Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 26th August 2008, 17:08   #1 (permalink)
teknophobia's Avatar
Default Weird temperature problem
I have been facing a weird problem with my Indica Turbo DLX, a few days back, when I started the car after having parked it for 10-15 minutes, after about 100 metres or so, the engine temp started to rise alarmingly and by the time I had moved to the side of the highway and parked, even though the temp gauge was halfway between the normal operating temp and the red portion of the gauge, the fan was not running. Last night, before parking the car for the night, I noticed the same problem. The temperature was somewhat elevated from normal.
The twist is that the car has not exhibited this problem while running, the temp remains at optimal even when pushing it at 120+ with the AC on or climbing steep slopes in 3rd gear.
Is it possible that something might have gone wrong with the fan?
__________________
Indica Turbo Dlx - 17+ KMPL through rush hour traffic in Mumbai
I miss my Conty :(
teknophobia is offline   Reply With Quote
Old 26th August 2008, 17:19   #2 (permalink)
tsk1979's Avatar
If fan is not coming on the fuse or relay may have gone bad. Get it checked.
At high speeds the wind speed cools the radiator, so even if fan does not come on, the car may not overheat.
__________________
Reclaimed, wrung dry and recycled....!
Old 26th August 2008, 18:01   #3 (permalink)
Originally Posted by teknophobia View Post
I have been facing a weird problem with my Indica Turbo DLX, a few days back, when I started the car after having parked it for 10-15 minutes, after about 100 metres or so, the engine temp started to rise alarmingly and by the time I had moved to the side of the highway and parked, even though the temp gauge was halfway between the normal operating temp and the red portion of the gauge, the fan was not running. Last night, before parking the car for the night, I noticed the same problem. The temperature was somewhat elevated from normal.]
If the fan is operating at times then you probably have a lose radiator fan relay. Get that checked. I have faced the same problem in my Indica as well once. If the fan is never operating, you might also need to get the fan motor checked (though I believe they replace the fan and motor as an assembly).
__________________
Stranger no more
Strangerintown is offline   Reply With Quote
Old 26th August 2008, 22:32   #4 (permalink)
Even when I am idling after a long drive or at signals the temp is not rising, it has just been those two incidents. I am taking the car to the TASC on saturday, let's see what the problem is.
__________________
I miss my Conty :(
Old 26th August 2008, 23:52   #5 (permalink)
Check the wiring these are common problems with indica. Does the fan come on when you idle after long drive [when the engine is hot and the car stops moving], if yes than there meter wiring has a short and/or the thermostat has to be checked.If not than the fan relay is the problem [get it changed] along with the AC relay as all these are on one circuit and any one faulty relay causes problem to the other.
dinar is offline   Reply With Quote
Thread Tools
Help - Laura AC weird problem vipul_bscity Technical Stuff 3 20th November 2009 13:53
Weird problem - Ikon madhunm Technical Stuff 11 15th February 2009 21:55
Weird iPod problem madbullram Gadgets, Computers & Software 3 27th July 2008 01:29
Weird problem...Palio Iknowthisguy Technical Stuff 16 31st August 2006 09:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
