Old 29th August 2008, 16:22   #1
Default help:about carb slide
hi friends my m800 was giving low fe so went to mechanic . he told me that carb slide has cracked . i need to change it. i want to ask whether it is true .how much does the slide cost . what is work of slide
harry2223 is offline   Reply With Quote
Old 29th August 2008, 21:24   #2
Thanked: 253 Times
Originally Posted by harry2223 View Post
... that carb slide has cracked
C'mon Harry, if it has cracked, you should be able to SEE it!
And if it is true, something HAS to be done, right?
Old 29th August 2008, 23:19   #3
kuttapan's Avatar
Thanked: 12 Times
Probable, but highly unlikely.
A carburettor works on the venturi principle. Slide is the device which controls the venturi dia. I suggest reading up on HowStuffWorks "How does a carburetor work?", lest I confuse you.
Basically, it is cylinder with a cutaway which regulates fuel going into you engine. If cracked, it can upset the working of the carburettor(making the mixture lean, would be my guess) and cause some side effects. I am not sure about the low FE, but if your mechanic is trustworthy, then maybe he is not trying to pull a fast one on you.
Slide should not cost too much, especially for an M800. Changing it should be less than half-hour job.
edit : - I realise that the link I provided does not show the working of a slide type carburettor. You could refer to the thread http://www.team-bhp.com/forum/motorb...-rd-350-a.html (Help Carburetor....Bullet 500>>or<<RD 350) to see the innards of a carb. Part 20 is the slide. Should be fairly similar in the Maruti.
If the Maruti carb is a butterfly valve type, maybe he means the butterfly is cracked? Can someone comment on this?
kuttapan is offline   Reply With Quote
Old 29th August 2008, 23:24   #4
Sankar's Avatar
Thanked: 4,656 Times
Harry, m800 carb doesn't have a slide. They have throttle butterfly. Is it that what is cracked? You can visually inspect it by taking off the air cleaner assembply and peeking down the venturi.
New SUV to slide in between the Evoque and Range Rover Sport? Tushar The International Automotive Scene 5 11th April 2015 10:53
Suzuki GS 150R: Braking causes the rear to slide out rajahamsa Motorbikes 15 18th September 2013 03:06
1,47,658 km Zen Mpfi report + drift and slide pics BunnyPunia Long-Term Ownership Reviews 16 20th August 2013 06:40
Best slide mobile for around 8K max? ramki067 Gadgets, Computers & Software 0 3rd October 2010 09:51
guys.... need help on carb esteeem.. angelfire Technical Stuff 2 27th November 2005 12:23
