Old 20th July 2010, 07:43   #16
sudev's Avatar
Thanked: 2,655 Times
This reset is something new. Will try it next time I need to.
Battery reset is common to all new gen cars using drive by wire tech. SX4 and GV have no mechanical connection between accelerator pedal and throttle body. Just electric wires to drive a servo motor.
OT:
Throttle Body Reset - Could it have happened at a place worse than this? http://www.team-bhp.com/forum/travel...ml#post1958074 (My Mughal Road Rally)
sudev is offline   (1) Thanks Reply With Quote
Old 20th July 2010, 21:10   #17
vigsom's Avatar
Thanked: 604 Times
Originally Posted by joel.chandra View Post
Hi Folks. I replaced my batter yesterday and had terrible time since the guy who did this did not know about the Drive by Wire. Now my RPM at idle is 500 which sometimes is stalling the vehicle. I am going to reset this immediately and will share my experience again.
Originally Posted by avigster View Post
Absolutely true. happenned to my SX4 too. it seems when you disconnect the batterry for more than a few couple of minutes, throttle body is reset & that would essentially cause stalling problems.
I belive it's a common problem with SX4. Why was the batterry disconnected ? it's fairly a couple of minutes job to reset it to what it was before...nothing to worry about!
The problem of low rpm gets rectified automatically after some driving(say 1 hr) once the ECU gets fresh data ; please check and revert
Old 21st July 2010, 22:40   #18
Not sure about the problem getting rectified automatically after an hour of driving, but for sure it was heck of an easy job to resynch the throttle-body. Unfortunately cant check, sold the car in January!
avigster is offline   Reply With Quote
Old 22nd July 2010, 13:57   #19
Thanked: 87 Times
Ok, Perhaps a bit off topic, but does the new swift have Throttle by wire ? Since it now has the K-Series Engine of Ritz, which has Throttle by wire ( As far as I know).
And if it does, then can we do the same reset procedure as elaborated here?
allajunaki is offline   Reply With Quote
Old 22nd July 2010, 14:31   #20
raghu.t.k's Avatar
Thanked: 163 Times
Im not sure how long this would take, but is a real pain and sometimes dangerous while driving in the City. This happend to me when I took my SX4 to Cars India at Adyar, since rat or some other rodents decided to taste the wires connecting the ABS sensors, and gnawed them off. While fixing this they had removed the battery leads reconected once the wires were fixed. After this at every turning I had to be extremely careful, else the car would stall and steerings lock while turning. Finally took it back in the evening, not sure what was done, but managed to get it fixed.
raghu.t.k is offline   Reply With Quote
Old 27th July 2010, 07:25   #21
sudev's Avatar
UPDATE: After reading this thread I started wondering if some how my GV's problem could be linked to such a reset.
Problem: The car would take two or three long turns of cranking to start. Every time. Hot or cold. There was no problem with idling speed tick over.
Solution: Followed the procedure described. Key at Ign. Full press of accelerator. Key off. Release accelerator. Wait. Start the car. Starts at first try with normal cranking.
Thanks for the links and bringing this procedure to attention.
Observation: When ever you do ECM reset (by removing battery or this procedure) before starting the engine again switch off all lights and a/c. And above all do not touch the accelerator when cranking the engine. Most of the mechs do not understand the last part and press the accelerator a "wee" bit when cranking the engine. This throws ECM off and results in engine not idling properly.
Also I have seen stickers pasted on the dashboards of new cars which say "Do not press accelerator when starting" Normally this is ignored but is important for fly-by-wire ECM plus throttle body systems.
@allajunaki: AFAIK it should be same procedure. In any case removing battery terminal and reconnecting after some time works.
sudev is offline   Reply With Quote
Old 27th July 2010, 08:58   #22
rkbharat's Avatar
Thanked: 613 Times
time for me to try this. will do it today
rkbharat is offline   Reply With Quote
Old 13th July 2012, 09:33   #23
Thanked: 95 Times
Default Re: SX4 : Throttle Body Adjustment on drive by wire
I tried this on my SX4 today and it works. The throttle response is so much more better now.
zoombiee is offline   Reply With Quote
Throttle body cleaning amit_mechengg Technical Stuff 103 5th June 2018 12:04
Throttle Body Enlargement / Expansion hellspawn Modifications & Accessories 42 1st December 2009 09:44
RPM Surges-Throttle Body Cleaning wolfinstein Technical Stuff 29 6th October 2009 08:12
Throttle Body Bypass 1self Modifications & Accessories 3 7th September 2007 14:31
Optra, Throttle body repair sage Technical Stuff 5 7th June 2007 12:30
