Old 26th August 2008, 11:22   #1
deepgautam_qa's Avatar
Question FIAT Petra 1.6 RPM falling down to ZERO
Hello BHPians!
I have been facing a peculiar and frustrating issue with my Fiat Petra 1.6 (Year 2004; clocked 38K). Once every 300-400 KM, the engine refuses to pull the car. I am able to start the car but suddenly the RPM falls to ZERO and engine is off.....after giving several tries the engine finally starts but as I proceed, the engine keeps getting off between gear shifts and I have to give it self every 100-200 Meters. After running 7-8 KM the problem gets rectified itself. I asked my dealer (Dynamic - Noida) for a solution but he failed to provide one.
There is absolutely no other problem with car pick-up, speed, mileage, everything is fine except the above stated problem. I used LPG (Lovato) as fuel for around 10K KM, but since last 5K KM I've completely stopped using LPG. I am expecting to receive some info/solution regarding the same.
Cheers!
deepgautam_qa is offline   Reply With Quote
Old 26th August 2008, 11:35   #2
planet_rocker's Avatar
Thanked: 368 Times
get the throttle body cleaned - does it happen when the weather is hot and driven in stop and go traffic? what is the condition of the spark plugs?
planet_rocker is offline   Reply With Quote
Old 26th August 2008, 11:42   #3
Throttle body got cleaned and spark plugs also replaced during last service. Not only in hot weather, I face this problem when I start the car after keeping it parked for 1-2 hrs.
Old 26th August 2008, 13:51   #4
humyum's Avatar
Thanked: 2,502 Times
Sounds more like a dirty fuel filter/failing fuel pump.
Old 26th August 2008, 14:02   #5
I got the fuel filter changed during last service but the problem still persists.
Old 26th August 2008, 18:12   #6
Smile
Dear BHPian,
I am waiting for your responses. Please help me with your expertise and experience in resolving this problem.
Cheers!
Old 26th August 2008, 20:42   #7
I does sound like a fuel pump issue, but then, I am not an expert.
e1t1bet is offline   Reply With Quote
Old 26th August 2008, 23:06   #8
RedMM340's Avatar
Thanked: 24 Times
Have you replaced your air filter recently?
The other thing to do is get your car hooked up to the engine computer at dynamic auto. I know that they have one. There is a routine in the diagnostic that checks the throttle position motor. Just stand by the technician's side and make sure he does all the tests.
RedMM340 is offline   Reply With Quote
Old 27th August 2008, 10:39   #9
amitverma's Avatar
check your ignition switch. maybe it is the culprit.
when you say rpm goes to zero, you obviously mean the engine shuts down.
while running the engine try to move the key in the ignition switch a bit violently, if the ignition cuts, it is the ignition switch.
amitverma is offline   Reply With Quote
Old 27th August 2008, 15:27   #10
Smile
Thanks e1t1bet/RedMM340/amitverma !
Air and Fuel filter got changed recently. I'll get the fuel pump checked.
Regarding engine check by computer, they say they do it every time my car visits their work-shop for a service, but as suggested by RedMM340 now I'll stand by the technician when he performs the computer check.
Cheers!
Old 28th August 2008, 02:19   #11
RedMM340's Avatar
Thanked: 24 Times
Cheers!
It is very unlikely that Dynamic does a scanner test at every service. They charged me Rs. 300 for the computer testing an couple of months back.
There are several tests available on the computer, and when I went there, I had the tech run through ALL tests and he found the fan low speed to be not working and had to change a resistor. You will be amazed how helpful and willing the tech will be to run all tests if you slip him a Rs.100 note.
I would be very interested in what you find out, since I also see my engine rpm dip very low once in a while.
Old 28th August 2008, 11:34   #12
I'll be taking my car to Dynamic Auto this weekend. I'll certainly update you regarding the test result.
Cheers!
Old 29th August 2008, 16:14   #13
Thanked: 30 Times
Default FIAT Petra 1.6 RPM falling down to ZERO
Dear Deepak,
Get the ECM Reset & Fuel line cleaned & Fuel Filter changed cleaned,
I hope this would solve your problem.
In case problem still persist pm me & I would let you know the number of Fiat Service Head.....
Thanks & Regards
Anupam
anupam00 is offline   Reply With Quote
Old 4th March 2010, 17:24   #14
DRC
DRC's Avatar
Thanked: 48 Times
Unhappy Fiat Petra 1.6, unstable idle
Bumping up this thread with a new problem....
I need your expert advice and help with my Petra.
Timing belt replacement for my Petra was long over due. Should have replaced by 60K, but stretched till 87K. Yet the belt was good but the idler had given way. Finally got the work done 2 weeks ago.
I got it replaced at Hariprasad. Soon after that during the test drive, I noticed that the engine was missing a beat once in a while in idle. POwer delivery is neat, starts at the first crank, everything else is neat.
During the 2 weeks of driving the things got worse. Idling would not stay out in hot afternoon. Some times too high, sometimes too low.
Yesterday, took the car back to the garage and opened the hood to notice small traces of soot in the manifold (intake). When we opened the throttle body, there was quite a bit of it inside. The obvious suspect was the timing belt alignment which in fact was found a bit off. Yesterday, garage fixed that too but the problem persists.
Did a ECU scan, found errors related to Evap Emmission valve and MAP sensor. I expected this as both of them were stuck with soot in the manifold.
I don't know what direction to proceed now!
The car is still in the garage and the mechanic is trying trial and error. I quickly need expert's advice before my bill fattens because of his experiments. Please help
DRC is offline   Reply With Quote
Old 4th March 2010, 18:28   #15
Thanked: 368 Times
i am facing the similar sticky RPM issue (again) since last week.
I guess the ICV in the throttle body needs cleaning - open the hose and spray with an in-let spray. in the mean time try and reset the ECU and see if the problem persists.
in my case the air-filter / intake hose pipe were opened while the clutch fluid pipe was replaced. and i guess they started the engine w/o the filter/ hose pipe fitted.
i have applied WD40 near the hinge (where the accelerator cable is connected to the TB - outside) and it has shown some results though i am not fully satisfied. IMO it still needs cleaning from inside.
see this: Cleaning Your Inlet Control Valve - The FIAT Forum
Also see this: http://www.fiatforum.com/search.php?do=process
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
Ridiculous Marketing Gimmicks: X amount / day, zero down, balloon payments etc. RSM_TorqueZoner The Indian Car Scene 16 24th November 2014 11:34
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Fiat Petra - RPM Problem Rai Technical Stuff 25 14th November 2009 16:03
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
