Old 26th August 2008, 20:14   #1
RacingHart's Avatar
Thanked: 11 Times
Exclamation Opel Astra vibration problems
Hi everyone
A few months earlier I got a 98 opel astra petrol. I started getting a strange problem now a days. Whenever I drive my car above 100km/hr, the car starts shaking very badly. even the steering starts vibrating very badly. the vibration starts at 90km/hr, which is mild, and becomes severe once i reach 120/hr. i am unable to go beyond 120 due to this probs.
The tyres are new. Engine foundation bushes are good. everthing seems to be right, but this vibrating is very frustrating.
Please help me out friends. Also, when I switch on my AC, the car's pickup drops drastically. Please let me know what could be the problem.
Please help me friends
Thanks and regards
RacingHart
RacingHart is offline   Reply With Quote
Old 26th August 2008, 20:35   #2
aah78's Avatar
Thanked: 1,646 Times
Arrow balancing
How new are the tyres?
One or more of your wheels are probably not balanced.
That's what I'd get looked at first.
aah78 is offline   Reply With Quote
Old 26th August 2008, 21:11   #3
flipsyde's Avatar
Thanked: 62 Times
Wheel balancing would be my first suspect. If that doesn't work you could have worn out wheel bearings. I think you should check the bearings first though.
flipsyde is offline   Reply With Quote
Old 27th August 2008, 01:20   #4
RacingHart's Avatar
Thanked: 11 Times
thanks flipsyde. I will check that, and by the way do you have any idea how much would it cost if i get a new bearings for opel astra 98 petrol
Old 27th August 2008, 10:05   #5
Thanked: 564 Times
@ RacingHart
As vibrations are felt at high speeds, please have wheel balanced with a dynamic balancing machine (available at most tyre shops). If problem persists, then look at other components like bearings.
What kind of wheels is Astra running on, stock steel wheels or alloys?
sukiwa is offline   Reply With Quote
Old 27th August 2008, 17:08   #6
RacingHart's Avatar
Thanked: 11 Times
My beauty is running with the original factory installed 5 spoke alloys. I got my wheel balanced, the vibration has decreased a little bit, the only difference is, now i feel the vibrations if i reach 140 k/hr. dono what to do. Please suggest.
Opel Astra Club or Opel Corsa bsashwin Sedans 2 11th July 2006 17:34
Opel Astra Automatic Wanted haryan Shifting gears 17 19th November 2004 02:57
Query regarding Opel Astra. nisweth Technical Stuff 4 17th November 2004 12:36
Opel Astra HPC amit The International Automotive Scene 13 27th September 2004 10:42
Opel Astra GTC amit The International Automotive Scene 7 21st August 2004 13:57
