Old 27th August 2008, 08:54   #1
clevermax's Avatar
Thanked: 401 Times
Default Different bore sizes or the alignment?
I happened to see a Palio 1.9D's engine opened up yesterday. When I looked at the base, as shown in the picture, two of the bores (marked in yellow) are deepeer than the other two.
Are the bore volumes unevenly distributed? Or is it just the positioning of them? I always thought that the bore volumes will be equal.
clevermax is offline   Reply With Quote
Old 27th August 2008, 08:56   #2
Nikhilb2008's Avatar
Thanked: 4,772 Times
naaah..... just that the pistons in those two are closer to (Bottom Dead Centre)BDC than the middle two.
IT is perfectly fine.
If you could rotate the crankshaft, you would see the position change.
Old 27th August 2008, 09:09   #3
nitrous's Avatar
Thanked: 282 Times
This picture will help you understand.
Old 27th August 2008, 20:03   #4
Rehaan's Avatar
Thanked: 22,566 Times
Clevermax,
Nikhil & nitrous have done a good job of explaining this, i just wanted to add (for the sake of information) that the bore is the diameter of the cylinder, and what you are refering to as the "depth" could also be termed as the stroke (ie the entire length of vertical travel).
Area from Bore x Stroke = Displacement (Volume)
cya
R
Old 27th August 2008, 20:25   #5
clevermax's Avatar
Thanked: 401 Times
Thumbs up
Clevermax,
cya
R
Thanks a lot for the explanation! Now I understand it the right way. (Bore, Stroke)
The picture does not help me understand why two of the 'cavities' are deeper. In your picture, if you rotate the crackshaft 180 degrees, you can see the other two pistons coming up to the same position as the ones in the top position shown in the picture. So why should the stroke be deeper in two of 'em?
Can you please explain more on BDC?
Old 27th August 2008, 22:37   #6
The piston moves up and down in the cylinder. When it is closer to the top(at the end of the compression stroke for example), it is known as TDC. Top Dead Centre. It cannot go above this particular point.
Same way, BDC is the bottom most point the piston can reach while working. BDC is reached at the end of expansion stroke and end of suction stroke.
The pistons are connected to the Crankshaft by use of a connecting rod. So, here the pistons at the extreme ends of the cylinder are near the bottom of the cylinder than the middle two pistons.
Old 28th August 2008, 08:31   #7
clevermax's Avatar
Thanked: 401 Times
Now I got it right. Thanks!
Old 30th August 2008, 17:45   #8
clevermax's Avatar
Thanked: 401 Times
A better illustration of what I saw.
(I drew it myself )
Yet another valparai trip to bore you!! Soccerfan Travelogues 64 28th June 2010 18:10
Rx135 4 speed -bore gets heated prsnck Motorbikes 15 14th June 2010 16:39
Brace yourself - i'm going to bore you to death! IronH4WK Introduce yourself 18 23rd December 2009 21:21
Hub/Bore Diameter doubt about Baleno Rims greenhorn Tyre & Alloy wheel Section 6 28th October 2009 15:22
