Old 30th January 2010, 01:49   #31
Thanked: 99 Times
Originally Posted by reddy6980 View Post
Finally the overheating problem was resolved, the culprit was the brake master cylinder which had worn out a little. A new one was replaced(KBX brand).
Now the brakes seem to be on the litter side should i ask the mechanic to adjust the brakes or will they get back to normal after some time.
Kindly expand your words-
What problem you were facing from brake master cylinder? Is there wheel jamming type some?
(Alok) is offline   Reply With Quote
Old 30th May 2010, 22:14   #32
narendra.vw's Avatar
Thanked: 402 Times
Hi, Reddy
I read your post today. Over Heating in rebuilt engine, causes may be many.
1) rings gap may be less. This leads to tighten of pistons
2) main & connecting bearing seating .
3) running in of the engine with no load. At least for 6hrs.(3hrs in circulating cold water.3hrs circulating same hot water)
4) engine head surface. Should be clean, even, no pores near the valves.
5) a/c condenser should cleaned by pressurized air. Radiator to be over hauled thoroughly, check for leakage. Paint it dual black. heat dispersion will be better.
6) never use a/c at least for 1000km.
7) change all the rubber hoses.
8)pump calibration and proper timing is amost.
Lastly, I don’t think brake has something to do engine over heating. Brake problem will heat brake disc/drums.
narendra.vw is offline   Reply With Quote
Engine for Tata SIERRA samybravo Modifications & Accessories 52 18th July 2012 17:23
Zen Engine overhauling enigmatictech Modifications & Accessories 12 1st February 2010 10:10
Diesel overhauling TeddyBear Technical Stuff 6 21st March 2008 16:59
HELP Transplant Petrol Engine In TATA SIERRA malvechaitanya Modifications & Accessories 3 16th February 2007 22:20
