Old 25th August 2008, 15:06   #1
ibm_jennifer's Avatar
Thanked: 7 Times
Default OWS 15W40 vs Castrol Magnatec - Which is Better
Friends,
I want to know which oil is better?
OWS 15W40 is Mineral Based with extended oil changing intervals up to 90,000 km:
OWS - Redefining Auto Servicing
Castrol Magnetec is 10W40, but Semi-Synthetic. Cost 50% less than OWS.
Anybody have experience with OWS 15W40
I need if for my TCIC Safari, still now I am using Mobil 1 Delvac MX and looking for a change.
ibm_jennifer is offline   Reply With Quote
Old 25th August 2008, 15:22   #2
nitrous's Avatar
Thanked: 285 Times
I don't believe in the "NVH feeling" test of engine oils.
UOA ie Used Oil analysis is what is right.
A good chemical lab that does UOA would analyse the drained oil for various chemicals and tiny metallic particles from internals like main bearing,etc. This done at similar intervals on the same engine (after proper flushing) with the two oils can give you the verdict on which one is better.
This said, Castrol Magnatec is intended for petrol and is API-CF rated for diesels at best.
The OWS15W40 Super High Performance Diesel Oil is an API-CH4 rated and is quite superior to the Magnatec.
PS:Jeniffer, you don't have to start every thread in the Shifting gears section.
This could be in the Technical section.
Old 25th August 2008, 15:42   #3
Thanked: 7 Times
Thanks for the suggestion Nitrous. Is it true that OWS 15W40 is also Semi-Synthetic? Will it work better on a TCIC Safari?
Offtopic: I went to speedworks and bought OWS 360 & 210 for a test(???). They know your name very well(and I got 5% discount because of you!!!). Thanks Man.
Old 25th August 2008, 17:16   #4
nitrous's Avatar
Thanked: 285 Times
An API-CH4 from OWS is God send even if its semi-synthetic.
How much are they quoting for the 8 litres that your Safari takes?
Glad to be of help,Jeniffer.
Old 25th August 2008, 21:45   #5
Thanked: 7 Times
I am not sure about the price. Around 3-4k for 8 ltrs, I think.
Old 26th August 2008, 03:44   #6
OWS 10W40
This is their "semi synth" oil - its hydro-cracked , your link is mineral , not sure if THIS is good for you , but i have faith in OWS , all their products rock.
By making OWS your choice, you are different too and together we make the statement to the world that it still makes sense to pay for something that works.
cyneverdie is offline   Reply With Quote
Old 27th August 2008, 02:20   #7
Thanked: 7 Times
Is there any other Semi-Synthetic oil available here?
Maruti Circular on Swift Engine Oil : Change from 15W40 to 5W40 rahulrajeev Technical Stuff 106 13th April 2017 23:46
Engine Oil- Castrol Magnatec..for Swift, Opel?? humm Technical Stuff 183 21st March 2015 09:23
Experience - Castrol Magnatec Vs Total Quartz 7000 abhaybakshi Technical Stuff 22 25th October 2014 08:17
Castrol Bikezone = Castrol Bikepoint? UPDATE: Review of Ace Bikes, Bangalore (pg2) Soumyajit9 Motorbikes 20 21st July 2013 23:48
VW use Castrol Magnatec 5W40 for Polo, Why not EDGE? gaurav_chopra04 Technical Stuff 7 4th March 2011 00:46
