Old 6th September 2011, 15:29   #16
Thanked: 72 Times
Default Re: Noise from Idler bearing...
Originally Posted by abhipuru16 View Post
Compressor Clutch maybe?
But the noise should reduce if I switch off the AC but that doesn't happen. Intensity of noise remains same no matter if the AC is ON or OFF. Moreover why the noise subsides when with the new bearing momentarily is what I fail to understand :(
akhilesh is offline   Reply With Quote
Old 6th September 2011, 22:56   #17
mgh
Thanked: 33 Times
idler pulley is used
1. to increase belt contact area
2. to easily adjust belt tension
belt can give noise
if tension is low.
or contact area is less (design problem in Indicas initially)
Usually, belt noise would be heard, when the engine is started first time in the morning, and then go away.
Physical inspection of the belt would tell you whether it needs to be changed. It would also need to be changed (rarely), if it has stretched so much that you cannot get the belt tension needed.
Bearing noise would be more persistent and change with engine speed.
mgh is offline   Reply With Quote
Old 6th September 2011, 23:00   #18
dot
dot's Avatar
Thanked: 714 Times
Default Re: Noise from Idler bearing... WagonR 2006 this time
Originally Posted by akhilesh View Post
There's a kat-kat sound which is really annoying and grows louder as the engine gets warmer.
it was found that the noise vanishes when AC belt is removed.
Took it to MASS where it was found that its the bearing again after replacing it noise was gone again but only momentarily.
It could be a belt noise too. Would it be possible to change the belt and check for noise. Does the WagonR come with a hydraulic belt tensioner? That could be another part to look into. Hope this helps.
dot is offline   Reply With Quote
Old 7th September 2011, 12:34   #19
Thanked: 72 Times
Its a new belt and its not a screeching noise which comes due to loose belt. Its a metal kat-kat sound which is typically of a bearing.
Could this be due to alignment which is causing the bearing to go bad ?
Old 27th September 2011, 16:26   #20
Thanked: 72 Times
Just for an update so that it can benefit others facing similar issue. The noise is finally gone. I replaced the belt and told my mechanic to keep it a little loose and bingo the noise was no longer there . So there could be 2 things, either the belt was the culprit or it was simply the tension tha was applied on the belt
Its is surprising that it was such a small fix and MASS was speculating a complete engine rebuild
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
the bearing used in handle bar of bikes vivekiny2k Technical Stuff 4 14th December 2005 10:48
