bhp.com/forum/techni...tch-usage.html (learning to drive, need some advice about proper clutch usage)
http://www.team-bhp.com/forum/indian...t-driving.html
Rehaan is offline
Closed Thread
Home Audio basics! Elito11 Gadgets, Computers & Software 74 1st January 2016 14:43
Road Tax Basics easyrider Indian Car Loans & Insurance 42 7th August 2015 22:13
Are these basics correct OR am i being taken for a 'ride' ? kalpeshc Technical Stuff 12 11th February 2007 02:23
Back to Basics : Solid or Metallic Colors Hackett Technical Stuff 6 11th September 2005 17:18
Back to Basics: How does a free flow work? aalaap Technical Stuff 4 7th November 2004 03:33
