Old 10th September 2008, 06:39   #1
mdesai_1981's Avatar
Angry Spark plug clearance on a Chevy Optra 1.6?
Hi guys,
Yesterday i had my spark plugs changed to bosch super. the preset air gap is 0.9mm and my manual says that i need 1.0~1.1mm. now my mechanic says that due to heat the preset air gap increases and it willl be 1.0mm once i start the car! is it true?
Also when he was changing the plugs we noticed that a little amount of engine oil was in number 3 chamber of the plug (not where the plugs ignite the inside combustion chamber, but where the cables go to reach the plug) he said that the TAPET COVER SEAL needs to be replaced and its not a big job and can be done later also. i would like to put it very precisely that very little amount of engine oil(around 1-2 ml) was found in it and he cleaned it and installed the plugs.
One more thing i would like to add is i have got my injectors cleaned at 17000kms(15 months back) and engine decabonised at 20000kms(12months back) now i'm at 30000kms do i have to get my throttle body cleaned and adjusted by removing it? i've also done engine flushing with changing the spark plugs.
by the way i'm having a chevy optra 1.6 .
please help me guys
mdesai_1981 is offline   Reply With Quote
Old 10th September 2008, 09:50   #2
Thanked: 245 Times
Metal expands on heating and does not turn away, so the gap will decrease on your plugs. Get the seal changed and follow the service manual for the throttle body cleaning.
Old 10th September 2008, 10:04   #3
Thanked: 16 Times
First of all the people who wrote the manual must have been aware of the fact that metal expands on heating. So they must have considered that.
Secondly, it's not only the tip that would expand. The whole spark plug assembly would expand so the end result may be a constant gap. I would say stick to the manual. You can also try driving it around and see if there's any difference for better and decide.
anupamsinha is offline   Reply With Quote
Old 10th September 2008, 10:25   #4
Thanked: 245 Times
Thats what I meant, stick to the prescribed gap and dont add your margins.
Old 10th September 2008, 10:27   #5
Jaggu's Avatar
Thanked: 8,693 Times
Replies inline in Bold
Originally Posted by mdesai_1981 View Post
Hi guys,
Set to comp specified limits
he might be right, since the oil residue is on the outside
Either you can use throttle body cleaner spray (2nd preference) OR do it the proper way by opening and cleaning the assembly. Get it done by A.S.S dont rely on local mechs for such jobs. they do tend to screw up big time
Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug finetuning Modifications & Accessories 20 12th September 2011 10:45
Chevy Spark...Chevy U-VA...comparative test drive report! omar1310 Test-Drives & Initial Ownership Reports 0 7th June 2007 11:59
Dicounted Chevy optra vs Chevy Aveo 1.4 LS vs NHC GXI kumar Sedans 41 25th May 2006 15:35
How does spark plug gap affect mileage? Samurai Technical Stuff 1 27th December 2005 15:24
MSD Spark Plug Wires & Ignition coil Kaizer Sozay Modifications & Accessories 11 16th December 2005 09:12
