Closed Thread
Old 12th September 2008, 21:43   #31
ibm_jennifer's Avatar
Thanked: 7 Times
Believe me or not, MY car is one of the best maintained safari as I used to change the engine oil in 3-4k interval and it never run without any additives. (I am the stupid who tested the efficiancies of the additives like IFTEX, Automax, MP6TY etc..) I have flushed the fuel system 2 times in the last 4 months. One with IFTEX and now with OWS 360.
And none of the additives removed the carbon deposits from my fuel injectors. If you are in chennai, I welcome you come the workshop to see my car. (it will be there 2 more days).
And regarding the Engine Flush OWS, it worked well. But believe me or not, NO ADDITIVES or Diesel or even ACIDs can remove the carbon 100% - we used two 18v Bosch drilling machines to clean the carbons!!!! But now I am wondering, how SYNTHETIC Oils will do its job 100%, if your oil bump, sump & strainer are like mine(after a Engine flush) - believe me or not I used new 15w40 Oil just for flushing - that means oil change just before the flush!!!!)!
ibm_jennifer is offline
Old 13th September 2008, 20:55   #32
Thanked: 7 Times
Here are some updates from today's works:
Cleaning the catalytic converter:
The Engine Pulleys after the cleaning:
The camshaft caps after cleaning:
Catalytic converter after Cleaning:
Old 15th September 2008, 23:16   #33
Thanked: 7 Times
Here are the updates from today's works:
The Valves after cleaning:
Lapping the valves:
Valves after Lapping:
Engine Guard afer SoundProof rubberized Paint:
Hood is ready for rubberized Paint coating:
Old 16th September 2008, 11:59   #34
esteem_lover's Avatar
Thanked: 451 Times
That is some overhaul ibm. Hope to see your safari sometime. Where did you get all this done ?
esteem_lover is offline
Old 16th September 2008, 15:09   #35
Thanked: 7 Times
No, this is not overhaul as my Engine is in perfect condition(only 60k done so far). Its De-Carbonization and I am paying only Rs. 5000 for the entire job including oil. I am doing it in my friends workshop.
Old 18th September 2008, 00:09   #36
Thanked: 7 Times
Thanks for your fine(!!!) responses to my efforts. Anyway here are the updates from today's works:
Pressure Washing the Engine:
Cutting Oiling the Engine:
Engine after Cleaning:
Inside the Oil pump:
Oil Pump after Cleaning:
Thermostat Valve Testing:
The TURBO Charger:
Surfacing the TURBO lets:
Hi-Temperature(1500c) Paint Coating the TURBO Charger:
Old 18th September 2008, 09:11   #37
Thanked: 245 Times
I would say a very very professionally executed cleanup by your friend. Please post his contact details at the end for everyone to take advantage of his expertise and meticulate execution. Worth every penny spent.
Also is it possible to post pictures of the injectors, the fuel additives work mostly on the injectors and would want to see their condition too.
dadu is offline
Old 18th September 2008, 09:23   #38
akshay4587's Avatar
Thanked: 1,686 Times
Whoa thats some serious cleaning
wonder if it going to perform better than new now
akshay4587 is offline
Old 18th September 2008, 12:14   #39
Thanked: 18 Times
@ibm_jennifer,
Superb work done and thanks for the excellent photos you have posted. My GTX has done 65K kms and want to go for Fuel Injection System Cleaning, Throttle body cleaning and Engine Decarbonization. This service is offered in concorde motors bangalore, Anybody has done such work so far for a Palio 1.6?
Also want to know If I need to go for soft decarbonization/Hard decarbonization of the Engine, what is the difference and how effective it is to improve the performance?
The URL which talks about Decarb Services offered by tata motors is below.
Tata Motors Customer Care :: Decarbonising & Engine Flush
Am planning to leave the vehicle for service tomorrow and get these works done their. Any suggestions/ideas would be of great help for me
ravikn is offline
Old 18th September 2008, 16:42   #40
Thanked: 7 Times
No, never go to Authorized workshops to do decarb. I have inquired to Concord about decarb works. They didnt even open the engine head. They just spray Bardhal S1 & S2 into the fuel system and run the car for 50 kms. Its 99% useless.
If your car is under warranty, you dont need to do any decarb. If your car is old, find a mechanic and ask him to do a Manual Decarb. If you are in Chennai, I will help you to do the decarb in my friends workshop.
Today we are going to fit the engine. (The delay is because we couldnt source a Metal Gasket(like SUMO Victa) for Safari Engine for 2 days in Chennai). I will update the pictures tomorrow.
Dont go to TASS for a Decarb work, Just try OWS 310 & 260. They may work.
Old 18th September 2008, 23:58   #41
toiingg's Avatar
Thanked: 85 Times
Thanks for the brilliant pics. Truly an eye-opener.
Just a few days ago i added Nulon (PTFE Based additive) to my OHC on someone's recommendation. Absolutely no difference. And after reading about PTFE based additives on the net, im kicking myself on doing so. Lucky I did'nt do it while changing my oil, just midway. Will get a firsthand experience once I open up the oil filter during the next oil change.
My verdict, Waste of Rs 500.
toiingg is offline
Old 19th September 2008, 00:23   #42
Thanked: 7 Times
PTFE is a Solid, Never add PTFE based additives with Engine Oil as it may block the oil circulation. If you really like NULON, you can add PTFE based additives in GearBox or Transmission Oil.
Old 19th September 2008, 00:51   #43
Thanked: 7 Times
Thanks friends, your comments encourage us to work more and more. OK, here are the results from todays works:
The Hose Joints before Cleaning:
Cleaning the Hoses:
Back to RED after Cleaning:
Inside the Head Cover after Cleaning:
Head Cover, Inlet Manifold, TURBO intake etc...
The Head after imported AUDI valve-oil seals:
The Gasket Kit:
Tomorrow we will assemble the head and expect some more photos...
Old 19th September 2008, 01:26   #44
toiingg's Avatar
Thanked: 85 Times
Not that i really like it or something, its just that it was recommended by someone who was quite knowledgeable about cars. At that time I did not get the time to check about the benefits online and took a can trusting his experience.
I had already done 4k in my current oil and would be changing it in another 1-2k so I thought what the heck, i'll add it now and even if it's no good, during the next oil change, its gonna get out of the system.
toiingg is offline
Old 19th September 2008, 01:47   #45
Thanked: 7 Times
No problem, it will not kill your Engine, let it to be there.
Use Bardhal Oil treatment(detergent based) if your Engine is old(more than 50k) or use OWS 220 if your engine is New. Never use PTFE or Zinc based Additives like STP, NULON in the Engine.
Closed Thread
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
