Old 4th March 2010, 22:10   #16
planet_rocker's Avatar
Thanked: 368 Times
i sprayed WD40 around the wheel thingy (in between the metal body and the wheel) which is connected to the accelerator cable - it has helped to some extent. make sure you place a cloth below the TB to avoid excess oil dripping.
planet_rocker is online now   Reply With Quote
Old 4th March 2010, 22:19   #17
arjunrudra's Avatar
Thanked: 13 Times
I had the exact same problem in the 1.6 opel corsa. Everytime the clutch was pressed the rpm would fall to 0.Got this fixed . The problem was there was something wrong with the sensor.Costed me 700 rs only.
arjunrudra is offline   Reply With Quote
Old 4th March 2010, 22:48   #18
Thanked: 368 Times
1.6s behave a bit differently - erratic idles. rpm sticks at 1100-1500 range > falls down to 500 (at time stalls) > pulls itself up from 500 > sticks at 850 and the cycle continues.
the problem is more prominent when the engine is hot = the oily gum becomes more sticky inside the TB.
Old 5th March 2010, 13:22   #19
DRC
DRC's Avatar
Thanked: 48 Times
OK..
Just back from the garage.
Most parts suspected had been cleaned. TB, Manifold, EEC valve etc... I guess the erratic idle issue seems to have gone or may be it is too early to comment.
However, that slight vibration as if the engine is missing a beat is still there. It only happens when in idle and AC off.
Will update as I go. mean while your thoughts please!
DRC is offline   Reply With Quote
Old 5th March 2010, 13:30   #20
Thanked: 368 Times
can you show us a pic where the soots were present? it will be very helpful.
the minor jerk (single) is present in my car as well but that doesn't happen always (even in a hot engine) while idling.
all the best - keep us updated.
Old 7th March 2010, 00:10   #21
Default Facing similar problems
Dear Mr. Deepgautam,
Let me share some of my experience as I have been suffering from this problem since last six - eight months.
I am / was also facing almost similar problems. RPM was fluctuating between 200 to 3000 rpm, sometimes even zero and car coming to stop. The problem is more pronounced in start-stop traffic when the car moves in first 2nd gear. There is a loss of power under such circumstances, car frequently stalls. However, after sometimes when the car is allowed to cool. the problem vanishes.
I got the throttle body cleaned. No effect. Checked the car on examiner, some errors were there, removed. Problem reoccured.
Got the throttle body replaced as suggested by M/s Elegant motors, Patpadganj (probably the best service centers for FIAT cars). Problem is still persisting. Around a fortnight back, again visited the service centers, the car was examined on scanner, following errors were present: air temp error, water temp error, RPM sensor, potentiometer error.
I am told that ECU is probably faulty because these many sensors can not be faulty simultaneously. I was suggested to replace it. Of late, I found that engine overheat problem is also coming which I was said that it is linked with ECU problem.
I plan to get the ECU replaced next week, but before that, I want to seek opinion of FIAT experts. Even now, I am not 100% sure, whether the problem will be rectified by changing the ECU.
The ECU costs 10000 Rs.
I request experts to give their valuable advice.
Subodh Kumar
Subodh Kumar is offline   Reply With Quote
Old 7th March 2010, 00:18   #22
Thanked: 368 Times
Ecu costs 16k in kol. Injectors could be clogged. Try and use system g with regular fuel - 2 tank fulls. Or get injectors cleaned. Reset the ecu. Unplug the negative terminal of the battery for 30mins. Plug it back.
check fuel filter and air filter.
the last error points to dirty icv / throttle body.
Last edited by GTO : 8th March 2010 at 11:09. Reason: STRICTLY no SMS language please. Corrected.
Old 7th March 2010, 10:52   #23
Dear Planet Rocker
I regularlu use system G. Also, 2-3 months back, I used a solution (I am forgetting the name, probably presto - one bottle in full tank), I got the improvement in fuel efficiency, but the problem persisted.
ECU of 1.6 Petra / Palio cost Rs. 10000.
Old 15th August 2010, 22:09   #24
Hi Deep,
Im facing very similar problem with my Fiat Siena, as you had faced with your petra. The problem only happens when I park my car for some time after I have driven it for a while. Also if I leave the car alone for about half an hour, the problem rectifies itself.
Were you able to solve this problem? If so, could you tell me how? Thanks.
Aninda.
spacefugitive is offline   Reply With Quote
Old 20th July 2015, 17:55   #25
Default Re: FIAT Petra 1.6 RPM falling down to ZERO
I am having similar problems with my palio 1.6 and none are able to diagnose the issue :(
Joseph is offline   Reply With Quote
Old 24th July 2015, 00:12   #26
Thanked: 110 Times
what is the issue you are facing
vijaycool is offline   Reply With Quote
Old 24th July 2015, 17:58   #27
DRC
DRC's Avatar
Thanked: 48 Times
Josef, I think you bumped up a 5 year old thread.
If you are referring to the unstable idle and sometime engine stall issue on a Fiat 1.6 petrol, (same as I faced, )issue was traced to the ignition coil. They seem to have a limited life and fail invariably. I had to replace them twice in 10 years of ownership.
DRC is offline   (2) Thanks Reply With Quote
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
Ridiculous Marketing Gimmicks: X amount / day, zero down, balloon payments etc. RSM_TorqueZoner The Indian Car Scene 16 24th November 2014 11:34
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Fiat Petra - RPM Problem Rai Technical Stuff 25 14th November 2009 16:03
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
